Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 09-09-2006, 06:51 PM   #46
monacoo is on a distinguished road
Quote: Originally Posted by 4u2n View Post
Here is the total pinout for the Blaupunkt
This is complete for newer models:
And for old models:
monacoo is offline   Reply With Quote
Old 10-24-2006, 08:16 PM   #47
Maxis24's Avatar
Maxis24
Thank you for the pin out diagram, I finally have an excuse to replace my after market stereo with a stock Ford Blaupunkt unit.
2000 Ford Focus ZTS
Maxis24 is offline   Reply With Quote
Old 03-31-2007, 01:24 PM   #48
rubicon's Avatar
rubicon is on a distinguished road
Alpine KCE-422i "Full-Speed" iPod Cable
Code:
KCE-422i pin Corresponding iPod dock pin(s) ------------ ------------------------------ 1 3 (Line-out, Right +) 2 21 (Accessory Indicator) 3 12 (Serial Tx) 4 4 (Line-out, Left +) 5 19,20 (FireWire +12VDC [in]) 6 18 (+3.3VDC [out]) 7 13 (Serial Rx) 8 2 (Line-out, Common GND) 9 11 (Serial GND) 10 16 (USB GND) Jacket 29,30 (FireWire GND)
Dock connector pin designations from Dock Connector - wikiPodLinux
rubicon is offline   Reply With Quote
Old 06-08-2007, 09:05 PM   #49
jakegaisser is an unknown quantity at this point
EL Backlight with inverter HD44780 character LCD Diagram
Last edited by jakegaisser; 06-11-2007 at 05:59 PM. Reason: image url broke, made image attachment
jakegaisser is offline   Reply With Quote
Old 07-19-2009, 12:24 PM   #50
awace is an unknown quantity at this point
Quote: Originally Posted by Chairboy View Post
gah, no sense of humor.
Quick method for regulating 12+ to 12v steady. There's a voltage drop off of around 1v or so. Using a 7505 or 7509, you can get regulated 5v or 9v too respectively.
Note: Less then 1 amp load. You cannot get regulated 3amps by just using 3 7512s or the like, so don't try.
you need a big capacitor too cause the diodes in youre alternator might not be all there cap goes across output and should be more than 15v . I would take one out of a existing 110v to any DC output power pack and use that type capacitor this would get less ripple on scope reading! GOOD LUCK.
an 340t5 is a 5v one and hooks up same . I use them in Atari2600
2200uF 16v should work if you want quality pick a 50v one! this should eliminate ripple out out put of regulator just fine...
awace is offline   Reply With Quote
Old 08-11-2009, 10:29 PM   #51
jatt1188 is an unknown quantity at this point
Quote: Originally Posted by Nicorolla View Post
carPC Turn On / Shutdown Controller
Material needed
2x SPDT standard automotive relays - automotive store or electronic store
2x Diode - Radio shack or electronic store
1x Serial port connector - Old serial device (mouse, joystick etc...) or radioshack or electronic store
1x Fuse holder + fuse <- VERY IMPORTANT !!!!! (if power source already fused then you're ok)
10g or 12g wire for providing power to the inverter (bigger is better)
16g to 18g wire for your relay triggers, grounds and 5V connection
Misc. connectors
In the BIOS set your motherboard to turn on after powerloss so the second you feed power to the power supply it will turn on.
Get an old serial port device, rip the connector off of it, take the cover off and solder a wire on PIN 8. If you look very closly the pins will be numbered on the connector. When PIN 8 is not getting 5v, it will initiate the windows shutdown. (credit to Laidback) Refer to the diagram for wiring.
Go into your control panel -> Power Options - Create a generic UPS with these settings (picture bellow this one)
note: some versions of windows xp does not have the UPS tab (ie: windows xp home) - xGROMx
More details and hints:
-The numbers you see on the diagram (87,88,85,30) are the pinout of a standard 12v SPDT relay
-The >| symbol are diodes, they are crucial to making this work.
-You can use your amp's turn on wire to make this work instead of ACC, however some amps may "thump" when the carPC turns on. The real ACC can be found in the head unit harness.
-Some cars turn off the ACC while being started, this may trigger the hibernation. The diagram below will solve this problem
Updated diagram - will only work on ignitions that have a key switch (most cars do). To know if your car has a key switch, leave your door open and put the key in the ignition w/o turning, if you hear a door chime, you have a key switch. It can be found right on the ignition plug itself. This may be a little more advanced for some users, testing with a multimeter is the only way to find the right wire.
This will only trigger hibernation when the key is removed from the ignition
Updates - July 2006
Alternative to the key switch method, to avoid hibernation being triggered when starting and the ACC turns off during cranking. -Important to follow the diode connections as shown below
Enjoy
For questions, please PM me
hey i was just looking at the info tht u provided and my comps power supply and i have some questions
1) wts up with the serial port device
2) is pin 8 same as pin that i have on power suppy saying p8 which connects to lines coming to my dvd player.
3) where you says to pin 8 on comp 1 where does that wire go plz expain
thanks a lot in the advance
really appropriate all the help
jatt1188 is offline   Reply With Quote
Old 08-13-2009, 11:08 AM   #52
Sicarius is on a distinguished road
1)The serial port is to have this circuit emulate a UPS to get the computer to shut down.
2) NO! He said serial port and he meant serial port.
3) It does not say pin 8 on "comp 1" it says "COM 1" as in COMmunications port 1, as in the first serial port.
Sicarius is offline   Reply With Quote
