Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 07-23-2004, 03:25 AM   #1
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
Schematics/Pin Outs/Diagrams
This thread is for schematics, pin-outs, and diagrams ONLY.
NO COMMENTS. IF YOU WANT TO MAKE A COMMENT OR ASK
QUESTIONS, MAKE A THREAD IN THE APPROPRIATE FORUM.
FORMAT RESTRICTION:
Schematic Purpose:
Pictures/Notes:
Extra Notes:
Have fun guys
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 07-24-2004, 06:58 AM   #2
pioneer is on a distinguished road
S-Video Pin out
Pin Name Description
1 GND Ground (Y)
2 GND Ground (C)
3 Y Intensity (Luminance)
4 C Color (Chrominance)
Code:
3 o o 4 1 o o 2 = 4 pin Male
ill try get an image instead, but for now it will do
pioneer is offline   Reply With Quote
Old 07-24-2004, 07:46 AM   #3
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
Garmin GPS 4 Pin Connector
Pin connector as seen from back of unit
Pin Name cable color
1 power input red
2 ground black
3 data out brown
4 data in white
jcdillin is offline   Reply With Quote
Old 07-24-2004, 03:22 PM   #4
Chairboy's Avatar
Chairboy is on a distinguished road
gah, no sense of humor.
Quick method for regulating 12+ to 12v steady. There's a voltage drop off of around 1v or so. Using a 7505 or 7509, you can get regulated 5v or 9v too respectively.
Note: Less then 1 amp load. You cannot get regulated 3amps by just using 3 7512s or the like, so don't try.
Chairboy is offline   Reply With Quote
Old 07-24-2004, 03:24 PM   #5
Chairboy's Avatar
Serial pinout:
Old 07-24-2004, 03:28 PM   #6
Zoltan's Avatar
Zoltan is on a distinguished road
Auto Power-Up laptop
Sends a momentary pulse to push the power button when the computer senses the charging go from cold to hot AND it's not already awake.
Enjoy!
'03 Escape 4WD:
-iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
-Transflective 8.4"
-XM, iG4, OBD-II (BR-3)
-Rearview camera with auto-switching (modified cheesbox)
-Slim Slot DVD+RW
-RR, DFX 4
Zoltan is offline   Reply With Quote
Old 07-28-2004, 08:21 AM   #7
MikeH is on a distinguished road
"Valet" switch to bypas ITPS/Opus/CarNetix
Here is a switch configuration that let's you manually control your PSU. It works for ITPS, Opus, and CarNetix type PSUs.
MikeH
MikeH is offline   Reply With Quote
Old 08-06-2004, 06:04 AM   #8
stimps's Avatar
stimps
Heres the pinout for your normal DB25 printer cable to use for wiring up HD44780 type LCD's
stimps is offline   Reply With Quote
Old 08-10-2004, 07:52 AM   #9
stimps's Avatar
stimps
relay circiuts.
These circiuts you may find usefull to "trick" a motherboard into powering up just after it has recieved batt power thru an ignition relay and a "on pulse" is needed to fire up the atx motherboard connection. There are plenty of other uses for them if you can think of them. Such as dethump power dissconection of amps during head unit turn on, etc.
Old 08-22-2004, 07:09 PM   #10
Gibson99's Avatar
Gibson99 is on a distinguished road
just found this site which lists a ton of connectors and all their relevant pinouts.
http://www.networktechinc.com/technote.html
has common pc, mac, sun, sgi, paralell, serial, usb, 1394, video, and other connectors i've never even seen before.
Previous: CamryAmp 1.0 - 95 Camry SE V6 Coupe (sold)
Current: CamryAmp 2.0 - 98 Camry CE V6 5spd
Gibson99 is offline   Reply With Quote
Old 10-03-2004, 08:08 PM   #11
Arathranar is on a distinguished road
DIY aux input to some stock radio units.
I found this whilst researching whether the 13 pin connector on the back of the stock radio in my 2000 Subaru Impreza Sport could be used as an aux input.
Looks like it can:
http://www.wakeworld.com/MB/Discus/m...tml?1096256753
I'm going to be giving this a go as I want to keep the hud and not have to use an amp.
Edit. Tried this, blew my radio up and had to buy another one. Moral:
1. Measure pin voltages before, not after you blow things up.
2. Connecting +13V directly to ground is a bad idea.
2. The pin out of the 13 pin connector on Clarion radios is not the same across all the models with that socket. I've since found a second pin out that still doesn't match my radio.
Arathranar is offline   Reply With Quote
Old 10-14-2004, 08:24 PM   #12
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
Most pioneer headunits have a IP-bus for controlling a CD-changer. This can also be used for aux input.
This website has the pinouts for the IP-bus in general, and directions for how to easily hook up wires to the pins for aux-input.
http://www.gutterslide.com/ip-bus_hack/
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 10-19-2004, 11:44 PM   #13
jaak's Avatar
jaak is on a distinguished road
Connectors for Nissan Murano, but good for many Nissan / Infinitis... Includes Sat receiver.
http://ca.geocities.com/muran0@roger...nectorInfo.htm
Murano Sat Radio...
jaak is offline   Reply With Quote
Old 10-29-2004, 12:03 PM   #14
lastkaos is on a distinguished road
A lots of connector :
http://www.hardwarebook.net/connector/index.html
lastkaos is offline   Reply With Quote
Old 11-06-2004, 06:15 PM   #15
MySQL Error
jcdillin's Avatar
This circuit waits for a set time and then activates a relay.
With the cap that is in the schematic you will get about a 6 sec delay till power on. You can change the cap in this circuit to 470uF for about a 20 sec delay.
肚子笑痛了
S60 Install
