11-06-2004, 08:22 PM
#1
MySQL Error
XMDirect Cable
Well after a couple days of playing with the XMDirect tuner, and doing some research I have been able to make my own cable for attaching the XMD1000 to your PC so you can control it using your serial port using frodoplayer.
It's actually quite simple first you need to find either a 8 pin mini-din plug or a old style mac printer cable.
Then you just attach the pins from the 8 pin din to the following pins on a 9 Pin DSUB Connector using the pinouts below.
XMD -- DB9 Serial
pin 1 = pin 3 Data Receive
pin 2 = pin 2 Data Transmit
pin 3 = pin 5 Ground
Then after you have those connected you just need to find a source of power which can come from your PC power supply. Pinouts below.
XMD -- Power supply
pin 6 = 12v
pin 7 = 12v
pin 8 = gnd
And that is pretty much it. Works perfectly with frodoplayer.
Images of the pinouts below.
11-06-2004, 08:29 PM
#2
Bowel movement
one of these days ill have to get XM
11-06-2004, 08:35 PM
#3
MySQL Error
it's worth the $10 a month
11-06-2004, 08:49 PM
#4
is this the same type of cable that is being sold in the mp3car store for 50 bucks?
CarPc Done.
HA HA......Is it ever done?
11-06-2004, 08:53 PM
#5
Bowel movement
What cable are you talking about? I didnt see one for 50 bucks
11-06-2004, 08:54 PM
#6
MySQL Error
I didnt know the mp3car store was selling one, but this is the same cable that hybrid mobile is selling.
11-06-2004, 08:56 PM
#7
if you want to add status lights for transmit and power use a 200 ohm resistor to a LED hooked to pin 3 and for power use a 500 ohm to another led.
11-06-2004, 09:02 PM
#8
CarPc Done.
11-06-2004, 09:07 PM
#9
Did you send it the magic word to switch it to pcr mode?
11-06-2004, 09:10 PM
#10
wha........?
part of me REALLY hopes you are kidding......
11-06-2004, 09:27 PM
#11
MySQL Error
ehh?
11-06-2004, 09:28 PM
#12
MySQL Error
Thanks! i'll have to try that.
11-07-2004, 01:25 AM
#13
Excellent info jcdillin! Thanks!
11-07-2004, 01:46 AM
#14
What are you talking about?
11-07-2004, 10:33 AM
#15
you can do that using a software and not worry about it...
| Thread Tools |
| Display Modes |
Linear Mode
