Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 11-30-2004, 10:37 PM   #1
SWC
Auto activate backup camera
I am looking for a way to interface a backup camera so that when the car is in reverse it will automatically go to the backup cam screen. I know how to wire it into the car (pretty easy actually) just need to hook it into the backup lamp wire. But what is an easy and fairly inexpensive way (I.E. No phidgets since a solution would be like $100+ probably) to have the computer determine when the circuit is turned on so that it can activate the backup cam.
SWC is offline   Reply With Quote
Old 11-30-2004, 10:45 PM   #2
kiltjim's Avatar
The software that I am trying to develop for this board here. will do it.
Otherwise, without the board, it would take a very little script, or FrodoPlayer to do it. And the trigger would be wired into the serial port.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 11-30-2004, 10:48 PM   #3
Dracos's Avatar
well, a relay i guess. ummm, a relay with software?
eg, 12v from rear illumination (reverse lamp) turns on relay, closes a switch, turning the camera on.
software determines when camera is turned on, and cuts to cam view when it is on
that is easy, you just gotta get someone to wrie the software
on that note, you could have a kinda double circuit. what I said above, except the relay is a SPDT relay, closing a switch turning the cam on, and shorting 2 pins on the comp/LPTI port. the shorting of the 2 pins would launch your rearview app, or would act at a 'hotkeyy press' for whatever you want. speak to weekendowel, i know he can do software like that.
Dracos is offline   Reply With Quote
Old 11-30-2004, 10:53 PM   #4
My Village Called
0l33l's Avatar
Well, you could ask the person who wrote the software for when doors are open to add a sensor to the serial port that detects if two pins are shorted (when you have the backup light).
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 11-30-2004, 10:57 PM   #5
SWC
Depending on how expensive the serial option is that might be worth a shot, writing the software isn't a problem. I decided to take a look at phidgets for just the voltage sensor its $17US. Not too bad the USB interface is the expensive part but may not be too hateful if I decide to hook it up to my AC and control that as well. It would bring the cost to $68 plus the cost of the servos for the AC. so total cost of controlling AC and rear cam would be about $122.
Old 11-30-2004, 10:59 PM   #6
Dracos's Avatar
lol! I already told him to do that
Old 11-30-2004, 11:34 PM   #7
My Village Called
0l33l's Avatar
You said LPT port, I said Serial
GammaControl v2.4
SKINbedder v3
Old 11-30-2004, 11:36 PM   #8
Dracos's Avatar
psh - effectively the same method (although what i meant was about asking owel )
Old 11-30-2004, 11:43 PM   #9
My Village Called
0l33l's Avatar
GammaControl v2.4
SKINbedder v3
Old 12-01-2004, 12:14 AM   #10
Dracos's Avatar
now thats just spamming lol
Old 12-01-2004, 12:26 AM   #11
SWC
He's gotta get that post count up somehow.
But I think I am gonna go with the phidgets system. I know I didnt initially but after seeing its only $17 more than my A/C controller its pretty much a no brainer.
Thanks guys.
Old 12-01-2004, 12:46 AM   #12
Hardware all the way...
http://www.mp3car.com/vbulletin/general-hardware-discussion/23462-auto-reverse-camera.html
Specifically http://www.mp3car.com/vbulletin/show...84&postcount=2
I know there is a more indepth explanation of how to mod the thing, but I really didn't feel like reading through all 7 search results for cheesebox...
Good luck.
msb5150 is offline   Reply With Quote
Old 12-01-2004, 10:27 AM   #13
Tainted Love
Cris's Avatar
How about this... http://www.cartft.com/carpc/catalog/il/395
Cris is offline   Reply With Quote
Old 12-01-2004, 04:27 PM   #14
SWC
Quote: Originally Posted by Cris
Nice solution but no good with computers no interface. also even if that is used it only switches RCA video so it couldnt switch the LCD from VGA to RCA.
Old 12-05-2004, 02:09 PM   #15
DeltaFX's Avatar
May be a velleman K8055 kit could help. It can sens volts.... And because a cam usually can see infrared, you could wire a huge IRspot to make sure there's nothing behind the car.
DeltaFX is offline   Reply With Quote
Auto reverse camera Tha Hombre General Hardware Discussion 28 10-10-2008 03:30 AM
Download Destinator 3 UK Speed Camera Pack HERE miagi Map Monkey 29 04-09-2007 06:44 PM
Backup Camera Screenshots, please. Zoltan General Hardware Discussion 12 09-05-2004 08:52 AM
For Sale, 1 x Wireless Miniature Security Camera. buildfromscratc Classified Archive 0 07-15-2004 07:13 PM
Great working tank circuit with backup bat. NightHunter Power Supplies 6 04-29-2004 10:51 PM
