Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 12-29-2004, 10:08 AM   #1
frankz's Avatar
temperature sensors
here's a couple links for anyone who might like to add
temperature sensors to their car, connected to your carpc:
http://www.lancos.com/webtherm.html
http://www.riccibitti.com/pc_therm.htm
for the sensors (ds1631),
Dallas Semiconductor was taken over my Maxim IC
maxim-ic.com
you can get a couple of them for free, by requesting free samples.
frankz is offline   Reply With Quote
Old 12-30-2004, 01:06 PM   #2
MySQL Error
MatrixPC's Avatar
This is what I really want for a car PC temp sensor
http://www.cesko.host.sk/GamePortTemp_eng.htm
But I can't find those sensor in the States
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 12-30-2004, 01:38 PM   #3
My man uses Levitra.
Peoples's Avatar
http://www.its-about-time.com/htmls/...atempsens.html
this one looks pretty neat
i bunch of them i've looked at retail at over $160, which IMO is rediculous, but $40 aint bad
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 12-30-2004, 01:44 PM   #4
egeekial's Avatar
I'd much rather just get one of these:
http://www.phidgets.com/index.php?mo...D=Admin&IID=85
and a couple of these:
http://www.phidgets.com/index.php?mo...223.128&IID=81
2001 Nissan Altima SE
Shuttle FV24 / P3 1Ghz
512MB (2x256) PC133 RAM
40GB 7.2k RPM
WiFi / GPS / XM
Opus 150
Xenarc 700TSV
XP Pro (nLite) / Frodoplayer
egeekial is offline   Reply With Quote
Old 12-30-2004, 03:39 PM   #5
Skipjacks's Avatar
Wait a minute....there are about 8 million temperature sensing computer products designed for monitoring case temp, processor temp, RAM temp, disk temp, mouse temp, keyboard temp, porn site temp, etc etc etc....
One of those kind of things has to able to be converted easily and cheaply into an ambiant outside air temperature sensor.
Skipjacks is offline   Reply With Quote
Old 01-22-2005, 06:22 PM   #6
RoadRunner Mastermind
guino's Avatar
Heck, I just use a 4 sensor serial circuit that requires no external power and no calibration (US$30), it is fully incorporated into my remake of Media Car... check out:
http://guino.home.insightbb.com
(there are links for the information and ordering locations on the links page)
guino is offline   Reply With Quote
Old 01-22-2005, 08:35 PM   #7
This looks like the way to go. You basicaly get as many sensors as you want and it uses the SMbus (I2C) connector on the epia boards. One IC and you have 4 remote temp sensors 2 ICs 8 etc and the actual temperature sensor is a simple el-cheapo transistor. Best of all you don't use up a serial port.
momanz is offline   Reply With Quote
Old 01-22-2005, 09:33 PM   #8
SWC
Quote: Originally Posted by egeekial
Phidgets are great but their temp sensor seems a lot bigger than most of the other around.
SWC is offline   Reply With Quote
Old 01-22-2005, 09:37 PM   #9
guino's Avatar
That's awesome! although, with all my clumsiness and luck I'd probably fry my MB trying to get it in place.
Old 01-22-2005, 10:43 PM   #10
Actually most mobo's have a 5 or 6 pin header that you connect a cable to. That way you can build the circuit on a breadboard plug in and go. Now if you don't have an SMbus/I2C connector you will need to solder a connection to your motherboard. I'm thinking that the most difficult thing here will be soldering the leads to the chip, it's tiny.
I'm waiting on parts to try this out. I'll post the results when I'm done.
Old 01-25-2005, 12:28 PM   #11
CNDaccent's Avatar
Thumbs up single line multiple temp sensors
IMHO: I2C single line temp sensors are the way to go. I've worked on different projects (I'm an EET) and these are pretty simmple to use. Each sensor gets programmed with an address so they can all use the same data I\O line. 3-pins 3-wires and you can connect a bunch.
Dallas semi makes a decent one (DS18B20) with a 64-bit ID code, in case you need that many
look at all the magic smoke...
Small Amp, Big Car
8" LCD
PC and assorted parts
CNDaccent is offline   Reply With Quote
Old 01-31-2005, 08:19 AM   #12
Any help on interfacing them (ds18B20's and ds1822P's) to a parellel port, game port, or serial port? Parellel would be prefered by me as what else am I going to use that port for (a printer...NO!). Second would be game port then serial (I already used my two up). I do have a usb to serial adapter but I'm trying not to use it because if I do then I'm going to need to buy a usb hub
hcker2000 is offline   Reply With Quote
Old 02-03-2005, 04:42 PM   #13
DeltaFX's Avatar
There 's a solution with a 1-wire-USB interface too. And 1-wire can be used for other sensors than temp. But it's in French
http://deltafx.free.fr/f02a016.pdf
DeltaFX is offline   Reply With Quote
Old 02-04-2005, 01:23 AM   #14
starfox's Avatar
Also this one that uses an AT90S2313 and talks to an ADC and temp sensor via Microwire.
http://mcselec.com/an_104.htm
I'm gonna try build it and write a serial port interface for it in the next few weeks..
starfox is offline   Reply With Quote
Old 02-04-2005, 10:59 AM   #15
Raw Wave
rando's Avatar
As long as they are strictly SMBus you should be all set with the onboard SMBus (not I2C) connector on the EPIA boards. There doesn't appear to be a way to issue I2C commands on it.
2004 4runner
rando is offline   Reply With Quote
Monitoring outside temperature Tha Hombre General MP3Car Discussion 8 01-25-2006 10:22 AM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
LCD temperature range jplev22 LCD/Display 5 04-14-2004 10:19 PM
Pc in the car and low autside temperature. ( winter time ) Goose General Hardware Discussion 3 12-25-2002 11:28 AM
Need help finding idle and temp sensors wizardPC Off Topic 0 05-07-2002 12:40 AM
