11-18-2005, 12:15 PM
#151
Quote: Originally Posted by IntellaWorks
seems people didnt notice it the first time
11-22-2005, 11:59 AM
#152
i-hacked doesn't appear to offer the cable anymore (their "cart" feature on the website doesn't work). Is there anywhere else I can buy one of these already made and working?
11-22-2005, 03:32 PM
#153
Raw Wave
BoyNextDoor might have one.. pm him..
12-09-2005, 10:59 AM
#154
hey guys,
the version of the xmd1000 on the first page has the grey logo on top. the ones for sale here have a yellow logo but same model #. is there any difference in the 2 units? can i still do this cable hack?
thanks,
chris
2004 Ford Mustang Mach 1
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
12-09-2005, 10:55 PM
#155
No difference - just picked one up a few days ago, got a cable from WebDog, and it works like a champ.
12-11-2005, 12:01 PM
#156
awesome, thanks for the reply! i'll finally have radio again
My XM FAQ
12-11-2005, 05:57 PM
#157
Well, He asked for it.
Glad your happy with it!
2005 VW GTI MKIV - SOLD
12-22-2005, 10:38 AM
#158
I bought two of these cables from Webdog and they work perfectly.
I am using frodo's standalone XM app, this is my first install with XM and it rocks.
Kudos to everyone here for the info
12-30-2005, 02:26 PM
#159
Thanks to everyone for some great info. A couple points I would like to add which may be confusing to the noobies.
1. Even if the cable you are using to hack has the same colors, orange, blue, brown, yellow etc. It doesn't mean that those cables match up to the proper pins on the connector you are leaving on the cable. You must test which wires correspond to which pins - easiest to do with a MM and a continuity test. Simply set your mm to measure continuity and put one probe to a wire color and then probe all the pins on the connecter to find out which pin corresponds with that color.
2. I didn't see it mentioned here, forgive me if I missed it, but there is another connection you need to make after the din/serial cable. That connection is audio. An RCA to mini-stereo adapter will work fine to plug in the XMD to your soundcard.
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
12-30-2005, 05:47 PM
#160
Alright, I'll ask this question. I made my cable about a month ago, and it powers up fine and what not, but I can't get it to work with Frodoplayer or frodoxm (cept the little program you put in your startup) and I finally got it to work with RR. Now, it plays the stations just fine, except It will never tell me the current song or artist or any of that info. How do I get that to work?
01-01-2006, 09:25 AM
#161
After buildling a cable; has anyone noticed that the apps (any) to control the unit randomly cut off song titles and artist names? (I'm trying to figure out if this is normal behavior or if there's something wrong with the cable)
01-01-2006, 10:03 AM
#162
MySQL Error
if you don't have the cable properly grounded or shielded it will cause problems like that.
01-01-2006, 10:52 AM
#163
I suspected as much...I planned to rebuild the cable once I get a decent soldering iron anyway since I made a mess of the cable and didn't have anywhere to connect the shield ground (The shroud is plastic??)
The cutoffs seem somewhat too predictable though...for example, Red Hot Chili Peppers is always 'Red Hot Chili Pe' regardless of the application used; and yes...the colums are expanded far enough to read the entire name.
Fortunately I have an 8' cable with plenty of room to cut off the mess and try again with the proper tools
01-01-2006, 11:08 AM
#164
MySQL Error
yeah but I dont think i've ever had any name cutoff at all
as long as you tie the shield of the DB9 to the shield of the cable it should help, you dont really have to connect both ends of the shield.
01-01-2006, 05:18 PM
#165
I stumbled across this thread this morning with no intention of installing XM in my car, but after I read the install guide I decided to go down to Fry's and pick up the unit for $49 with a $30 dollar rebate and the cable was $7.99 and I had the rest of the stuff. XM is having a special with no activation fee so it was just the $12.95 for my first month's service and $30 worth of parts.
Thank you so much for an amazing write up because everything works as advertised through RR. It is great to have radio again!!!!!
| Thread Tools |
| Display Modes |
Linear Mode
