01-03-2006, 04:43 PM
#166
awsome! i just went and bought my terk at circuitcity, however i was too late for the gift card deal that circuit city was having when purchasing this reveiver. anyway, i gotta work on doing the hacked cable (hoping i can make a usb one since my lcd touchscreen takes up the serial - yes i'm using an older gain/xenarc lcd.. pre usb touchscreen interface).
01-04-2006, 12:03 PM
#167
Quote: Originally Posted by jcdillin
yeah but I dont think i've ever had any name cutoff at all
as long as you tie the shield of the DB9 to the shield of the cable it should help, you dont really have to connect both ends of the shield.
I've redone the cable three times already--this time with a better iron for more precision. Soldered the shield wire to the side of the DB9. Same result...channel info is getting truncated. Not sure what else I can do at this point.
01-04-2006, 01:30 PM
#168
Just buy one from WebDog! Mine works great, no issues. Highly recommended.
01-04-2006, 01:59 PM
#169
I will if I need one, but I don't see the need to randomly buy parts before understanding what is wrong. As far as I can tell the cable itself checks out perfectly fine on continuity tests. I've gone so far as to test DB9 -> PCB and that seems to check out as well with the exception of DB9 Pin 5 (Ground) Not exactly sure what I should be seeing with that but I get readings on several pins on the PCB.
Does anyone still have Frodo's XMDebug app? I wanted to give that a try but can't find it.
EDIT:
I suppose this is more of an XM annoyance than a problem. I've read track info is cut off at 16 chars--which is exactly what I've been experiencing. Rather annoying, but I guess there's nothing to be done about it.
02-01-2006, 11:26 AM
#170
In regards to the Names getting cut off. I've seen this happen first hand in cars that have XM built in, mainly the Acura TL. So I dont think its your wiring, might be an issue XM is having or the channel ?
02-03-2006, 05:23 PM
#171
I found this if anyone is interested. Its only $1.49 + $4 shipping.
Click Here
Then search for DB9M-Idc10
02-06-2006, 03:02 PM
#172
ANyone else on here sell the cable for XM direct to PC? I guess I could make one, but been busy. emailed webdog, but no response. Thanks
02-06-2006, 04:17 PM
#173
If you can not find one I will build one for you. It is very simple and mine works great. If you need me to build one for you PM me and we can discuss it.
02-06-2006, 04:25 PM
#174
There was a fellow in the for sale forum with a few of them for sale.
Stop Buying New Music CD's.
Hit The RIAA where it lives.
Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
02-06-2006, 04:57 PM
#175
That's me. $15 shipped, just let PM me.
02-06-2006, 05:25 PM
#176
Yea I just paid 25.00 shipped on ebay.
02-06-2006, 05:59 PM
#177
Well, He asked for it.
Hey just PM'ed you... I was off the forums for a week or so...
2005 VW GTI MKIV - SOLD
02-13-2006, 01:57 AM
#178
aight this might be a very noobish thing, but i just gotta ask... after reading these 12 pages i am dam confused on xm... so question being, are there any simpler ways to get xm radio on ur carputer? something like plug and play maby?? something that hooks up to a serial or usb without any kinda hacking? or am i dreaming?
02-13-2006, 08:09 AM
#179
XM PCR are still available on eBay and work just fine out of the box. You may want to upgrade them to optical output for cleaner reception or not, thats up to you. The XMdirect is what Im switching to so I can use mobile impact as well as Road Runner. I just can't make up my mind which I like better. RR is so cool with lots of added features and Mobile Impact is very fast so....I don't know which I prefer. The simplest way to get XM by far is to stick with a head unit that supports an XM tuner upgrade. Alpine makes an indash radio with an XM tuner built in but if it breaks, your out your entire sound system. And as far as I know, you won't be able to control it from your CarPC, It's all in how you want to handle it.
Take care,
Peter
want
02-13-2006, 12:00 PM
#180
Quote: Originally Posted by Prindle19
Prindle19
are both of those lil wires positive? or does the yellow one go to a 12v and the black one to a ground?
| Thread Tools |
| Display Modes |
Linear Mode
