02-13-2006, 12:13 PM
#181
Quote: Originally Posted by djurchicprelude
are both of those lil wires positive? or does the yellow one go to a 12v and the black one to a ground?
Yellow to 12v, Black to Ground
1999 Pontiac Sunfire
New CarPC on it's way! Check out my worklog for details ;)
02-18-2006, 06:40 PM
#182
Can anyone help me find a link to TouchXM? all of the links here on the forums seem to be dead ends. I have tried over and over to get Frodoplayer to work but I always get an error before the program starts stating that
"MSCOMCTL.OCX or one of its dependencies is not correctly registered...blah blah....."
I just wanted to see what I have wrong and I really would like to try TouchXM
02-18-2006, 11:57 PM
#183
Have you tried registering the file manually? regsvr32 (filename)will do it for you if the file exists. You may have to type in the entire path to the file. I have a copy of another XM program if you send me an email address that can handle about two mb, Ill send it to you. I dont have a copy of touch XM. Which XM device are you using?
Peter
Stop Buying New Music CD's.
Hit The RIAA where it lives.
Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
02-19-2006, 04:49 AM
#184
I am using the TERK XMD1000 and a home made cable. I actually got the unit functioning, and I am using a variety of different programs for access and control, S.R.C., and I just started using one called Mobile Impact (MI) but I am up to try whatever. I want to get frodo player to work, I can get it to open now but unfortunately, I still cant seem to get it to talk with the receiver. I like the look of Frodo, and I would Really like to find TouchXM, but like I said I would like to try a few programs see what I am up against for the total system.
03-07-2006, 10:19 PM
#185
Thank You For This Thread!!!!!!
This thread is a lifesaver!! I just picked up a Terk XMD module on eBay for $31 with a $30 rebate and the parts to make a cable for about $12. 30 minutes later and I have XM in RR!
I figured this would take me a few tries to get the cable right, but managed to get it right on the first shot. I opted not to go the solder route and instead went with the crimp connectors from rat shack (276-1428). Crimping is much easier than soldering when working with those thin wires IMO. Not sure if it helps, but I used a shielded hood as well (276-1513).
One thing I discovered is half of my cable matched the color pinout and the other half was a mirror image. The cable must cross the signals from one end to the other. At any rate, the other half of the cable worked out to be:
1: Red
2: Brown
3: Green
4: Yellow
5: Orange
6: Black
7: Purple
8: Blue
For what it's worth...
Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
03-07-2006, 10:21 PM
#186
If anyone is interested in a cable, I have an extra one made up. $20 shipped.
03-12-2006, 02:44 PM
#187
The Mini Din 8 connector -- is that the same connector that is on the end of PS/2 style mouse cable? If not, has anyone found the proper connector at Best Buy or radio shack? I've been looking and haven't seen anything that looked correct.
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
03-12-2006, 02:46 PM
#188
Apple serial printer cable at Fry's
03-12-2006, 02:59 PM
#189
We don't have a Frys in Minnesota. I may be able to locate an apple serial printer cable though. I don't think Best Buy or rat shack has them but Compusa might. I'll have to do some more looking. I was hoping to find stuff locally today so that I could get to work on it.
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
03-12-2006, 03:21 PM
#190
MySQL Error
yeah it has to be a mac printer cable, no store has the din connector, besides digikey or mouser
03-12-2006, 04:06 PM
#191
I tried OfficeMax, Office Depot, Circuit City, Best Buy, Radio Shack, etc. and none had it. Ended up buying it on eBay for about $7 shipped. I can PM you the guy I bought from.
03-12-2006, 09:22 PM
#192
http://www.circuitcity.com/ssm/Terk-...oductDetail.do
I used something similar to that, got it from circuit city. It was basically just a big long cable with the correct style plug on one end and the brand name headunits interface on the other.
Not sure if thats the exact one I used but check your local bestbuy or circuit city. Should be around 10 bucks.
03-12-2006, 10:55 PM
#193
Thanks guys. I found an Apple PC store and bought the serial printer cable.
I bought a Terk XMD1000 and installed it and I have everything working under Road Runner. Its pretty slick!
The only problem I have now is that the Terk XM radio introduced noise. I'm getting a rythmic noise that cycles up and down. Its kind of a white noise with an underlying tone of some kind. This is with the engine turned off. Its not alternator noise.
I assume serial cable is shielded and I did solder the braided ground wire to the outside of the DB9 connector. So I have a good ground on the cable. I also have a shielded shroud around the DB9. The two power wires, which are powered from my M2-ATX power supply, are plain 18 guage wires (no shielding)
The RCA cable I bought looks like a pretty cheap cable. Its a 6 foot Y adapter cable that goes from two RCA females to the 1/8 inch jack -- which plugs into the line-in on my PC. I'm guessing I may need to replace it with a shielded cable.
I have no idea whats causing the noise in the system, though. Has anyone else run into this problem. You guys agree that it may be the RCA cable?
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
03-12-2006, 11:10 PM
#194
i just ordered the solder cup mini-din connector from mycableshop.ca (.com for the US folks, dunno about overseas) http://www.mycableshop.com/sku/C8DSM.htm and then got a Female DB9 connector, and I forget the cable that I used, but it worked out really well.
03-13-2006, 08:29 AM
#195
Hey I had the same issue, the noise is caused by either a poor cable terk xm or rca. I did the lazy thing and just bought a simple noise filter and put it between the rca from the terk and the 1/8inch jack for the computer, works fine now. Try unplugging the 1/8 from the cpu and see if you still have the noise.
| Thread Tools |
| Display Modes |
Linear Mode
