05-31-2005, 08:08 PM
#46
yeah I saw that thread and pin 10 on both my XM units have 0 voltage... the unit is not turning on. but wont it only turn on if it gets a proper signal from the computer telling it to turn on? Also frodos app isn't available anymore...
05-31-2005, 08:10 PM
#47
MySQL Error
Vehicle: 2002 Dodge Ram 1500 Quad Cab
post 95
the xmdirect will turn on if both pins 6 and 7 are shorted and fed 12v and you send it the magic bytes
05-31-2005, 08:12 PM
#48
MySQL Error
also who did you get the cable from?
05-31-2005, 08:17 PM
#49
ok I am getting S's AND R's!!! but not any channels??? I'm sure frodos app is sending the magix bytes right??
05-31-2005, 08:19 PM
#50
MySQL Error
well are you running direct serial or through a USB to serial adapter?
if you are seeing S and R that means your cable is wired correctly and your XMD is running
you might just have a cable shielding problem
you need to make sure that the shield is grounded at both ends
05-31-2005, 08:21 PM
#51
through serial.... the cable shielding?
05-31-2005, 08:22 PM
#52
MySQL Error
also keep in mind that it will have trouble bringing up channel list if it doesnt have a good sat signal level, it wont work if you just have ground repeater signal. I have even had to activate some to get the channels to come up
05-31-2005, 08:25 PM
#53
well wouldnt the app at least recognize the XM direct unit? none of them are even finding it... also wasnt there an app that sent the magic bytes?
05-31-2005, 08:27 PM
#54
MySQL Error
you just tried it
the programs are not going to recognize it persay, they are just going to bring back the channel list if they can
if the XMD is getting good signal and is activated the test program will bring back a channel list
05-31-2005, 08:35 PM
#55
MySQL Error
the other thing you might try is make sure that in the device manager that windows didnt find the XMD as a serial mouse
05-31-2005, 08:41 PM
#56
SON OF A!!!! well if only that damned debug app was online last week!!! The app all work ONCE that debug app is run...
05-31-2005, 08:42 PM
#57
damn... well I have a perfectly brand new XM Direct unit for sale... god damn it... now my old one that I soldered the toslink too works...
05-31-2005, 08:46 PM
#58
MySQL Error
well good you got it working
05-31-2005, 08:50 PM
#59
Raw Wave
Vehicle: 1987 Mercedes 190E 2.3 Automatic. Not so much fun... eh
i'm happy my cable worked out for you!
06-05-2005, 12:12 AM
#60
I ordered a cable a few weeks ago, and ran into the shorting problem that other people are seeing. When I checked the cable, it seems like it was wired up in a "mirror image" compared to the diagram on the first page.
Are the pins on the DIN numbered as if you are looking at the front of the plug, or from behind?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
