Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 07-01-2005, 10:18 AM   #91
tbird2340's Avatar
Wow!! I just looked at mouser and that thing is $57!!
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 07-01-2005, 10:24 AM   #92
Raw Wave
tj!2k4's Avatar
Quote: Originally Posted by tbird2340
Where can this be purchased? B&M or online only?
I bought mine online, but I'm sure I'm sure it can be purchased in a B&M store. I'd try calling some electrical supply places if you really want to pick it up in person, otherwise I'd froogle it.
I forgot to mention another plus, which is, that it heats up very quickly (perhaps 15-20 seconds, if even that long).
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 07-01-2005, 10:43 AM   #93
Great post! Thanks
Auram is offline   Reply With Quote
Old 07-01-2005, 10:45 PM   #94
tbird2340's Avatar
Can someone please tell me if I got the wrong freaking cable... I bought this one here and I want to hook it straight to my EPIA M10000 motherboard. I'm not sure if this is the V1 or the V2. Please someone let me know because I already got it all soldered together and now I'm thinking it's the wrong one.
Man, I hope not
Old 07-01-2005, 10:54 PM   #95
tbird2340's Avatar
Ok... According to the pinout directions:
Cable Pinout
8 pin mini-diin to db9
pin 1 = pin 3 Data Receive
pin 2 = pin 2 Data Transmit
pin 3 = pin 5 Ground
pin 6 = 12v
pin 7 = 12v
pin 8 = gnd
And this picture:
I don't think the pinouts above is correct is it? The Epia manual says that Pin 3 is "Send out or Transmit Data" but the pinout directions have:
And then the Epia manual says that pin 2 = "Serial In or Receive Data" but the pinout directions have:
So what I'm asking is this... If I'm hooking it directly to my motherboard via riser cable shouldn't it be as follows:
pin 1 = pin 2 Data Receive
pin 2 = pin 3 Data Transmit
Old 07-01-2005, 11:01 PM   #96
kamikaze2112's Avatar
I'm no expert, but i think what they mean is that the tx from the XM goes to the rx on the mobo and the rx from the XM goes to the tx on the board.. what you are desribing sounds like tx -> tx and rx -> rx which won't work......at least that's how i read that lol
kamikaze2112 is offline   Reply With Quote
Old 07-02-2005, 06:39 AM   #97
MySQL Error
jcdillin's Avatar
yes it's not going to match up in that situation because when I made the directions I was using them with a db9 serial connector
so you would be correct
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 07-02-2005, 07:12 AM   #98
tbird2340's Avatar
Well I got conflicting replies... So is it supposed to match up?
XM TX to MB TX
XM RX to MB RX
or
XM TX to MB RX
XM RX to MB TX
Old 07-02-2005, 08:35 AM   #99
MySQL Error
jcdillin's Avatar
sorry
should be XM TX to MB RX
XM RX to MB TX
肚子笑痛了
S60 Install
Old 07-02-2005, 09:35 AM   #100
tbird2340's Avatar
Ok, have a couple questions. I have this all hooked up in my truck. Am I supposed to use the included app (Take 3 FP > Menu > XM Radio) or the FrodoSatelliteRadioXAlpha3.exe?
Either way I'm not getting nothing. With the first option I just get the screen but no bars or anything.
With the alpha program I just get a solid blue screen (not locked up, just that prog is solid blue).
I changed the ini file to point to com2.
The link to that XMTest program isn't valid.
Any ideas?
My cable is getting 12V's so I know it's getting good power / ground.
Old 07-02-2005, 09:40 AM   #101
tbird2340's Avatar
UPDATE
I'm now getting channels to show up. Still have a quesiton.
Which program am I supposed to use? Thanks
Old 07-02-2005, 10:03 AM   #102
MySQL Error
jcdillin's Avatar
well i'm looking for the xmdebug program right now, because thats the best way to make sure you are getting the correct signals
if the screen is blue on the frodo XM application that means that the skin path is wrong in the ini file
but you should be able to use either one
on a side note, does this thread look screwed up to anyone else, it's squashed for some reason
肚子笑痛了
S60 Install
Old 07-02-2005, 10:04 AM   #103
MySQL Error
jcdillin's Avatar
lol, too slow
you can use either program
the frodo radio application is faster as far as getting channels and starting up, but I like the built-in player because it doesnt have as many preformance issues. ie the frodo radio application has a bad habit of locking up sometimes and you have to reboot the machine
肚子笑痛了
S60 Install
Old 08-12-2005, 11:50 PM   #104
MoFo's Avatar
My XMPCR stopped working so I'm going to have to give this a shot.
I just got one of these cables and I'm going to get a XM direct. I noticed this cable has a molex cable and needs to get 12v from a ATX style power supply.
The only thing is...I'm hooking it up to a laptop. I dont have a power supply giving me a 12v power connector.
Whats to best way to hook up a XM direct to my laptop using the cable discussed in this thread?
by the way, my laptop is powered by an inverter.
MoFo is offline   Reply With Quote
Old 08-14-2005, 09:30 AM   #105
tbird2340's Avatar
You could just tap into your head units 12V..
carputer install: I dare you... Cat Monkey General MP3Car Discussion 42 01-27-2005 05:34 PM
XM Direct digital adapter or XM PC cable with SkyFi2??? LATEOTT Hardware Development 0 01-19-2005 02:18 PM
Using an XM direct as an XMPCR dacndar General Hardware Discussion 20 10-17-2004 01:21 AM
XM Sirrius for carputer? withoutcomp1 Newbie 1 05-01-2004 09:04 PM
XM Sat Radio for your carputer jzgt General Hardware Discussion 73 12-20-2003 12:51 AM
