Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 01-31-2005, 01:15 PM   #1
strohmrs's Avatar
Auto select video input for Lilliput?
I searched but did not see anything on this topic. Has anyone modified a Lilliput to act like a Xenarc as far as having the display auto switch to one of the Video inputs when a signal is detected?
I would like to have the input switch to one of the RCA inputs when it detects an active signal there or have some other signal (5V, 12V, ect.) do the switching for a rear view camera when in reverse and switch back to VGA when not in reverse. The only problem I see is the the video select goes from VGA, VID1, VID2 and back to VGA with each push of the button. Anyone know if each mode can be selected independantly by bypassing the front panel board and going directly to a pin on one of the chips on the main video controller?
I've got a couple of other projects going on now and don't have time to research this myself yet. Still need to get a camera as well! If I don't hear of anyone else that has already accomplished something like this, then I will attempt to design a mod that can be posted here. A schematic would be nice!
Thanks,
Rick
Rick S.
XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
strohmrs is offline   Reply With Quote
Old 01-31-2005, 01:17 PM   #2
dodgetimes2's Avatar
It's been discussed before, search for the words "Cheese Box" of "Cheesebox".
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline   Reply With Quote
Old 01-31-2005, 01:50 PM   #3
strohmrs's Avatar
Thanks. Looks like it would work. Expensive though at $75. Would also add more external bulk to the setup and requires a 9v power adapter. I'd rather use my existing inputs to reduce the cost. Hope datasheets are available for some of those chips on the controller. Time to open up the display again and check.
Rick S.
Old 01-31-2005, 05:28 PM   #4
techy101's Avatar
Make sure you find one of the origional Cheese Box's. The new one (it's green, doesn't look like a block of cheese or nething) is a PAIN to set up to switch. It's got 24 solder points on two seperate switches inside the box. Even though there is only one switch on the outside. The old one as far as i have read only has a real simple switching system.
Outside the dawn is breaking on the stage that holds our final destiny...
Dual In-Dash Screen Carputer Installed Check It Out.
techy101 is offline   Reply With Quote
Old 02-14-2005, 04:17 PM   #5
Clover
Grayscale's Avatar
http://www.freewebs.com/billymcbunter/
Also, look for the auto-reverse camera thread, its got more info on this stuff.
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 02-14-2005, 04:57 PM   #6
strohmrs's Avatar
Thanks Grayscale, I saw his thread in the forums here on that already. Trying to aviod the multiple button press method he's using but I might not have any other choice since I haven't been able to decode the controller chip inputs yet.
Rick S.
Old 02-14-2005, 05:49 PM   #7
Clover
Grayscale's Avatar
I think thats the only route man. I think if you do it fast enough its not noticible
Old 02-14-2005, 08:22 PM   #8
strohmrs's Avatar
Probably is the only way but I can never do it quick enough. I end up pressing it 3 or 4 times but it will only respond to key presses about once per second. It has to switch to the new mode, display VID2 or whatever, then it will allow another key press.
Rick S.
Old 02-15-2005, 03:39 PM   #9
Clover
Grayscale's Avatar
Should have gotten a Xenarc JK, I love my lilliput!
Old 02-15-2005, 11:02 PM   #10
strohmrs's Avatar
Know what you mean. Just more proof that being cheap isn't always the cheapest route! It wasn't until after I got the Lilliput that I learned that the Xenarc had that feature built-in. And yeah, I still like my Lilliput as well. Only real complaint is daylight readability but I think they all pretty much suck equally at that. Hurry up with those OLED screens already!!!
Rick S.
Old 02-17-2005, 02:26 PM   #11
a few months back I picked up a cheesebox for $40 delivered... ebay baby...
mgithens is offline   Reply With Quote
Old 02-17-2005, 03:12 PM   #12
Raw Wave
rando's Avatar
IIRC, the last time I took a look at this, the monitor controller chip (NT68320) and video decoder (SAA7114H) both recieve commands over I2C from the MCU (SM89516a) in the Lilliput. You should be able to tap into that bus and command the decoder yourself. This might confuse the programming in the MCU though -- dunno for sure. The decoder and MCU data sheets are easily found on-line. I only found overview information on the monitor controller chip from www.lcdtv.cc.
2004 4runner
rando is offline   Reply With Quote
Old 02-17-2005, 06:18 PM   #13
Clover
Grayscale's Avatar
rando, you're a hardware genius! are you an electrical engineer? thanks for all of the wonderful information about PICs, i greatly respect you for taking the time to write all that out. yesterday that glitchbusters site was down, but today i ordered a bunch of stuff on there, and am gonna start tinkering
i'm gonna go research these chips now
EDIT: It seems possible, but very difficult to reverse engineer this...we need smarter people like rando in here
Old 04-17-2005, 02:36 AM   #14
Raw Wave
rando's Avatar
Anyone make any progress on this?
2004 4runner
Old 04-21-2005, 02:13 AM   #15
Jesus Freak
antimatter's Avatar
yea... now i am interested. Any one have any other information
antimatter is offline   Reply With Quote
need help with lilliput RCA video input CDesigns LCD/Display 9 04-04-2007 07:33 PM
Need a lcd with s-video or rca video input!!! Need to send signal from my laptop!!! bankingdom LCD/Display 3 01-28-2005 04:32 PM
Weird problems with video and ME 2.1 Rireal Media Engine 4 02-20-2004 07:33 PM
My older project looking for USER INPUT!!! Please SoloCon Show off your project 24 10-22-2003 03:27 AM
Laptop video input. Any experience, ideas? carabuser Input Devices 2 10-09-2003 12:56 AM
