Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 02-08-2005, 10:01 PM   #31
MySQL Error
jcdillin's Avatar
I should be getting mine tomorrow or the next day, so I will start a thread with some pictures of the install progress, even though there really isnt much to it.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 02-08-2005, 10:17 PM   #32
jcdillin, i'l just warn you ahead of time. The quarter on the picture next to the garmin receiver in their documentation doesn't do any good. I was in shock when i opened up the package to see how really small it is. Same goes for the wires, there really small and tedious to work with, but not impossible. other then that, glad to see that your going to use it, really good receiver that i'm sure you'll praise.
DaRacerz is offline   Reply With Quote
Old 02-08-2005, 11:58 PM   #33
Quote: Originally Posted by IntellaWorks
I'd definatly love to see a OEM gps install thread, it's importance can have a great value to our comminity.
I agree,
How about making a sub forum in the GPS forums called "OEM GPS INSTALLS"
Intella - will the antenna work if its inside the car,for example i have the earthmate on my rear deck in the car
My next concern is powering this thing,Im using a c134 case with the 60w mortex PS that came with it, connected to a carnetix, can i get the 3.3v from my PS
camsgs3 is offline   Reply With Quote
Old 02-09-2005, 08:58 AM   #34
IntellaWorks's Avatar
Quote: Originally Posted by camsgs3
I agree,
1- Intella - will the antenna work if its inside the car,for example i have the earthmate on my rear deck in the car
2- My next concern is powering this thing,Im using a c134 case with the 60w mortex PS that came with it, connected to a carnetix, can i get the 3.3v from my PS
1- The antenna would work inside your car, but as with any gps reciever you are limiting its ability to recieve a satellite lock. GPS signals are just like light comming from a flashlight. Say each satellite is a flashlight trying to shine down on your car... Think of objects in your car that would reflect light or not let light shine through for example the roof of your car... Optimally you should have 180 degrees of free space above your GPS antenna to recieve these signals.
2- Ok, to power these modules should be pretty easy. If your thinking about getting the GARMIN 15L then it can handle anywhere from 3.3v-5v of power. So on my system board, there is an IRDA internal connection that had 3.3v and a ground I just connected my wire harness to this. You can find and tap into a 3.3v from your atx power supply OR look for places on the system board that has 3.3v or 5. Another place you could try is your floppy connector... thats 5v or even an internal USB that is also 5.5v...
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 02-09-2005, 09:08 AM   #35
MySQL Error
jcdillin's Avatar
Thanks for the heads up, I do alot of prototyping with SMD so shouldnt be a problem.
肚子笑痛了
S60 Install
Old 02-09-2005, 09:55 AM   #36
Raw Wave
edrex's Avatar
Quick question for you guys: Did you need to drill a hole in your roof to get the reciever on the outside of the car? Can these be placed outside with no drilling?
Thanks.
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
edrex is offline   Reply With Quote
Old 02-09-2005, 10:05 AM   #37
MySQL Error
jcdillin's Avatar
mine is going right next to my xmdirect antenna, which the wire just runs from my trunk around the back window gasket and onto the roof, I didnt have to drill any holes
You just have to make sure the antenna you get is actually mag mount and not through hole or something.
肚子笑痛了
S60 Install
Old 02-09-2005, 02:22 PM   #38
Creoden's Avatar
I am getting an AntennaPlus GPS/800mhz antenna for my roof once I get this device, but you could always put it on the trunk of your car, and run the wire to the back of the trunk and inside to the trunk, then you can route the cable anywhere you need to in your car.
This posting is provided "AS IS" with no warranties, and confers no rights.
Creoden is offline   Reply With Quote
Old 02-09-2005, 07:56 PM   #39
Thanks.
The GPS antenna, comes with a very powerful magnet, the antenna weighs les than a quarter so the magnet works excellant.
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 02-10-2005, 10:33 AM   #40
MySQL Error
jcdillin's Avatar
woot! mine is out for delivery!
肚子笑痛了
S60 Install
Old 02-10-2005, 09:07 PM   #41
MySQL Error
jcdillin's Avatar
A question for the ones that have used this module, I got my unit today. I noticed that the output voltage is 3.3v for the antenna. my antenna is 5v. the datasheet claims I can put 5v into the RF bias pin to power the antenna. I just want to verify this before I blow my new unit out
肚子笑痛了
S60 Install
Old 02-11-2005, 05:18 PM   #42
I'm not to sure.. youd have to check the specs out for the antenna to see what it can handle.
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 02-11-2005, 05:21 PM   #43
MySQL Error
jcdillin's Avatar
yeah I called tech support and it's correct, for my 5v antenna I just apply 5 volts to the RF bias pin so it will give the antenna the needed voltage
肚子笑痛了
S60 Install
Old 02-11-2005, 05:22 PM   #44
ok cool, lemme know how it works out for you... how it works.. and everything..
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 02-11-2005, 05:39 PM   #45
well, you guys just help me starting with my Dead Reckoning GPS project. I understand a little bit more on GPS for me to go to this route.
Now I know MCX is an antenna connector.
Serial connectors can be connect directly to the serial header on the board, and power from RF pin.
So, I guess I'm gonna fork over my cash and buy the U-Blox GPS receiver w/DR very soon.
This is the datasheet for the 20 pin connectors.. Can someone translate to non techincal english for me?
nl4jy is offline   Reply With Quote
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
a new way of GPS brownpage GPS 8 08-24-2004 03:51 PM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 06:08 PM
USB DVD + Radio Tuner + OEM GPS gguy General Hardware Discussion 4 02-13-2001 12:43 PM
