Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 02-15-2005, 11:04 AM   #61
@hklomann: Thanks for the diagram. Sure does make it a lot clearer. I plan on purchasing it in the near future then.
From what I read the direction sensor (pin 7) is optional. Is that correct? I'm wondering where would that pin be connected to.
EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
edikp is offline   Reply With Quote
Old 02-15-2005, 11:46 AM   #62
After reading further: seems like the direction input takes only a 1 or 0 input. For instance: 1 for forward and 0 for backward, or vice versa. Could anybody verify this?
Old 02-15-2005, 12:48 PM   #63
if that's the case.. maybe we can wire it to the reverse. Then it knows when we're going backward. Really, someone needs to verify this.. only $230 more to go and I will have one of these puppy.
nl4jy is offline   Reply With Quote
Old 02-15-2005, 01:33 PM   #64
hklomann's Avatar
why donīt you download the datasheet
i paid 229euros incl active antenna and gyro + 54 euros tax
actualy i am looking for env-05g datasheet cause there is no socket on board
so we might find someone to do a lil pcb layout for the max 232 serial (i would like to put an rs232to usb here to power the system)linedrivers the backup batterie and the gyro and the reverse input and the speedpulse
everything is possible
home is where your heart is
hklomann is offline   Reply With Quote
Old 02-15-2005, 02:14 PM   #65
I did download the datasheet.. If you look at the bottom of page four, you'll see the datasheet that I posted... Only problem is... I am not an electrician.. I have no idea what all these things means. So my best bet is to following a smart one, and you my sir... is my smart one.
Yay, just found $10 in my car... only $220 more to go.
Old 02-15-2005, 02:38 PM   #66
hklomann's Avatar
hell was not easy to find the gyros pinout the matching murata pages were all japanese
to the point of my profession i am computer proffesional and i know that overvoltage can be bad to your health that all i know about electronics but i am very experienced in finding information and the people to help me out with their profession
Old 02-16-2005, 05:35 PM   #67
fredda's Avatar
The Garmin 15L fits really great inside my Travla C137, thanks for the info about it...
System: MII12000, TRAVLA C137 (Opus 150 inside), 512DDR, 60GB 2,5"HD, 3COM WIRELESS 54MBS USB, HAUPPAUGE WIN/TV NICAM RADIO.....
fredda is offline   Reply With Quote
Old 02-16-2005, 05:59 PM   #68
Raw Wave
rando's Avatar
Hooking up a max232 is not going to be a problem. There are even versions of the chip that don't require external capacitors -- a single chip solution.
2004 4runner
rando is offline   Reply With Quote
Old 02-17-2005, 01:21 PM   #69
IntellaWorks's Avatar
irratic mouse movements, OEM GPS
Well, a little update for everyone who is thinking about Garmin 15l mods. Windows might think that its a serial trackball mouse, which will cause the mouse to move irratically across the screen.
I first installed the GPS mod on a version of nLited windows and I was able to recieve a signal. I since then changed my windows confguration and re-nLited it (for those of you who don't know what nLite is it basically chops useless stuff from windows making it smaller and run less bloated)
ANyhow, one my re-installs the GPS mod was causing my mouse to go nuts, even during setup rendering the machine useless. At first I thought it was an IRQ conflict, but after troubleshooting for hours started thinking of other causes.
DUring this trouble shooting process I figured out that the Garmin has an internal power source which can last up to 21 days so even if you unplug its power it will still send a signal to your system. THat being said and you run into the same problem unplus the input cable instead of the power cable.
Now, be-fuddled as to how to correct this problem I decided to call Garmin... Let me make a recomendation here, don't call them if you enjoy having a low stress level because thier tech support is aweful !!!!
They are aware of this happening and thier solution is to simply unplug the GPS mod and plug it back it after windows has booted. Windows thinks that the gps mod is a serial trackball MOUSE. This is the only peice of information that I got from them that was helpful..
To fix this problem, go to device manager make sure that windows is seeing 2 mouse one should be your real mouse and the other is a driver windows selected for your gps mod. Take the driver "Sermouse.sys" and rename it to sermouse.bak.sys and uninstall the serial mouse in device manager. THen reboot the system with the gps mod plugged back in and this should solve your problem.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 02-17-2005, 01:56 PM   #70
Am am just curious if anybody has dealt with a tech support group lately that does't stink?????
In the past two years I think all have been outsourced to India and the level of knowledge is aweful. If they would just put the same database the tech support people are reading from on the internet they could do away with those morans.
Linksys for one is the worst. About 4 years ago when I got my first Linksys device their tech support was GREAT... solved every problem I had quickly and properly. They were located in the US and had real knowledge.... Now it is a bunch or dumbasses in India that just type what you say into a database and read back the anwer to you. Most calls to Linksys lately have resulted in them screwing something else up, which I have to fix... them try to fix the original problem I called about.....
Sorry to divert... but you got me fired up again about crappy tech support....
dug1967 is offline   Reply With Quote
Old 02-17-2005, 01:57 PM   #71
I had the same problem but took a different approach to fix it: Went to Device Manager and just simply disabled the Trackball mouse.
I had to do this twice since I had two Trackball mice. This was due to the fact that I connected both serial outputs on my Garmin GPS25LV to my PC. One on COM1 and one on COM2.
Old 02-17-2005, 02:01 PM   #72
hklomann's Avatar
@intellaworks garmin gps 15
thats usual behavior for serial gps devices
i figured out prices for the gps modules in germany:
GPS 15L-W
1 Stck (Muster) USD 120.00
02 - 09 Stck 92.00/Stck
10 - 49 88.00
GPS 15H-W
1 Stck(Muster) USD 120.00
02 - 09 Stck 98.00/Stck
10 - 49 94.00
prices will be converted to euro on dayly exchange rate
these are the modules including prewired conectors
15H: 8 to 40 Vdc unregulated
15L: 3.3 to 5 Vdc +/- 100 mV ripple
and i would add a short mcx to mcx conection cable (or mcx to fme patchcable most gpscarantenna or tripple antennas here in gy use fme connector)to keep the module location more flecible and not to stress the module conector
intresting article about garmin gps oem module and activ antenna:
http://lists.tapr.org/pipermail/aprs...er/000821.html
and donīt buy a cheaper gps 15 cause it has no waas/egnos and no 1pps data output
@ublox oem sbr-ls intrested
gps modul gyro and antenna arrived yesterday its so tiny (bad image cause of the camera)
Size:71mm x 41mm
• Height: 11mm
• Weight: 17g
my solution with the serial linedriver problem will be:
will connect both serial ports via a dual serial to usb converter ftdi FT2232C that works fine with serial cmos level 3.3 volts
i chop a cheap convertercable to get it (which i hopefully receive tomorrow)
still searching for a clue how to connect the gyro (can`t shrink it to a cable cause it has to be in the right position upwards to work as rotation sensor)
first i will do a quick and dirty wireup maybe someone likes to construct a pcb daugtherboard to make it a quick connect solution
Holger
Old 02-17-2005, 02:21 PM   #73
Yea this is also a fix I guess but I wanted to be assured that it will never show up again so I just got rid of the driver.
About gramin's tech support this is why I was upset: I called in the AM and asked for Tech support and stated that I had an OEM GPS 15L. I was transferred to someone who wasn't even in tech support then transferred again to some nitwit that said that there is no fix. He told me to just unplug it and replug it in, I explained to him that I'm a systems developer and that the designs for my machines won't allow for that and further more that doesn't make any logical sense. He asked me to hold on and then asked me the same questions he asked me the first minute of the phone convo !!! AND offered the same solution !!!!!!! Are you kidding me ?? At least they pointed me in the right direction and I was able to easily solve it after I knew it wasn't an IRQ conflict...
Here is the kicker though. Me being the nice person I am, called garmin back to tell them that there is actually a solution to this problem... I was transferred twice to people who either were too lazy to pass the info on or wasn't even in that department. On the 3rd transfer I explained why I was calling and she told me she was going to transfer me again.. I told her to wait a second... Explained to her that this is the 3rd time and honestly I could care less about helping Garmin out at this point because its obvious they are so clueless that my knoladge probably wont get passed along anyways...
Anyhow, I'm ****ed that a company can't even provide help for thier own products it's rediculus... I belive this call was to somewhere in Texas, so there are clueless poeple in the US as well as all over.
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 02-17-2005, 02:31 PM   #74
n00b 4 life
mp3oplecarrier's Avatar
I had this as well with my first setup, and I solved it in a different way, i built a small delay circuit that caused the gps to only be powered after windows was running, as I now have a carnetix in my new system I will be using the delay on signal to power it on.
Steve
New Car
New Car computer will follow........
(Gazes at pile of components)
mp3oplecarrier is offline   Reply With Quote
Old 02-17-2005, 02:33 PM   #75
hklomann's Avatar
@ intellaworks you should add your workaround with renaming the sermouse driver to your writeup thread
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
a new way of GPS brownpage GPS 8 08-24-2004 03:51 PM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 06:08 PM
USB DVD + Radio Tuner + OEM GPS gguy General Hardware Discussion 4 02-13-2001 12:43 PM
