Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 02-17-2005, 02:56 PM   #76
cheap custom title
JC-S60's Avatar
The same problem occurs with my haicom 203E GPS-receiver... just disabled the 'trackball', but it comes back if you plug it in another usb-port, as windows assigns a new com-port and then thinks it's another trackball.
Renaming the driver is a very good solution!
JC-S60 is offline   Reply With Quote
Old 02-17-2005, 06:12 PM   #77
MySQL Error
jcdillin's Avatar
you know what is strange, I was getting the mouse jumping, and I went and enabled the gps to send all sentences(default is only to send like 3 or 4 of them), and to send them at 19200 baud and windows will not detect it as a mouse now.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 02-17-2005, 06:23 PM   #78
IntellaWorks's Avatar
hmm
I wonder if that would work for me.. ahh well I'm working on my system with the problem already solved.. someone post if this solution works for them.
BTW: working on my system and it boots to a shell in 12.3 seconds (using boot vis) I'm using it with a fast IDE drive tho so it'll slow when i add it to a CF card.. but the effort as worht it !
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 02-17-2005, 06:50 PM   #79
MySQL Error
jcdillin's Avatar
very nice, I would do the same thing, but mine boots in about the same time with a standard xp sp2 install.
肚子笑痛了
S60 Install
Old 02-18-2005, 09:05 AM   #80
hklomann's Avatar
look what i got as 2 port usb2serial converter cable
itīs not what i expected but i will give it a try
i realy could not belive that it includes a 4port usb hub
it was hard work to chop it
everything is possible
home is where your heart is
hklomann is offline   Reply With Quote
Old 02-20-2005, 06:13 AM   #81
I'm sorry, and you are....?
frodobaggins's Avatar
Registry fix for jumping mouse.
File Type: zip sermouse.zip (254 Bytes, 82 views)
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 02-22-2005, 12:04 PM   #82
Why do u need 2 serial?
Also, would you still have the detection problem with windows when you convert rs232 to usb? The main reason why I switch my usb gps to serial gps is every time I got out of sleep, i had to unplug and replug my usb gps mouse in order for windows to understand that gps mouse is a gps mouse instead of a unknown gps device.
If worst comes to worst, i may have to look for pci to serial to give me additional ports to make this works.
I already used com1 for my touchscreen and com2 for my gps...
nl4jy is offline   Reply With Quote
Old 02-22-2005, 01:05 PM   #83
hklomann's Avatar
the usb 2 serial coverter works fine with the 3 volt cmos level serial signal from the ublox module and all navigation software listens on com/virtual com port for their input and i always have free/unused usb onboard conectors the other reason why i don`t attach direct to serial is cause my module shall be usb bus powered and the module might be placed internal or externaly i never had any recognition problems with gpsmodules on usb 2 serial or direct serial except of the well solved ballmouse prob after conecting
Old 02-24-2005, 10:27 AM   #84
that's cool to hear. I'm just concern for my case since I do have that recognition problem when I return from sleep/hibernation. I'll be watching this thread or a new one you created to record your WIP.
Old 03-02-2005, 11:57 AM   #85
any update on your prject hklomann? My fund is almost complete and would really like to hear how's it going.
Old 03-02-2005, 12:28 PM   #86
hklomann's Avatar
not yet i ll bag you pardon but first have to do a few other things thread will be updated as soon as something new is to say...
Old 03-06-2005, 01:48 AM   #87
I love the Trimble Lassen SK2 module. I built an interface PCB, it's been operating perfectly. Here is a pic (if I could attach it).
emumanXM is offline   Reply With Quote
Old 03-06-2005, 07:35 AM   #88
MySQL Error
jcdillin's Avatar
dual serial outputs?
肚子笑痛了
S60 Install
Old 03-06-2005, 07:49 AM   #89
hklomann's Avatar
@jcdillin
both serial ports of the ublox module can be configured as in or output
Old 03-06-2005, 07:57 PM   #90
MySQL Error
jcdillin's Avatar
very cool
肚子笑痛了
S60 Install
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
Newbie's guide EBFoxbat Newbie 6 02-08-2005 11:06 AM
a new way of GPS brownpage GPS 8 08-24-2004 03:51 PM
Window Tint's effect on GPS signal MoFo GPS 3 07-19-2004 06:08 PM
USB DVD + Radio Tuner + OEM GPS gguy General Hardware Discussion 4 02-13-2001 12:43 PM
