Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 03-10-2005, 06:14 PM   #31
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
That would be correct, 2 for serial and 2 for power, and just tie the two grounds together.
if you dont ground the serial line you will be tearing your hair out trying to figure out why it wont send any data
Here is mine,
http://www.mp3car.com/vbulletin/gps/43268-oem-gps-installs.html
i'm actually using 5 wires because my antenna takes 5 volts instead of 3
edit:
also when you get it installed, make sure you try turning on all the sentences on (the default is only like 4 of them) I want to see if that fixes the mouse jumping issue
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 03-10-2005, 06:15 PM   #32
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
You can use the "plugs" or connectors used in a pc-case to connect you speaker/hdd-led/power-button etc. to the mainboard. They should fit in the serial/usb headers too.
Just look for an old pc-case and cut those wires. Solder them to the wires of the 15L-W and you're in
JC-S60 is offline   Reply With Quote
Old 03-10-2005, 06:32 PM   #33
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
Quote: Originally Posted by edrex
Intella:
From what I can tell you only use 4 of the 8 wires that come off the 15L, right? 2 for power that I'll be getting off usb pins, and 2 going into the COM port 2. Is that correct, and if so, what are the other wires for? I will be (hopefully) installing this tomorrow if I can find something to use to connect the wires to the pins. Any suggestions would be great.
Thanks again for the excellent writeup (which should really be a sticky so more people will know about the OEM route).
Cheers.
This is correct, check the pinouts for the Garmin 15L its a .PDF file located hereDocumentation
W/o really looking into it I'm drawing a blank as to what the other pins actually do.. if you read the documenation or see my pic of the garmin pinouts it'll tell you... Your not loosing anything functionality if thats what you mean.. In fact I was able to update the OEM firmware with the 4 wires connected...
Again for the life if me I cannot remember the name of the little pins I used to attach to the wire, which in turn slides over the COM header on the Mobo.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 03-10-2005, 07:00 PM   #34
integramodder is on a distinguished road
I saw in this thread you briefly mention the reason for doing this. It seems to be a more involved and more expensive way of getting GPS working.
Are there anyother reasons for doing this of than just to fully embed this part of the system?
integramodder is offline   Reply With Quote
Old 03-10-2005, 10:03 PM   #35
Yea, another reason is that the bulk of the electronics is inside my car instead of out in the weather...
Also my GPS unit maintains a lock for up to 21 days un-powered.... your USB mouse doesnt..
This GPS mod takes a less amount of power and is WAAS capable... At the time I was doing the initial research there were no WAAS USB gps mouse's...
The antenna that goes on the roof of my car is less than a quarter of the size of the smallest GPS mouse, so its more of a stealthy look...
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 03-10-2005, 11:36 PM   #36
When you say gps mouse are you actually refering to the gps mice that are sold or the general all in one package?
Old 03-11-2005, 06:18 AM   #37
Raw Wave
edrex's Avatar
edrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud of
I have no idea what this means, but I'll test out anything that you all need me too. Just send some directions over to me. If this is a software thing, I haven't bought my software yet. Still need to decide on which one to go with (suggestions for one that will embed with RR?).
Thanks to all of you for the advice so far. I will try and find some connectors for the wires and get it all done soon. So far RadioShack and my local hardware store don't carry anything that will work. Going to computer stores next.
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
edrex is offline   Reply With Quote
Old 03-11-2005, 09:42 AM   #38
woeful is on a distinguished road
I order this, and the antenna that intel mention, total $156 shipped. Now I only need a screen and powersupply and find a way to mount the antenna on a civic.
woeful is offline   Reply With Quote
Old 03-11-2005, 12:56 PM   #39
Change's Avatar
Change is on a distinguished road
You may want to look into the GPS15H instead of the 15L, the H version takes 8-40VDC unregulated power.
Change is offline   Reply With Quote
Old 03-11-2005, 02:56 PM   #40
Raw Wave
edrex's Avatar
What would the advantage be over the L that takes 3-5V and can be powered right off the motherboard?
Old 03-11-2005, 03:24 PM   #41
DigitalDog is on a distinguished road
GPS Antenna
Seriously you guys. If you are considering using the OEM gps from Garmin, consider buying the Glisson antenna from GPSgeek.com. It is a direct replacement for the ga27c from Garmin for $45.00 cheaper. I have used Garmin products in the past (I have an iQue 3600 and etrex Legend) and I've found their antennas way overpriced.
Just my thoughts.
DigitalDog is offline   Reply With Quote
Old 03-12-2005, 12:48 AM   #42
Just my thoughts.
could have say sooner, my order have already been shipped.
Old 03-12-2005, 01:02 AM   #43
Unhappy
Sorry, I thought I did. See post #29.
Old 03-12-2005, 07:24 PM   #44
Change's Avatar
Depends...some will mount it inside their PC case, and get power from in there...others may put it in a small external enclosure, where vehicle power will be easier to get at.
Old 03-14-2005, 03:12 PM   #45
Raw Wave
edrex's Avatar
Got It Installed!!!
Hey everyone,
Just wanted to let you know that I got my Garmin 15L installed today and it seems to be working just fine!! Thanks for the help and support getting this one going for me, I'm very happy with the way it turned out.
I used the Delou Testing software that Intella posted on the first page and it got a lock with my position right away. At the top it said, "Tracking 0 of 12 satellites in view". Is that good or bad?
Anyway, Thanks again for the help/ideas. I'll post some pictures in the install thread when I get the inside of the computer a little cleaner.
Cheers.
Stealth OEM install in MR2 Spyder - Magazine coverage! silencery Show off your project 95 07-31-2008 05:15 PM
Sony XA-300 mod pics? tom2112 General Hardware Discussion 11 10-27-2004 04:48 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
Some mod pics of Remote and D Link radio gospeed.racer General Hardware Discussion 2 01-14-2004 04:10 PM
pics of my pioneer slot DVD window mod =) moahdib General Hardware Discussion 5 04-30-2002 06:10 PM
