Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 05-24-2005, 09:45 PM   #61
Registered User
aoLhaTer's Avatar
aoLhaTer
Heres my crazy wiring setup
Used two connectors off a 4 pin internal sound cable and then a connector off an internal usb cable
Testing it out right now, weeee
2004 G35 Coupe project
aoLhaTer is offline   Reply With Quote
Old 05-24-2005, 10:36 PM   #62
woeful is on a distinguished road
how are your guys reception? the max i got in open road is 10, never more than that. I guess my antenna big, expensive and crap.
woeful is offline   Reply With Quote
Old 09-26-2005, 01:47 PM   #63
rgardjr's Avatar
rgardjr is on a distinguished road
I installed one last week and I'm very impressed ....
After bending a pin on my Earthmate cable it became very unreliable so I bit the bullet and bought the OEM 15L-W from MegaGPS.com plus this antenna from Ebay:
http://cm.ebay.com/cm/ck/1065-29392-...tem=5810468863
Total spent including shipping:
OEM $88.72
Antenna $24.98
Total $113.70
Installation went very well other than the minor hassle of xp detecting it as a serial mouse, but thanks to earlier posts I was able to fix that quickly. I used a serial header cable and an extra audio cable tha I had laying around to wire up the OEM. The soldering the wires was very easy. I used some double sided foam sticky tape to stick the OEM to the side of my unoccupied PCI slot on my Epia M10K. I have a truck so I routed the antenna through the third brake light-I've seen this done alot with XM/Sirius installs. Very easy installation all the way around. The GPS module performs so much better than my Earthmate. I'm getting a constant 9 satellite lock. With the Earthmate I don't remember getting more than 6. I would absolutely reccomend this for anyone looking for a GPS module for their install. I'll take some pictures when I have the camera out again.
Rick
'03 Sierra Denali
rgardjr is offline   Reply With Quote
Old 09-26-2005, 02:43 PM   #64
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
Response.
Thanks to all that have contributed information. I agree with Rick, this setup is recommended and again much more stable.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 06-23-2006, 08:03 AM   #65
miztahsparklez is on a distinguished road
i was searching around for some cheap oem gps modules, and i was wondering if anyone had any ideas on this Ebay gps module.
http://cgi.ebay.com/3-OEM-NMEA-GPS-M...QQcmdZViewItem
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
miztahsparklez is offline   Reply With Quote
Old 06-23-2006, 07:25 PM   #66
hmm, but i wonder if that oem gps performance is similar to say the garmin unit for 85 bucks or whatever. im thinking you will need to make that little battery backup PCB thing, shown in someones picture above. hmm, whats peoples experience with the performance of various oem units?
ive searched a few times, but most people are using dongles.
Old 07-03-2006, 12:51 PM   #67
Garmin 15L & H models seem to be the most reliable / accurate (depending on the antenna placement)
F
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 07-04-2006, 03:59 AM   #68
currently i have my usb mouse under the dash of my car attached to an air vent. it probably averages about 5-7 sats the most was 9 and only if im in the city with tall buildings itll drop to 2 sats or less. if i were to put the antenna in this same location, would it do any better? or should i find a different spot? say in the windshield cowel where the wipers go.
Stealth OEM install in MR2 Spyder - Magazine coverage! silencery Show off your project 95 07-31-2008 05:15 PM
Sony XA-300 mod pics? tom2112 General Hardware Discussion 11 10-27-2004 04:48 AM
Finished Building my GPS, now some ?s for the GPS gurus Dominik GPS 9 10-25-2004 02:34 AM
Some mod pics of Remote and D Link radio gospeed.racer General Hardware Discussion 2 01-14-2004 04:10 PM
pics of my pioneer slot DVD window mod =) moahdib General Hardware Discussion 5 04-30-2002 06:10 PM
