Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 03-22-2005, 04:12 PM   #1
How to make LED's flash?
How are you going guys
I have been doing so reserch on but have not been able to come up with anything. i want to make some kind of circuit that will alow me to control the way led's flash, or make it flash in a pattern. so far all i've been able to find is that i need a chip. but i need info where to buy it and how to program the chip.
I will me really thankful if someone can give some ideas how to do this. keep in mind i want to run this from my car at 12v.
jceli728 is offline   Reply With Quote
Old 03-22-2005, 05:12 PM   #2
Prem's Avatar
I find the following link useful when building circuits.
http://www.discovercircuits.com/
Hope this helps.
Prem
Re-boxed Dell Optiplex GX110 PIII 733 256Mb RAM
Modified Sproggy PSU
Custom made automatic start-up/ shut-down controller
Dual 2.5" HDDs
Laptop DVD Reader
D-Link FM Radio
5" PSOne LCD
Installed and working. 75% complete.
Prem is offline   Reply With Quote
Old 03-22-2005, 05:20 PM   #3
rubicon's Avatar
Turn them on and off *really fast*.
rubicon is offline   Reply With Quote
Old 03-22-2005, 05:27 PM   #4
fantomas's Avatar
parallel port interface...and control them with some custom software....
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 03-22-2005, 05:35 PM   #5
Saab9-5's Avatar
Agreed. Depending on how much control you want, using your carputer would give you the most flexibility with flash rates and patterns. Using the parallel port would eliminate the need for a chip. Individual LEDs can be driven directly from the port's pins. A string of LEDs would be controlled by a transistor connected to the port's pins to give you more current for the LEDs without the possibility of damaging the port.
Saab9-5 is offline   Reply With Quote
Old 03-22-2005, 05:45 PM   #6
NiN^_^NiN's Avatar
Talking
When i get home i'll give u instructions and code to make the LED's flash on and off from the parallel port
Just wait a few hours tho cause it's 9:50am and i don't leave work till 7 so i'll be home at 8 or 9
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 03-22-2005, 06:45 PM   #7
Thanks for the info so far. NIN^ ^NIN, i will appreciate if u can provide me those instructions.
Old 03-22-2005, 10:37 PM   #8
Stonewall78's Avatar
A 555 timer works great for simple flashing jobs and I am sure you can find even more circuits on the discovercircuits site. Here is another site for you.. link .
Stonewall78 is offline   Reply With Quote
Old 03-22-2005, 11:28 PM   #9
Curiosity's Avatar
If it doesn't matter how fast or anything, I'd just buy blinking LEDs.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 03-22-2005, 11:55 PM   #10
99bravada's Avatar
Hooking leds up to the computer is a bit overkill if you just want simple blinking... I've seen led strips with a potentiometer monitoring how fast it blinks, etc... but this was at a surplus store, so no link to give unfortunately
I saw some LED strips at walmart one time that light up with the music as well... you may want to check there.
Current:
2007 Black Diamond Toyota FJ Cruiser | Mac Mini (in dash) | Carnetix P1900 (in dash) | Apple Bluetooth Keyboard | Kicker KX350.4 amp | Pair Polk Audio 6.5"s in front
Coming soon:
12.1" touchscreen LCD (in dash) | US GlobalSat USB GPS receiver
99bravada is offline   Reply With Quote
Old 03-23-2005, 01:06 AM   #11
Raw Wave
Use a christmas light
Chris31 is offline   Reply With Quote
Old 03-23-2005, 06:01 AM   #12
Saab9-5's Avatar
@jceli728 - How about going into more detail about what you are thinking/planning on doing?
Old 03-23-2005, 12:00 PM   #13
code-'s Avatar
Like... uhm... MIRT fast?
1984 BMW 323i (E30)
[==========] 90%
EPIA MII10000
256MB RAM
40GB 2,5" HD
Lilliput 7" TS
Hacked Travla C134
Haicom CF GPS
code- is offline   Reply With Quote
Old 03-23-2005, 12:04 PM   #14
rubicon's Avatar
Well, after years of "practice" using advanced training material (read: lots 'n lots of porn), I can say "yes."
At least with my right hand.
Old 03-23-2005, 04:28 PM   #15
Thanks for the feed back. yes i'm trying to stay away from hooking them up to my pc. What i'm really looking to do is for a show purpose, for ex: i have put them in the interior door handles, now i'm able to turn them on with my headlight switch or with an independent switch when the headlights are off.
but what i want to do is make them flash back and forth between the doors & create different patterns in the rest of the car almost like strobe lights. i know it will just be much easier using strobe lights but for the place where i'm installing the LED's i will not be able to install a strobe light.
How to make the Garmin GPS 35 Work with Copilot 2003 fluffy2097 GPS 16 09-05-2007 05:19 PM
Cheap Compact Flash BiohazrD General Hardware Discussion 0 10-05-2004 08:07 PM
SBC with LCD controller, flash disk, snd / lan etc :) Phrozenpenguin Classified Archive 4 08-11-2003 01:23 PM
Have your friends make their own playlist! dudah85 General MP3Car Discussion 3 08-14-2001 11:19 AM
how to make LED flash? schrodos General MP3Car Discussion 7 01-14-2001 07:39 PM
