Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 04-05-2005, 01:26 AM   #31
Zac
Awww and I was hoping someone had it finished already. I've been "working" on this for the past year+ but I can't get the time to actually start and see it through. I had a relay controller working nicely with Cypress's EZ-USB FX chips but I can't solder SMD to produce em and the dev board is toast.
Maybe this will provide some motivation...I've got an fairly nice assortment of the new USB pics lying around and I got the ICD2 clone working not too long ago....
What would you be willing to pay for a USB relay controller? I figure a price could even be broken down to $x/per each relay on board since they'd be made to order.
Zac is offline   Reply With Quote
Old 04-05-2005, 07:21 PM   #32
kiltjim's Avatar
I've tried to update my design keeping in mind your suggestions. I've thickened all the traces where I could, and managed to get it down to a one layer board, with just a few jumpers. And I also got it to print to PDF too. so with a little playing around in photoshop, you can print it to your transpareny film.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 10-06-2006, 11:16 AM   #33
Does anyone have the used sourcecode, the link in the starting post is broken.
Thanks in advance.
e5james is offline   Reply With Quote
Old 10-07-2006, 01:29 AM   #34
Stonewall78's Avatar
I have some suggestions for you board lay out. Try to have all your connectors along one edge that way it will be easier to integrate into a case. I would put the power and usb on one side and the relay connects on the other. I would also look into adding the relay right to the board, that way you can add the protection diodes(for coil feedback protection). You could also look into using SMT parts, that way you have less holes to drill when you make your own circuit board, SMT is not hard to work with just buy a good set of tweezers and you are golden.
Stonewall78 is offline   Reply With Quote
Old 10-07-2006, 02:15 AM   #35
pRoFiT's Avatar
Damn i read the whole thread for something that probably ended a year ago. Thanks guys.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline   Reply With Quote
Old 10-07-2006, 08:07 PM   #36
I have a board layed out based on a newer PIC18F252. Yes, not the NEWEST, but newer than any 16C part.
KE4NYV is offline   Reply With Quote
Old 10-09-2006, 02:09 PM   #37
Could you put a file in this thread with the assembly files you used for your relay controller? I'd really appreciate that :-)
Old 10-17-2006, 03:47 PM   #38
Dragonknell911's Avatar
Quote:
All said and done, it's gonna cost me about $20, if I can make the PCBs myself.
Based on some of your posts I was unsure whether or not you were aware you can print/create your own PCBS, so just in case I thought I would post a link to how to make 'em.
http://www.madengineer.com/tricks/homemade%20PCBs.htm
REBUILDING!!
Dragonknell911 is offline   Reply With Quote
Old 11-07-2006, 06:15 AM   #39
Thanks in advance.
Sorry to bump this post, but I am really eager for the source code used for this project. I found the PIC16C71 sources on archive.org, but am still looking for the code used in the "USB->serial" chip, does anyone have that code, and would you plase post it for me?
Old 11-28-2006, 12:55 PM   #40
send me a PCB!
I'll buy one.
Jim
gpscruise.com
carterson2 is offline   Reply With Quote
USB -> Parallel -> HD44780 LCD Zip-Lock General Hardware Discussion 5 03-09-2005 06:31 AM
Will someone help me program my relay control module cproaudio Software & Software Development 6 09-04-2002 05:50 AM
WTB: Intellitouch USB or Serial Controller tbdombrosky Classified Archive 0 06-28-2002 07:41 PM
Switching USB connection On/Off with relay Destin General Hardware Discussion 8 09-09-2001 05:31 AM
USB LCD Controller smashr2k General Hardware Discussion 3 07-19-2001 05:03 PM
