Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 04-20-2005, 01:28 AM   #1
zPilott's Avatar
Exclamation V1 Virtual Display : Valentine One to PC via USB
I have been working on this for quite some time, but I have finally finished it. After abandoning the serial interface for several reasons I came up with this:
There may be some enhancements in the future, but for now this works great.
Connection:
  • The parts list for the connection is:
  • 2 10k resistors
  • 1 15k resistors
  • 1 2.2k resistor
  • 1 .033uF capacitor
  • 1 +12V to +5V regulator (e.g.) 7805A
  • 1 2A2904 transistor
  • 1 USBMOD3 (the best price I found was at http://www.futurlec.com/USB.shtml )
  • A 4 or 6 conductor modular phone jack (or you can rip apart a phone cord)
  • A small enclosure (such as this ) to make things neat.
Look for the thread on the accompanying software in the software forum.
|V1 Virtual Display|
Hard work often pays off over time, laziness always pays off right now.
Last edited by zPilott; 04-20-2005 at 02:10 AM. Reason: added link to software post
zPilott is offline   Reply With Quote
Advertisement Sponsored links
Old 04-20-2005, 04:15 AM   #2
Change's Avatar
Very nice work!!!
Change is offline   Reply With Quote
Old 04-20-2005, 07:57 AM   #3
Enak's Avatar
What does it do?
Enak is offline   Reply With Quote
Old 04-20-2005, 08:00 AM   #4
The valentine 1 is a radar detector, a very popular one... this displays its output on your carputer.
e46|700tsv 2005 model|sb51g xpc2.4ghz opus 150|I-bus|XM Direct&cables | slim slot USB DVD-cdrw|Hawking 54g|iGuidance 2.1-HoluxGPS
sold it all... :-(
Coming Soon - 2007 BMW 335i UMPC install
RiXst3r is offline   Reply With Quote
Old 04-20-2005, 08:12 AM   #5
Enak's Avatar
I'll have a look at that then
Old 04-20-2005, 01:43 PM   #6
drait's Avatar
Awesome work zPilott!! I'll have to see if I can make this one work with my V1
Does the concealed display need to be attached in order to get the output signal?
89 Supra Turbo
drait is offline   Reply With Quote
Old 04-20-2005, 03:19 PM   #7
zPilott's Avatar
Thanks for reminding me, I should have said this before. The current design works ONLY ON ITS OWN!!!!!!
DO NOT CONNECT THE REMOTE DISPLAY
(sorry about that, just wanted to make it clear that running a splitter and connecting the remote display MAY cause problems )
I am working on modifying things to allow for that, or for putting an in and an out jack on the board for connecting the remote display.
|V1 Virtual Display|
Old 04-20-2005, 03:37 PM   #8
drait's Avatar
That's what I figured... just wanted to make sure
You can do what I did on one of Jim's designs and just put in a 2-pin jumper or single position DIP switch inbetween that resistor and +12V (or in this case, +5V). Not as elegant as an input/output port, but it works.
89 Supra Turbo
Old 04-20-2005, 03:50 PM   #9
I'm sorry, and you are....?
frodobaggins's Avatar
Where do you hook it to the pc ?
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 04-20-2005, 03:51 PM   #10
nevermind, wasn't looking at the usbmod3
just the schematic
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 04-20-2005, 04:03 PM   #11
Hy,
Thx a lot.
I hope your schematics will work.
It's very nice, useful, and I really wait for the next update.
Thank you for the API too
Just need to order tomorrow the USBMOD3, 'cause my local store hadn't it, and ASAP I'll mount it and try it
PS : I didn't found drivers for PPC, do you think it already exists ? ( I know I would have to modify the schematics... )
Regards.
Forden
forden is offline   Reply With Quote
Old 04-20-2005, 08:50 PM   #12
contaygious's Avatar
nice. can you mute your v1 with that usb cable? anyone want to make me one?
It would be nice to be able to hook up my remote display as well as I switch b/w carpc and stock nav on my screen...
THANKS!
Peep MY TYTE WHIP yo! It's got too many ill mods to list!
contaygious is offline   Reply With Quote
Old 04-20-2005, 09:57 PM   #13
zPilott's Avatar
there are win ce .net drivers, but no ppc
ima see what I can do about the remote display connection, and also extinguishing the display.
|V1 Virtual Display|
Old 04-20-2005, 10:16 PM   #14
thanks! Let me clarify, does anyone want to SELL me a cable that I can use to mute the v1 with via this software?
THANKS!
Old 04-21-2005, 02:04 AM   #15
Hy again,
Could you just confirm me, that there's a mistake in the part list.
You wrote : 1 2A2904 transistor and on the schematics there's a 2N3904...
(2A2904 transistor doesn't seem to exist, so.... ).
So my local store send me a 2N2904, will it be good enough for it ?
Thank you
Forden
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
GRAPHIC LCD DISPLAY? -> POOSIBLE TO CONNECT TO PC? andi General Hardware Discussion 6 02-27-2004 06:31 AM
Garmin 35 PC USB VS. Deluo USB Receiver SLAYER6669 GPS 0 10-03-2002 01:33 AM
Toshiba Pocket PC e74 w/VGA out & USB hotwater9 General Hardware Discussion 0 07-17-2002 11:58 PM
Can you drive a laptop display with a regular PC? rx-7_mp3 General Hardware Discussion 1 01-13-2001 04:26 PM
