Quote: Originally Posted by RoyN
256mb??? I think that would be pushing it even for the smalles footprints I've seen reported....
13s is damn fast... can you post details? did you use nLite then minlogon? can you post the nLite file?
Are you using Bluetooth? what USB devices are you running?
256 does cut it close, but it's most certainly possible. In fact, if you do some research you'll find many systems at or just above 300mb. By killing alot of useless crap, you can cut her (just barely) to fit 256.
No bluetooth (yet) and the only USB device being used is the FM Wireless Keyboard. I plan on adding a serial GPS this week, and a bluetooth module somewhere down the road.
I don't use nLite, or any other login modification. I simply carved parts of XP out which aren't needed. The most obvious things are knocking your prefetch around, getting rid of fonts, tweaking the filesystem and cache, and disabling a bunch of useless services. Out of the possible services running, I believe I have somewhere around maybe 10 or so. I'm at work right now, so I can't give you exact details on those.
Also making sure you have the least amount of drivers loading is handy, as well as having a pure and clean registry--nothing buggered up, and definately nothing where you've installed a bunch of things and uninstalled them. Even after using some sort of registry sorting program, it'll never be the same. All of my streamlined burns of XP (or any flavor of NT) are setup on a test system first, and then installed using either a streamed CD or utilizing the exact methods needed (eg, installing only what you want).
It's a Shuttle XPC, and I'm running a WD 160gb drive. AFAIK it's a 7,200rpm drive. 512mb ram, AMD chip. I want to say it's almost 3ghz, but I forgot offhand (I know, sounds weird, but it was a gift and I never looked at the specs--I just dove right in
And for anyone else curious, while sitting at the interface she's only using 51mb of ram. If I disable the default explorer interface on bootup, it saves another 1 or 1.5s, and also almost 2 megs of ram. By loading up one of my custom LiteStep interfaces, I can have a custom interface which looks OEM (without running an external program such as CentraFuse or Frodo) and it only uses .5 - 1mb of ram.
At any one point while using CF, she never goes over 70ish of ram usage. I hope this helps anyone, and answers your questions. If you need anything more detailed, I'm sure I can type something up when I get home.
