Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 05-11-2005, 11:05 PM   #1
Kamakazie2 is on a distinguished road
Pc integration for Smartire pressure system or Back up sensors
I was wondering if anyone tried to integrate the Smartire Tire monitoring system to a car pc? How hard would it be?
What about those back up sensors for the bumpers that we all see on ebay?
Thanks again!
-Jack
2006 Chrysler 300C AWD
IBM T30 Thinkpad / RoadRunner
XMPCR/GPS/SIRIUS
(RIP) HDRadio project: http://www.mp3car.com/vbulletin/hardware-development/93791-someone-here-has-able-crack-hdradio-car.html
Kamakazie2 is offline   Reply With Quote
Old 05-11-2005, 11:43 PM   #2
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
I'm planning to do something with backup sensors, except I'll install 2 sensors in the front and 2 in the back. Still don't know how I'll manage to do that, but I will eventually
0l33l is offline   Reply With Quote
Old 05-12-2005, 10:11 AM   #3
I cant wait to see the finished product.
I am going to purchase one of those units on ebay and see how it communicates with the display.
-Jack
XMPCR/GPS/SIRIUS
(RIP) HDRadio project: http://www.mp3car.com/vbulletin/showthread.php?t=93791
Old 05-12-2005, 10:34 AM   #4
angusn's Avatar
angusn is on a distinguished road
Funny (kinda) related topic
My dad's 2000 Corvette has some integrated tire pressure gage and it's very flakey. When he first got it (new in spring 2000) it misred the tire pressure and wouldn't let the car go over 50mph. That sucked for me, 'cause I wanted to see what the car would do!
Are you thinking of getting the voice to read you the tire pressure if it gets below a nominal value?
"Right rear tire pressure is low. Car needs air badly!"
Car: 1997 VW Passat TDI moving to
1985 Mercedes-Benz 300D
CPU: HP ePC 1gig/256meg/250 gig
Status: Ghetto Install w/Inverter,
Xenarc & GPS & RadioShark
ToGo: DC-to-DC conversion, Grease conversion
angusn is offline   Reply With Quote
Old 05-12-2005, 10:36 AM   #5
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
Thanks again!
Is smartire a specific brand of tps? I was reading an article on autospeed.com about splitting ABS and traction so you can disable TC via switch without loosing ABS. (I've wanted that for awhile) Long story short, reading up on the sensors gave me an idea.
If you have for wheel speed sensors, you can use them to measure (roughly) tire inflation. Many oem systems do just that. I think the system is usually called Differential Tire Pressure Monitoring (DTPS). They compare the 4 speed signals, if one is faster, the tire is smaller and therefor underinflated. It doesn't help if they all lose an equal amount over time though.
Shouldn't be to hard with a PIC. It's on my list of things to do
shotgunefx is offline   Reply With Quote
Old 05-12-2005, 11:22 AM   #6
I like that idea, however how would we differentiate when the car goes around turns? Maybe if we link the tire speed based on side instead of comparing with all 4.
Smartire is a system that you install in the rim prior to installing a tire. Its a band that measures inflation and wirelessly transmits the info to a reader.
http://www.smartire.com/
-Jack
XMPCR/GPS/SIRIUS
Old 05-12-2005, 11:30 AM   #7
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
don't forget to mount some in the sides linked up to a warning sound or a camera!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 05-12-2005, 12:09 PM   #8
Raw Wave
shotgunefx's Avatar
Good point. Well I suppose you would see a change in both tires so that could be an input. But I think the because the baseline is averaged out over quite an amount of time, turning I would think would be factored in by the averaging.
You could always use an accelerometer. I've got a Memsic one. I haven't installed it yet (but have played with it) as I don't know if I'm going to use it to measure vehicle movement or as a tilt sensor for the steering wheel.
I'd really like to have my driving lights turn with the steering wheel. They make steering sensors (Basically big potentiometer) but they are big, big bucks. The problem with the accelerometer I need to work out is that my wheel turns multiple times. Not a big deal to calibrate out, but just haven't had the time. Plus I have to fabricate brackets for the lights.
Old 05-12-2005, 12:13 PM   #9
I would love to take that idea and relate that to my reverse camera. As you turn the wheel in reverse it will pivot the camera to see where your car is going.
-Jack
XMPCR/GPS/SIRIUS
Old 05-12-2005, 12:15 PM   #10
Raw Wave
shotgunefx's Avatar
Way ahead of ya! (Note the servo)
Another easier option (that I might take) is to wire it to your blinkers and just have it deflect when you use them.
Old 05-12-2005, 01:08 PM   #11
My Village Called
0l33l's Avatar
What do you expect? Its a corvette
I wouldn't do the tire pressure stuff, because you need special wheels, atleast on the SC430.
Old 02-17-2006, 06:49 PM   #12
pastypyro's Avatar
pastypyro is on a distinguished road
Major bump...
I have a smartire system and I need to do just this. It consists of the four transmitters on the wheels and a radio receiver that mounts inside. The nice thing is that the received has a remote display option that uses 10 pins. I believe this is some kind of serial RS-232 interface, however I can't confirm that just yet. It also has another 10 pin connection on the receiver that connects to something other than the remote display.
If it is serial, software may be developed to read the thing with Labview. Anyone else interested in this?
Xenarc 7" USB Touch LCD / 3.06 GHz P4 / 512MB DDR / 250GB 7200RPM 16MB HD /
DS-ATX 220W / Centrafuse / GPS / XM / 802.11g: 6db / RF Keyboard
pastypyro is offline   Reply With Quote
Old 02-17-2006, 07:11 PM   #13
Raw Wave
shotgunefx's Avatar
Quote: Originally Posted by pastypyro
Major bump...
I wonder if it actually uses all 10 pins. I would think it's serial myself, but might be byte oriented.
Old 02-17-2006, 07:13 PM   #14
pastypyro's Avatar
It may, as the 10th pin could be +12V for the remote display?
I'm not sure. I might get at the thing with a scope and a couple buddies soon. We have it installed on a car for a university research project that I'm putting a CarPC in and we'd like to monitor all of our information in teh vehicle with our PC, including this.
Edit: I now believe it is serial. I looked up the specs on one of the IC's inside the remote display and it is a serial transmitter utilizing RS-232 and RS-485 I believe. I have never heard of the 485 before, but I'll see what I can do about it.
How2 control CarPC from key fob.... NotchbackVW Power Supplies 1 09-21-2007 06:27 PM
A few observations in OS and why I'm now using Windows 2003... Mastiff Software & Software Development 12 01-21-2004 10:11 AM
Super small PC barebone system... your views? Techy Ben General Hardware Discussion 7 11-23-2003 02:32 PM
My PC plans - anything wrong with this system? mx270a General Hardware Discussion 15 09-02-2003 07:32 PM
controling ac system with car pc sugarmychurro General Hardware Discussion 4 05-21-2003 02:17 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
