I use Girder and an IR-Man for my Pioneer remote (until I can finnish my Pioneer CD-Changer emulator code that is). I have the remote that comes with the P1R head-unit (it has buttons 1-6 on the top and a lot more buttons than the standard Pioneer remote). Unfortunatly Pioneer remotes send 2 packets of IR data for a lot of the buttons. The first packet is the same for all the buttons, and the second packet lets you know which button it really is. The result is that the IR-Man is not smart enough to tell the differance between a lot of the buttons.
The IR-Man works for Up, Down, Left, Right, Select, plus one more for all the other buttons (1-6, Function, Audio, PGM, and all the other buttons are all recognized as the same button by the IR-Man).
Actually the CD, Aux, Tuner buttons all send unique codes and I believe the Volume buttons do too, but I can't map those to the CarPC because they control my Pioneer head-unit (The other buttons I do use for the CarPC do nothing to the Pioneer head-unit when it is sourced to AUX).
Eventually I will have my CarPC emulating a CD-Changer and then I won't need an IR-Man plus all of the buttons will work (plus I can have the PC display text, time, and disc/track numbers on the Pioneer head-unit).
