Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 05-28-2005, 03:33 PM   #1
tyRion's Avatar
Question Car Start on Finger-Print Recognition?
Would it be possible to do this?
Either 1) Wire a Finger-Print scanner to the pc, so it only boots if a fingerprint is picked up, then start the car, via a line out(LTP?) to a relay, would mean PC would be on before Car PC
Or 2) Wire the scanner to the relay for starting the car directly, then the PC boots like normal
In the first case you'd need a button to start the car, but in the second one it'd just start when the print was recognised.
These sites may be helpful, Print-Readers or Bio-link U-Match
Edit: I also just found this, which may be of some use, considiring it dosent need the PC to be on
tyRion is offline   Reply With Quote
Advertisement Sponsored links
Old 05-28-2005, 07:25 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Try searching the forums with terms "fingerprint". There's a big thread on the MS fingerprint reader there.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 05-31-2005, 12:58 AM   #3
problem with going straight from the scanner to ignition is that you would have to have a dedicated system. one idea is that there are scanners for home doors that controll relays to unlock the door. you may try something like that and just run the relay connection to the ignition. personnaly id just run straight through a computer with biometric login and a startup program signaling relays through one of its ports.
Absolution is offline   Reply With Quote
Old 05-31-2005, 05:39 PM   #4
tyRion's Avatar
Ok, I wrote a program to put on the CPU of the UniFinger™ SFM3000.
Its written in BASICA or GW-BASIC which is the only code I know off by heart, here it is, please point out any mistakes
Code:
10 if in5<>1 and in4=1 let x=1 else let x=0 20 in in1=1 and x=1 let y=1 30 if v=1 let y=1 40 if x=0 let y=0 50 let v=0 60 gosub 170 65 if in3=1 and in2=1 let y=0 70 if y=1 and in2=1 goto 90 80 goto 10 90 let y=2 100 let v=1 110 for w = 1 to 50 120 if in3=1 goto 10 130 next w 140 gosub 170 150 let y=1 160 goto 10 170 if y=0 let out1=1 else let out1=0 180 if y=1 let out2=1 else let out2=1 190 if y=2 let out3=1 else let out3=1 200 return
Here are the varibales and inputs I'm using (you can use 8, which i have 5 in, 3 out, though out1 is probabally unnecissary)
Code:
in1 Thumbprint Match signal in2 On/Off PTM stitch in3 Engine running sensor in4 Drivers Door PTM (Closed gives value of 1) in5 Alarm Indicator singal (1 is alarm on) out1 Off out2 On/Drive out3 Ingition v Remember ignition position from loop w loop x Door and alarm OK y Key state
The line ins or outs may have to be linked to relays or optoisolators
Old 06-10-2005, 08:45 PM   #5
emdzey01's Avatar
just remember to take care of your thumb... if someone cuts it off they can run away with your car
Brushed Metal for Centrafuse 1.4
Brushed Aluminum for Centrafuse 1.4
xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
emdzey01 is offline   Reply With Quote
Old 06-10-2005, 09:30 PM   #6
Banned
xdjxklusivex's Avatar
we will need to keep a spare thumb ;-)
xdjxklusivex is offline   Reply With Quote
Old 06-10-2005, 09:39 PM   #7
binary.h4x's Avatar
actually, you can bypass the fingerprint biometrics with a gummybear.
binary.h4x is offline   Reply With Quote
Old 06-10-2005, 10:07 PM   #8
SickVette's Avatar
It would be proably be best to use an aftermarket car remote start system. There is more to starting most cars then just the ignition wire. Many remote starts can be activated with a neg pulse and that would cover all the relays, safety shut offs, starting and stopping the car.
SickVette is offline   Reply With Quote
Old 06-21-2005, 04:03 AM   #9
emdzey01's Avatar
gummybear? ill have to try that out sometime.
and yeah, you should keep spare thumbs in your wallet, just in case you leave yours inside your car.
Old 09-07-2005, 07:15 AM   #10
Fingerprint car immobilizer
Hello,
look what i found...fingerprint to start cars..
visit www.automobile-security.com
Looks real..
what do u guys say?
peterthomas is offline   Reply With Quote
Old 09-07-2005, 08:13 AM   #11
Neither darque nor pervert
DarquePervert's Avatar
Quote: Originally Posted by peterthomas
Hello,
Looks real..
what do u guys say?
PRetty cool. It appears to be a remote start and/or keyless entry that uses a fingerprint reader instead of the traditional remote on a keychain. Their mounts are pretty ugly, though.
It also doesn't have a full-fledged PC that's on all the time sucking your battery down to the point of inoperability.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-07-2005, 05:32 PM   #12
It sounds cool but after working with biometrics in a hospital primarily for medication security, there is no way I would use biometrics to secure anything I wanted to reliably access. I'm sure there are overrides, but the failure rate of the hardware (the biometric reader) is horrendously high.
It's great when it works but a PITA when it does not!
ficklerx is offline   Reply With Quote
Old 09-07-2005, 09:32 PM   #13
Any bad guy who has seen the movie "Demolition Man" is gonna get ideas...
Bob T1 is offline   Reply With Quote
Old 09-08-2005, 12:01 PM   #14
the new lexus ls400 has fingerprint recognition, but i think it only unlocks the car.
2001 Acura CL traded for a 2006 Subaru Legacy GT
7" Lilliput Touchscreen
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
relocated HU faceplate
acura cl is offline   Reply With Quote
Old 01-02-2006, 11:20 PM   #15
Fusion Brain Creator
spammer!
greenman100 is offline   Reply With Quote
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 10:11 PM
Car Stereo Installation Video's for Sale johnram Classified Archive 2 09-05-2002 11:27 PM
New toys for the pc car gizmomkr General Hardware Discussion 10 02-06-2002 05:55 PM
can I power a car stereo with an ATX PSU? Fourgig General Hardware Discussion 9 10-03-2001 09:53 AM
System Restarts whenever I start my car Blue Falcon Power Supplies 24 06-25-2001 06:15 PM
