Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 06-25-2005, 04:09 PM   #1
jessebs's Avatar
110v or 220v AC to 12vDC converter
If I made a couple of these, would anyone be willing to buy them?
Basically, I use it to power my carputer usings its internal (12vdc) power supply, so when I bring it inside for development, I dont have to bother with connecting a standard ATX power supply.
It is somewhat similar to http://www.hobby-warehouse.com/in10ashepows.html in functionaliy (but not adjustable output).
Not sure the exact ampres out yet, but it will be at least 10
Price for such a unit would definately be <$50, Probably closer to $20 or $30.
If anyone is really interested, I can look into this and estimate the price better.
[###########--] 85% complete - Software Installation
To Do: Complete Voice Recognition, transfer hardware into car and wire.
jessebs is offline   Reply With Quote
Old 06-25-2005, 04:39 PM   #2
evandude's Avatar
you can already buy power supplies that are designed to run car accessories indoors... typically used by HAM radio operators...
http://store1.yimg.com/I/teptronics_1851_77612990
you can get them with 10-20 amps output for reasonable prices... so you'd have to at least beat the price of those... (do a google search for "13.8V supply") not trying to rain on your parade or anything, because if you CAN sell them for $20 or $30 then i'm sure you'll have little trouble finding buyers on here. (including myself, perhaps)
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
evandude is offline   Reply With Quote
Old 06-26-2005, 01:44 PM   #3
jessebs's Avatar
http://www.mp3car.com/vbulletin/power-supplies/53112-power-converter.html is a link of how I made mine. If i marketed it, i would make it look alot better (and be safer).
Old 07-09-2005, 06:22 PM   #4
Banned
RPM_VR4's Avatar
I am very interested for <$50 (if you can keep it small). I use those 13.8V 3A-5A's at work all the time. We also use 10A ones but they are HUGH weigh A TON and cost $100+.
7A should easily do it. The biggest requirement is small size and low heat.
I really want it set up so that the 110V-13.8V is inside my shuttle cube (along with my Carnetix 12V regulator) and on the back there is a standard PC plug connector (along with a seperate connector for car battery input). That way when I am visiting someone, I can simply pull my CarPC out of the trunk and plug it into their TV to show-off my huge DiVX library of movies and TV running a full-screen interface on their TV!
RPM_VR4 is offline   Reply With Quote
Old 07-09-2005, 06:26 PM   #5
jessebs's Avatar
This is just a modified atx powersupply, so size and everything is that. Cost was going to be the price of the powersupply, plus my time (but not alot).
I dont think this is the solution you are looking for, sorry. Maybe try searching for a 1u atx power supply?
Old 07-11-2005, 01:52 PM   #6
Banned
RPM_VR4's Avatar
Well, in that case, have you ever heard of anyone making an ATX Y-Splitter with relays? I was thinking if the AC/DC is providing power, all of the ATX lines would be disconnected from the DC/DC, and if it is not then all of the ATX lines would be disconnected from it so the DC/DC can work and not blow up the AC/DC.
A switch (rather than relay) solution would be fine too, but where could I find a 2-position switch that can change all ATX lines (9 lines minimum) with enough amperage?
Old 01-06-2006, 11:23 AM   #7
Sales Manager
Hello everyone...as brief as I maybe. I am an American manufacturer of 12volt power sources [110vac to 12vdc from 30amps to 80amps].
My primary market is the RV Industry but I'd like to diversify into the Automotive Industry.
As many of your questions imply...you're looking for an inexpensive 12volt Power Supply and I have them.
Feel free to contact me directly at jsalvo@progressivedyn.com
I'd like to find out how to become affilliated with your industry so I won't have to find every chat room forum to attract business. Somehow find a distribution network to become associated with.
Thank you and best regards...Joec.
joecprogressive is offline   Reply With Quote
powering m1-atx dc via power outlet (USA 110V AC) dtran01 Power Supplies 22 01-13-2006 10:27 AM
Power Converter jessebs Power Supplies 4 06-24-2005 02:37 AM
FS: Car Power Point , PSU, Power Supply DC - AC Converter m_lazell Classified Archive 0 03-21-2005 04:11 PM
WTB 70-75Watt 120 AC to 12VDC Power Brick komarak Classified Archive 0 12-23-2003 07:41 AM
DC -> AC converter question BRINET Power Supplies 1 03-25-2002 02:21 PM
