The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Thread Tools Display Modes
Old 07-08-2005, 09:36 PM   #1
freestyler's Avatar
Vehicle: 1997 Jeep Wrangler
My Photos: (0)
Motor circuit with reverse
Hey all, looking for some help here.
I want to build a circuit that when it gets power it will move a motor until it hits some sort of sensor. Then when power goes away it moves in reverse until it hits a sensor. I've been googling it but can't find too many good resources. If I can't figure this out I'd have to just use a toggle switch and stop the motor myself.
1997 Jeep Wrangler Rugged Waves
Ebay Stuff For Sale
freestyler is offline   Reply With Quote
Sponsored Links
Old 07-08-2005, 10:47 PM   #2
markland556's Avatar
Vehicle: 86' Mercedes 300E
My Photos: (0)
you could do this with a few relays and some spst switches.
86' Mercedes 300E
Status..::... {######----}65%~~ paused
markland556 is offline   Reply With Quote
Old 07-08-2005, 11:58 PM   #3
kiltjim's Avatar
Vehicle: 2000 Subaru Impreza Outback Sport
My Photos: (0)
Ok, I'm fairly sure its way too late for this, but heres an icredibly easy to understand paint rendering
The red box is a latching DPDT relay. The green liney thing on the left is a SPST relay, and the blue things are your switches to stop it from moving.
Now, I'm not entirely sure it would work, but I'm not gonna worry about that now. Maybe tomorrow morning.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 07-09-2005, 12:28 AM   #4
kamikaze2112's CarPC Specs
kamikaze2112's Avatar
Vehicle: 99 Pontiac Sunfire
My Photos: (0)
while not quite sure what you are trying to accomplish and how, but i believe i read something somewhere that you could control a stepper motor via parallel port quite easily...
kamikaze2112 is offline   Reply With Quote
Old 07-09-2005, 12:44 AM   #5
Admin
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
You can use a mini-SSC controller to run a servo. You can control how far it goes. If necessary, you can use a continuous rotation servo. The controller is accessible via VB and the serial port.
What is the application of the motor?
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 07-09-2005, 03:08 AM   #6
My Photos: (0)
this circuit should work. it better both the switchs are normally closed even though the diagram doesnt look like it. M$ paint isnt really that good. And im watching blind-date right now so im kinda preoccupied.
86' Mercedes 300E
Old 07-09-2005, 10:34 AM   #7
freestyler's Avatar
My Photos: (0)
well i have two different applications for it, one for moving an LCD and the other is to possibly rotate an antenna
Ebay Stuff For Sale
Old 07-09-2005, 04:27 PM   #8
freestyler's Avatar
My Photos: (0)
Could you explain this a little bit? Are those SPST or SPDT relays?
Thanks.
Ebay Stuff For Sale
Old 07-09-2005, 09:56 PM   #9
freestyler's Avatar
My Photos: (0)
I tried building that circuit using SPST relays, it didn't work right.
What I need is so that when you give it power the motor spins up, then when it hits the first switch it stops.
When you kill the power to the circuit it spins in reverse until it hits the second switch.
Back to the drawing board I guess, I burnt up one SPST relay though
Ebay Stuff For Sale
Old 07-10-2005, 01:44 AM   #10
kiltjim's Avatar
My Photos: (0)
Did you try mine? The SPST relay should stop the current, until the Accessory power is lost. Then the reset coil would become energized, and would run until the sensor was tripped. Then the whole thing would wait until the reset was triggered (power to ACC was lost) and would run until the second sensor was triggered.
2000 Subaru OBS
Dell P3 @ 900 Mhz
80GB External HD
Sponsored Links
Old 07-10-2005, 11:18 AM   #11
freestyler's Avatar
My Photos: (0)
I didn't try it because I was having a hard time understanding it.
I was talking with my cousin and he said it'd probably need a few more relays, like 3 or 4.
Ebay Stuff For Sale
Old 07-10-2005, 06:51 PM   #12
My Photos: (0)
im sure mine would work, but i diddnt really finish, if you really want me to make you one i will.
86' Mercedes 300E
Old 07-10-2005, 07:29 PM   #13
freestyler's Avatar
My Photos: (0)
i would appreciate it, I haven't had much luck trying to figure it out. I can build it, just can't design it
Ebay Stuff For Sale
Old 07-22-2005, 01:42 AM   #14
DjDrewDigital's Avatar
Vehicle: 02 Jeep Wrangler X
My Photos: (0)
Hey freestyler,
What do you have in mind? You said something about moving an LCD?
I'm doing something similar. I'm using a microcontroller to drive 4 servos. The servos have feedback sensors built in so I don't need any switches to stop the motors. Check out my prototype:
http://www.mp3car.com/vbulletin/showthread.php?t=55392
---> '02 Jeep Wrangler Jeeputer Install:
http://www.mp3car.com/vbulletin/showthread.php?t=80695
DjDrewDigital is offline   Reply With Quote
Old 07-22-2005, 07:37 AM   #15
freestyler's Avatar
My Photos: (0)
Quote: Originally Posted by DjDrewDigital
Hey freestyler,
interesting, very simliar to what I'm doing, however I'm going for more a more cosmetically appealing solution with a fiberglass bar to add to my soundbar I made.
I haven't had time to work on this, too much wedding planning lately. Hopefully this weekend I will be able to revist it.
Ebay Stuff For Sale
Sponsored Links
vB code is On
Trackbacks are Off
Displaying reverse camera on a carputer? coachreed LCD/Display 47 04-22-2008 05:47 PM
Anyone give me an approximate of the draw of reverse lights? aoLhaTer General MP3Car Discussion 26 11-20-2005 09:55 AM
K301 Reverse cam wire keanpedersen LCD/Display 3 08-15-2005 04:53 PM
reverse cam on xenarc video2 kuo General Hardware Discussion 2 05-29-2005 12:33 AM
reverse sonar - anyone install an aftermarket kit? aoLhaTer General Hardware Discussion 1 05-16-2004 05:58 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
