Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 07-13-2005, 08:10 AM   #1
Micv is on a distinguished road
Steering Wheel Control
I've but haven't found a useful thread regarding how to make the factory steering wheel audio controls buttons functional, when a resistor network is used. I don't want to use the IR solution, but need something that can make these different voltages into simple keystrokes. Is it doable?
Micv is offline   Reply With Quote
Old 07-13-2005, 08:32 AM   #2
dan__wright's Avatar
dan__wright is on a distinguished road
welcome to the foums. you should find it if you searcha bit more because i have asked the same.
you need an analogue input board, and connect that to the resistor network, you can then set diff voltages for each action.
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
dan__wright is offline   Reply With Quote
Old 07-13-2005, 09:13 AM   #3
just looked at your thread (Corsa ....), but swix solution is IR. The gamepad solution is not possible because these buttons aren't seperate. It is just 2 wires, when buttons are pushed:
Vol - 54 Ohm
Vol + 147 Ohm
Mode 1036 Ohm
Mute 2007 Ohm
Preset 562 Ohm
^ 300 Ohm
No buttons pushed 5kohm
I'm sorry if I didn't understand you correctly.
Old 07-13-2005, 12:45 PM   #4
Raw Wave
edrex's Avatar
edrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud of
http://www.mp3car.com/vbulletin/show...&highlight=SWC
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
edrex is offline   Reply With Quote
StevieG's Steering Wheel Control Software stevieg Software & Software Development 21 08-01-2009 09:58 PM
FAQ: Hacking Your Steering Wheel Buttons to Control Your PC Bugbyte The FAQ Emporium 77 12-23-2008 08:29 AM
Using steering wheel controls to control mini mac? brandondente MacCar 7 05-12-2005 10:50 AM
GM Steering wheel control interface S7347H Input Devices 1 04-14-2005 02:17 AM
Wireless control for steering wheel DodgeCummins General MP3Car Discussion 1 02-15-2002 02:14 PM
