Do you already have a FET-based isolator or do you already have it? In any case, here is one with schematic.
It is the DuoCharge from Balmer
Digital Duo Charge (DDC-12/24)
Say “so long” to switches. Put your isolator on “ice”.
The Digital Duo Charge delivers a smarter, safer and
faster way to care for your batteries.
Four built-in battery programs – Deep Cycle Flooded,
AGM, Gel and Standard Flooded – safely maintain
two battery types from the same charging source!
Unique FET-based control virtually eliminates voltage
drop while delivering up to 30 amps, so your batteries
reach full charge quickly. Should greater charging
power be required, the Duo Charge can be used to
control a separate solenoid.
Battery temperature sensing (with optional sensor)
adds even greater safety. Minimal “sleep” draw of
14mA when house voltage is less than 13V. Working
draw is just 25mA. Epoxy potted circuitry in a durable
anodized aluminum heat sink. Measures 4.6"L x 3.2W
x 1.5"W. One year limited warranty.
*Requires Battery Temp. Sensor (MC-TS-B).
They have a schematic @
http://balmar.net/page20-Duocharge.html. They also were supposed to release the Duo-Charge II, a fancier version of the first, in the Spring.
