Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 08-23-2005, 07:40 AM   #1
djmickyg's Avatar
djmickyg is on a distinguished road
usb flash drive issues??
ive just bought a 1gb usb flash disk thngy and i plug it into my usb unpowererd hub and it says.. this item cant operate because it needs more power.. needs 200ma my hub puts out 100 per port
my understanding is these things will run on 100ma but the speed is limited??
it is a usb2 device.. but once again if i plug it into a usb1 hub it should just limit the speed yes?
i have used other ones in the same hub, but they werent as big as 1gb
is this usb stick thing just cheap and power hungry or is it doing what its ment to do
djmickyg is offline   Reply With Quote
Old 08-24-2005, 03:12 AM   #2
sy_pug306's Avatar
sy_pug306 is on a distinguished road
i've had a similar problem when trying to connect usb keyboards and mice i've found that they just don't work unless pluged into there own port on the pc.
I think with your situation that the smaller sized pen drives don't need as much power and so will work via a hub, but the 1gb and above use alot more power and so won't work.
You are right that the hub being usb 1 will slow things down but that wouldn't be the reason for the drive not working.
sy_pug306 is offline   Reply With Quote
Old 08-24-2005, 03:26 AM   #3
djmickyg's Avatar
i have used this usb thing on my dads 4 port unpowered hub.. so i know it should work
i went to buy a 4 port usb2 hub 2day hoping that will fix it.. and the guy in the shop said for sure it will work.. but yet agian.. no work
i looed in the settings.. all i have in the hub is my touchscreen and thats only using 100ma so there is a bit of power still left for it..
Old 08-27-2005, 11:14 PM   #4
Stacker is on a distinguished road
Have you tried plugging it into other ports on the hub? I know one of the ports on my home powered USB hub will power my mouse but not anything else I plug in, yet the others seem to do fine. Possibly in the current distribution within the hub?
Stacker is offline   Reply With Quote
Old 08-27-2005, 11:27 PM   #5
djmickyg's Avatar
interesting... i may have to give that a go..
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Can the Kaser 2.2GB Jumbo USB 2.0 Drive be a fixed drive? wardemon666 WinNT Based 0 08-16-2005 02:47 AM
stupid usb slimline DVD drive ummagawd General Hardware Discussion 4 04-26-2005 02:57 PM
USB drive Array? EBFoxbat Software & Software Development 10 02-12-2005 03:37 AM
External USB drive mtmsol General Hardware Discussion 11 11-27-2001 06:25 AM
