As far as an automatic trigger, most systems have an infra-red transmitter on the side of the track or a loop embedded in the track. I tried it using a remote control kit (as in a car alarm style one) but it wasn't real accurate. Probably the easiest is the infra-red transmitter. You can make one out of a dolphin torch and some IR leds. There should be quite a bit of info on the net about making IR floodlights, which is the same thing.
You then need a receiver in the car and then have it trigger your data pins in your serial or parallel port. Then all you need is to count the time between the pulses. You could probably write a crude app in VB to do this for you.
Note: Some track officials can get quite funny about timing yourself at trackdays. Been there and done that.
Hope this helps
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
