Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 10-23-2005, 08:17 AM   #1
slimmegane's Avatar
slimmegane is on a distinguished road
Can I pull out 200mA from serial port of Epia 10000?
Can I pull out a 200mA current from serial port of Epia 10000?
I want to power the Axiom OEM GPS module direct from Serial Port.
ITALIANI: DISPONIBILI MODULI OEM GPS:
http://www.mp3car.com/vbulletin/show...214#post639214
slimmegane is offline   Reply With Quote
Old 10-23-2005, 11:02 PM   #2
mushin's Avatar
mushin is on a distinguished road
I doubt you can get that much current from any serial port, regardless of MB. The quick search I did turned up around 10mA as the max for most boards. Why don't you just draw power directly from the PSU?
mushin is offline   Reply With Quote
Old 10-23-2005, 11:12 PM   #3
kiltjim's Avatar
kiltjim is on a distinguished road
You could pull it from the PS2 or USB port. I have my serial GPS running off of the PS2 port. Run the connection into a custom made serial connection, and then out by a really long headphone cable I had broken. Its been working for a really long time too.
(And who uses PS2, seriously? )
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 10-24-2005, 08:28 AM   #4
slimmegane's Avatar
Thanks, now I use the PSU +5v, my question is only to make a unique cable for data Rx/Tx and Power supply.
Thanks.
Old 10-24-2005, 08:52 AM   #5
Gutter's Avatar
Gutter is on a distinguished road
*Feebly raises hand*
Don't Click
Gutter is offline   Reply With Quote
Old 10-24-2005, 11:25 AM   #6
kiltjim's Avatar
@Slimmegane:
You shouldn't need both a Rx and Tx cable. You are only going to be recieving data from the GPS aren't you? Or does it have some kind of programming feature to it? And where are you going to be putting it? I have my GPS tucked under the dash, and the computer in the trunk. This means I have something like a 6-7 meter cable running the length of the car. I just used a shielded headphone cable. One end has a DB-9 connection on it, with a short PS2 cable hanging out of it. You could just put a power connector on instead of the PS2 connection.
@Gutter:
Hey, I wasn't talking to you! Get back in your cage!
2000 Subaru OBS
Dell P3 @ 900 Mhz
80GB External HD
serial port to game port adapter wiring asif General Hardware Discussion 5 08-17-2006 05:47 PM
Epia 10000 memory Vagabond Newbie 8 09-02-2005 12:21 PM
VIA EPIA MII 10000 vs. M 10000 imprezive one General Hardware Discussion 8 03-02-2004 10:17 PM
serial o lpt port adaptor pcman General Hardware Discussion 0 08-24-2000 06:50 AM
1 serial port, 2 devices Meatballman General Hardware Discussion 7 04-16-2000 11:50 PM
