Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 11-22-2005, 07:07 AM   #1
(6)
(6)'s Avatar
Question XM Direct question
Inside the xm direct housing the board isattached to the side of the housing. Is this neccesary to be touching the housing wall?
(6) is offline   Reply With Quote
Advertisement Sponsored links
Old 11-22-2005, 07:25 AM   #2
MySQL Error
jcdillin's Avatar
You mean the voltage regulator that is bolted to the inside? If your going to run the XMD without a case I would at least put a small heatsink on that reg i've had mine get pretty hot at times
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 11-22-2005, 05:32 PM   #3
(6)
(6)'s Avatar
Question
What kind of heatsink do you recommend i use so this wont over heat not using the case?
Old 11-22-2005, 06:14 PM   #4
MySQL Error
jcdillin's Avatar
something like this would work fine
http://www.electronics123.com/s.nl/s...t.A/id.1078/.f
肚子笑痛了
S60 Install
Problems with XM Direct Cable HummDinger General Hardware Discussion 5 07-08-2005 10:16 AM
Xm Direct Cable Ready For Shipping!!! HybridMike General Hardware Discussion 104 07-06-2005 10:58 AM
XM Direct timeout? problem eleventh Hardware Development 0 01-23-2005 08:38 PM
XM Direct optical out to Catalina question Lord_Pall General Hardware Discussion 0 01-16-2005 07:16 PM
XM Direct Epia line in bjm2020 General Hardware Discussion 1 12-27-2004 11:03 PM
