Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 02-17-2007, 05:30 PM   #166
SmoL is on a distinguished road
i think i'll stick with the silabs, at least its a name you can trust and not homebrew, so even thought its r&d the support is still there
SmoL is offline   Reply With Quote
Old 02-17-2007, 05:37 PM   #167
crispyrabbi's Avatar
crispyrabbi is an unknown quantity at this point
Is it just me that gets no sound after changing frequency in radiator. I am using radiator and the DLL that you can find in a link to somewhere in this post. It works fine until you try to change the frequency. Then you get no sound and radiator freezes when you try to end the program. If I kill the radiator.ini file I can use the program again.
The silabs device has good reception in stationary use. Havnt tried it in the car yet.
AOPEN MINIPC 945 VXR, CORE DUO T2400, 512MB, 120GB, Wlan, CARNETIX CNX-P1900, 1020TSV TFT 10.2" Touchscreen, BU-353 GPS, wlan-antenna, X3 integration to HU, D-link DUB-H7 USB 2.0 Hub, Wireless RF-keyboard, Logitech USB noicecancelling mic, NV RVcam
crispyrabbi is offline   Reply With Quote
Old 02-17-2007, 09:48 PM   #168
umpculi's Avatar
umpculi is on a distinguished road
Thumbs up
hi evryone, just wantd to share my experience. I am using silab usb fm on my car nothing special just striped wire from car antena connectd with silabs antena and reception is close to perfect. i used it for awhile without connectng it to car antena it was almost useless because i had to hola it to get reception. Im using it with RR n radiator with digital fx skin. No rds on skin neither on radiator. Reception minimally changed with speed, id say 10%. I am very happy with my buy and install. thanks for the guidance guys i wouldnt b enjoyn it without this thread. keep up the gud work. HOPE TO SEE RDS ON ME RR!!!
http://weekendtechs.net
umpculi is offline   Reply With Quote
Old 02-18-2007, 12:06 AM   #169
royandrews is on a distinguished road
In aussie?
How do I get hold of these in aussie? Sydney to be precise.
I e-mailed the Sydney office of that distributer whose name starts with 'B' (whatever its called) but they won't respond.
I want one of these!!!!
royandrews is offline   Reply With Quote
Old 02-18-2007, 12:11 AM   #170
they are called braemac, i ordered from their syd office aswell. Give em a call
Old 02-18-2007, 12:14 AM   #171
I havent had the problem, but i think someone posted previously said something about usb devices, unplugging something, not really sure??
i've noticed that there are 2 different dll'd for radiator on here. I've got this one and it works ok.
http://www.alibri.it/RRMobile/Silab%20USB%20Radio.htm
let me know how you go with that
Old 02-18-2007, 01:01 AM   #172
Yeah, that's the one. Will give them a call. Thanks.
Old 02-18-2007, 03:36 AM   #173
NiSlo's Avatar
NiSlo is an unknown quantity at this point
Ask for Lisa Diaz. She was the one that helped me out.
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 02-18-2007, 06:04 AM   #174
I have tried with two different dll:s with no success. Are you supposed to just copy the dll in your plugin dir or all of the files in silabtest?
It still locks up after you have changed the frequency. Works fine with the silabs original program.
Old 02-18-2007, 07:39 AM   #175
I thought maybe the fault is in my carpc setup so I tried to launch radiator in a stationary computer but it wouldnt even start. I get som Eaccess error so I cant even start radiator.
The silabs original program works fine. I figure radiator must be some extremely buggy program. Or am I missing some crucial install? Some codecs that have to be installed or something else?
I thought the only installs where the radiator package and the dll file.
Are there any alternatives to radiator if I want to use silab in RR?
Old 02-18-2007, 02:01 PM   #176
portreathbeach is an unknown quantity at this point
USB radio frequency error!!!
Been playing around with the USB radio for a bit and have noticed a small problem with my radio...
In my house 'Radio 1' is at 99.30MHz, a local station 'Pirate FM' is at 102.80MHz. Any radio I use, auto tunes to these frequencies. The USB radio is .10 MHz out, which is pretty anoying. This is the same with every radio station it tries and tunes too.
Anyone else had this with there radios?
portreathbeach is offline   Reply With Quote
Old 02-18-2007, 08:20 PM   #177
umpculi's Avatar
Smile
Did u switch radiator settings to use external dll? check config on radiator program folder if you can see external driver=usbradio.dll. Gud luck!
Old 02-19-2007, 02:43 AM   #178
have you tried not using the search functionality and tried manually incrementing by .10mhz??
you could also set it up as a preset.....
Old 02-19-2007, 12:34 PM   #179
SUNAJ's Avatar
SUNAJ is on a distinguished road
Quote: Originally Posted by Bj View Post
Mouser still sells them - I got mine the other day.
These little tuners are fantastic! It performs 1 billion times better than any of the previous usb radios I have used. I attached an external antenna (75 ohm) to a standard house type splitter between my tv tuner and the silabs. I used to use the magic box pro for FM, but the performance (even though it was the best I had found at that point) is absolutely no match to the quality and signal strength of this tiny little radio! And to make things even better it supports RDS.
Here is the antenna mod I did...
Fitted in car
Here it is running a full 75 ohm system and splitter to both the silabs and the DVBT tuner part of the magic box pro
The only issue I have found is that the RDS info is all jumbled up, or it doesn't refresh at the rate it comes in at. I downloaded the demo from this thread, and all I get it chopped up sentences, it seems that the data coming in is scrolling, but the app can't refresh at the same rate as the scrolling....
Any ideas on this?
Other than that I have got this functioning in my car, all but the rds..
I'm using the vb6 example from a thread I can't find now, but thanks to whoever it was
Where dit you get the Silabs USB tester program? cannot finde it
SUNAJ is offline   Reply With Quote
Old 02-19-2007, 12:40 PM   #180
Frankino's Avatar
Frankino is on a distinguished road
how's the reception while moving?
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Frankino is offline   Reply With Quote
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
FS: USB TV / FM Tuner, haupauge usbtv e36mp3 Classified Archive 5 11-18-2004 11:03 AM
USB FM solution good or crap? Jake General Hardware Discussion 2 10-03-2002 02:56 PM
