Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 03-10-2007, 02:39 AM   #196
jjnit's Avatar
jjnit is an unknown quantity at this point
Well, I received mine today from mouser... have not yet connected an external antenna but results driving around with the little wire hanging off of it weren't too bad. Going to get parts perhaps tomorrow and connect to my oem antenna in the truck and see what happens - if we're good then bye-bye head unit, hello "stock-look" dash LCD!!! (with some work of course)
I'm in Atlanta and live by my radio - the only reason I've put off getting rid of the HU. Hopefully this solves that.
GeorgiaCarry.org Member
jjnit is offline   Reply With Quote
Old 03-10-2007, 09:36 AM   #197
hari-bhari can only hope to improve
where did you guys get the antenna socket. i went to radio shack and they didnt have one. is there a good place to buy it online?
hari-bhari is offline   Reply With Quote
Old 03-10-2007, 08:14 PM   #198
SmoL is on a distinguished road
good to hear jjnit, can't wait to hear your results. if you get a chance can you take a sound recording for us and post it aswell??
SmoL is offline   Reply With Quote
Old 03-11-2007, 12:16 PM   #199
grayvader's Avatar
grayvader is on a distinguished road
Got mine from mouser a while back and finally got an antenna socket from Fry's yesterday (I just bought the 18" generic antenna extension cord for $3). Cut the pointy end off and soldered the ground shield into the big hole next to the antenna hole (on the little USB card). Both the antenna signal wire and the ground wire (all twisted together) fit quite nicely. Anyway, I plugged it into my labtop and the antenna in my f150 and it works GREAT!
I can't imagine anyone needing to go further for a radio. As soon as all the good frontends' support improves, i think we'll have a real winner. No need to go through all the trouble of the HQCT module if you ask me.
grayvader is offline   Reply With Quote
Old 03-11-2007, 03:44 PM   #200
geeky_hawkes is on a distinguished road
I second what grayvader has said above really. IM using it connected to my car aerial and the quality is fine, im using it in streetdeck and the integration isnt too bad either! (Especially for 1 £10 card!)
geeky_hawkes is offline   Reply With Quote
Old 03-11-2007, 03:57 PM   #201
lez
lez's Avatar
lez is on a distinguished road
ehh?
Whats £10, and what card? its a dongle and its £27 !
lez is offline   Reply With Quote
Old 03-14-2007, 03:34 AM   #202
Fantastic News!
Old 03-14-2007, 06:39 AM   #203
lez
lez's Avatar
Quote: Originally Posted by SmoL View Post
Fantastic News!
what is ?
Old 03-14-2007, 05:43 PM   #204
Card or dongle, i mean its a usb device (not splitting hairs!) And i got it for £10 so happy with that! Even for £27 its worth it though!
Old 03-16-2007, 03:13 AM   #205
the guy with good reception, thats what
Old 03-19-2007, 01:22 PM   #206
jjnit's Avatar
CRAP!
Well I went out this weekend to do a lot of stuff on my install, part of which was to connect this to the factory aerial. Here's a pic of my soldering job which I thought was pretty good honestly.
I thought it was all good but sometime about an hour after I did it it stopped working, must be a cold joint or something.
Soo - I;'ve got to go back and fix it next weekend (I'm assuming it's a bad solder and that I didn't ruin the board) before I can test results.
I did sheild left and center right - that's correct isn't it? Sort of odd since the PCB doesn't have a trace to the pad that I soldered the sheild to?!?!
Bj/Iceman - any advice?
Thanks!
Old 03-19-2007, 01:41 PM   #207
dudeness is an unknown quantity at this point
Without reading all sites...
...is this radio working with hibernate?
dudeness is offline   Reply With Quote
Old 03-19-2007, 01:49 PM   #208
jjnit's Avatar
Yep. I've had an occasional issue(read: like twice in the last 3 weeks) but simply tune to another station and back and you're golden. Doesn't lock up or anything or need a reset.
Old 03-19-2007, 01:56 PM   #209
Cool, sounds good. The ADS Tech radio is constructed in the same way, so it also supports hibernate? (Silabs Programm works with ADS Tech Radio).
I cant find a shop which sells the silabs in germany (without 15$ shipping) so i hope the ads tech work also.
Old 03-19-2007, 01:58 PM   #210
jjnit's Avatar
Don't know enough about the ADS to say for sure but I don't imagine it will have any issues. You can always use software to disable the USB device causing issues before hibernating - I forget the name but it's pretty common on this forum...
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
FS: USB TV / FM Tuner, haupauge usbtv e36mp3 Classified Archive 5 11-18-2004 11:03 AM
USB FM solution good or crap? Jake General Hardware Discussion 2 10-03-2002 02:56 PM
