Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 03-19-2007, 02:06 PM   #211
I never heard from this programm but it sounds good. I try to buy a silabs, so im sure the hibernate works well
dudeness is offline   Reply With Quote
Old 03-19-2007, 02:24 PM   #212
jjnit's Avatar
Devcon it seems is the name of it: http://support.microsoft.com/default...;EN-US;Q311272
GeorgiaCarry.org Member
LinkedIn Profile
jjnit is offline   Reply With Quote
Old 03-19-2007, 02:38 PM   #213
Quote: Originally Posted by hari-bhari View Post
where did you guys get the antenna socket. i went to radio shack and they didnt have one. is there a good place to buy it online?
http://www.partsexpress.com/pe/showd...number=090-455
you can also find one with a long cable if you need it!
4 foot
http://www.partsexpress.com/pe/showd...number=265-595
or 2 foot
http://www.partsexpress.com/pe/showd...number=265-596
davidingermany is offline   Reply With Quote
Old 03-19-2007, 02:47 PM   #214
Quote: Originally Posted by jjnit View Post
Ok thx. I'll try to understand the tool. I also found Hibernate Trigger. Here u can start a programm on and after hibernate.
Old 03-20-2007, 01:43 AM   #215
grayvader's Avatar
Funny you had issues too... I was trying to make my connection a bit more robust by anchoring it with electrical tape and the next time i plugged it in... Nothing. I'm going to have to take it into work with me to look at it under a 'scope to see if i trashed any traces or leads on the ICs. crap!
grayvader is offline   Reply With Quote
Old 03-20-2007, 05:18 AM   #216
jjnit did u put the plastic cover back on the board? i just hope you didnt short circuit it or something with a piece of metal behind your dash...
SmoL is offline   Reply With Quote
Old 03-20-2007, 10:34 AM   #217
jjnit's Avatar
Yep - I even put a 2" piece of heat shrink over the cover and zip ties to make it neater and maybe help insulate from vibration, etc.
I cut that away this morning to see if maybe something slipped and maybe fractured the lead but no.
I don't have a scope so I'll just desolder and redo in the next couple of days when i get a chance. I used a pair of hemostats around the pad as heatsinks so I don't think I burned up a trace? We'll see.
I was attempting to avoid adding an additional connector in line as Bj had on his images by going directly into the aerial lead, maybe that caused a problem too.
Regardless, this piece, as cheap as it is, is worthless to me if I can't get it connected to a decent antenna so I'll work on that this week
LinkedIn Profile
Old 03-21-2007, 09:07 AM   #218
GuMiSZu's Avatar
I have an ADS USB FM tuner (instant FM) it uses same chip (SILAB) but it doesn't work with SILAB reference driver/program. Anybody could help me ?
or
could you send your device driver to me? maybe...
thanks in advance
GuMiSZu is offline   Reply With Quote
Old 03-21-2007, 09:26 AM   #219
GuMiSZu's Avatar
Hmmm, my device name/ device id isn't good for this player (USBplayer.exe)
i need some hack on it... i think...
Old 03-21-2007, 09:31 AM   #220
BJ> Could you post your reception level using the App that a member here developed for stations which you receive very clearly.
I am getting values between 43-57 however there is still static on the audio
I have used a small signal booster (which gives a boost of between 5-10 points).
I'm trying to figure out if the signal strength value actually means anything, or if cable type (ohmage) is more important.
Iceman_jkh is offline   Reply With Quote
Old 03-21-2007, 03:39 PM   #221
Im using the ADS Tech Stick with Silabs Chip.. it works with Silabs software but i cant get it working with radiator. I downloaded the Silabstestpack in the plugins folder and have chossed the subradio.dll in radiator setting as external dll. But nothing happens? any ideas?
Old 03-21-2007, 03:58 PM   #222
jjnit's Avatar
Are you using the Radiator gui to test or RR?
Check what the Radiator output is mapped to in its config.
Sometimes it takes a channel change and then back for mine to produce audio after a boot - even static.
That's all I can think of that I've experienced - I'm sure others have more ideas.
LinkedIn Profile
Old 03-21-2007, 04:04 PM   #223
Im using the Radiator GUI atm. Where i can change the radiator output? I only can see the volume control. I restarted my pc serveral times and changed the channels with no result.
Old 03-22-2007, 03:11 AM   #224
have a look in the C file, it may be looking for a specific hardware name or part number before opening...
Old 03-22-2007, 07:56 AM   #225
almera's Avatar
AFAIK you should select Volume Control (Internal) option. And have you tried USBRadio.dll?
almera is offline   Reply With Quote
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
FS: USB TV / FM Tuner, haupauge usbtv e36mp3 Classified Archive 5 11-18-2004 11:03 AM
USB FM solution good or crap? Jake General Hardware Discussion 2 10-03-2002 02:56 PM
