Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 03-22-2007, 09:01 AM   #226
dudeness is an unknown quantity at this point
Quote: Originally Posted by SmoL View Post
have a look in the C file, it may be looking for a specific hardware name or part number before opening...
Hm i cant find anything. The C file is really big and my c skills are not so good.
@Almera: Yes, i tried the USBRadio.dll but nothing happenes when I use that .dll
dudeness is offline   Reply With Quote
Old 03-24-2007, 12:22 PM   #227
odyssey5 is an unknown quantity at this point
So what was the conclusion on the impedance problems by using a carantenna on this device?
I want to change the carantenna to a windowantenna - Or should i go for a different/better approach if i'm going to use this device?
If I order it from UK to Denmark it rates £35 incl shipping Didn't anyone get a load of the $5 ones?
Does it come with some standard connector or are the included antenna hardwired?
odyssey5 is offline   Reply With Quote
Old 03-24-2007, 09:53 PM   #228
DeLorean Dave's Avatar
DeLorean Dave is on a distinguished road
Have you guys tried the High Quality Computer Tuner, and if so, how does it compare to the tuner being talked about in this thread?
1981 DeLorean DMC-12
VIA SP13000, Xenarc 700TSV, 100GB hdd, 1GB ram, WinXP, BU335 GPS, iNav 3.0, Griffin PowerMate, M2-ATX, HQCT-AM/FM USB Radio (Software by Luc)
PMD-1208 USB Data Acquisition
Flux Capacitor
Kensington USB 2.0 BT Dongle just dangling
DeLorean Dave is offline   Reply With Quote
Old 03-24-2007, 10:01 PM   #229
Read a few pages back...
Old 03-25-2007, 08:34 AM   #230
AyrtonSennaD's Avatar
AyrtonSennaD is on a distinguished road
anyone know where i can found one i try all the link from this thread and they do not work also check the web and didn't find any.
thanks
AyrtonSennaD is offline   Reply With Quote
Old 03-25-2007, 12:42 PM   #231
grayvader's Avatar
grayvader is on a distinguished road
The SiLabs link didn't work? I just got 2 from mouser.com this week.
And with regard to the impedance question -- the standard motorola antenna plug that I put on mine works great. I'd say that the radio works at least as well as the Kenwood that I pulled out of the truck.
It doesn't come with an antenna to speak of. It has a piece of wire soldered into the antenna connection and it's plain terrible. You HAVE to solder something in to replace it if you want any reception.
"Wait a minute, Dave. Ah... Are you telling me you built a computer... into a DeLorean? "
Dave says?
"The way I see it, if you're gonna build a computer into a car, why not do it with some style? "
grayvader is offline   Reply With Quote
Old 03-26-2007, 09:28 AM   #232
Do you guys using the Silabs with hibernate? I have the ADS Tech radio and sometimes after hibernate i have to unplug and plug the stick in again. It seems a soundchip crashes
Its the some problem with the silabs one?
And does anyone know where i can buy it in germany/EU? Without 15€ shipping ;<
Old 03-26-2007, 11:09 AM   #233
jjnit's Avatar
jjnit is an unknown quantity at this point
Quote: Originally Posted by grayvader View Post
Funny you had issues too... I was trying to make my connection a bit more robust by anchoring it with electrical tape and the next time i plugged it in... Nothing. I'm going to have to take it into work with me to look at it under a 'scope to see if i trashed any traces or leads on the ICs. crap!
I attempted a "redo" this weekend to no avail. I'm going to order one more and try again - if I miss it then I'll just go find something else. Hate to do that though, even 2 of these cost less than the other solutions out there but I miss my radio and traffic reports.
Those of you who have successfully connected to a car antenna system - what could I be missing here. I know I redid the solder correctly.
Do I have to have a connector in line or will soldering directly on as I did work? Also - my truck has a dual antenna system (window and whip) - does this make any difference? Can I still use both of them from the radio lead or must I re-run directly to one or the other? If I must choose - which will give the best results - embedded window antenna or the whip antenna?
Now that I think about it more - I wonder if that is indeed the issue? Maybe the diversity system requires power or something from the radio? Don't see how but I'm grabbing at straws here - this is a great little device if you have it connected to a decent aerial it seems, and I really really want to get this tuner working and maybe it can help some of the others who are having this issue.
Thanks!
GeorgiaCarry.org Member
jjnit is offline   Reply With Quote
Old 03-26-2007, 01:01 PM   #234
what was the part number i try SI4701 but it wasnt the right product
Old 03-26-2007, 01:30 PM   #235
geeky_hawkes is on a distinguished road
I hibernate and it works fine. THe only thing i do with my carpc is exit the front end before hibernating thepc as Ive found it gives a more robust hibernate/startup solution. BUt the silabs works fine each time
geeky_hawkes is offline   Reply With Quote
Old 03-26-2007, 01:46 PM   #236
I need a Silabs Radio. Its such a crap that the silabs isnt avail in Europe. I have to pay ~80$ with shipping and duty. When im purchasing at mouser the duty costs are not included, right?
Old 03-27-2007, 12:59 AM   #237
grayvader's Avatar
Thanks!
I ended up buying another one. The board is very delicate -- I probably trashed something under a part because it was just too intermittant.
This time i soldered the antenna extension on carefully and managed to get it to fit perfectly in the hole on the side of the plastic housing. The housing holds it secure and I taped it all up nice and tight. All is GREAT now.
Now, about your dual antenna setup -- I have no idea. Is there a way to plug into one or the other to test?
Old 03-27-2007, 03:42 AM   #238
almera's Avatar
almera is on a distinguished road
Maybe you aware of this but just to remind you:
SILICON LABORATORIES USBFMRADIO-RD (1186925)
almera is offline   Reply With Quote
Old 03-27-2007, 03:47 AM   #239
Thanks! I diddnet know the shop yet. I will look into it (especally shipping costs)
Edit: I purchased the Silabs one for ~39€ with shipping and sales tax, i hope this shop can be used from everyone.. we will see.
Old 03-28-2007, 03:59 AM   #240
almera's Avatar
so you saved ~30USD
yeah anyone from Europe can buy from them.
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
FS: USB TV / FM Tuner, haupauge usbtv e36mp3 Classified Archive 5 11-18-2004 11:03 AM
USB FM solution good or crap? Jake General Hardware Discussion 2 10-03-2002 02:56 PM
