Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 03-28-2007, 05:05 AM   #241
SmoL is on a distinguished road
jjint , about your dual antenna. check to see how many antenna connections go to your head unit. i'm guessing it is probably one. If so the system is already set up to determine the best reception on the antenna so just plug you silabs rasdio into that lead and you will be set, no extra power required.
However, if there are 2 antenna connectors that means that your head unit monitors and makes logical decisions on which antenna to use. There is no way to replicate this without a homebrew type setup (i don't know gow to do it), so you would have to try both and just pick the best one for now.
I suggest looking at your head unit and see how many antenna connections you have, either way its a cheap and good radio so no harm in trying
SmoL is offline   Reply With Quote
Old 03-28-2007, 07:47 AM   #242
dudeness is an unknown quantity at this point
Yes, but a univerity access is needed. They want so see your confirmation of enrollment (dont know if its the right translation). I sent it via fax and hope i have the silabs soon.
dudeness is offline   Reply With Quote
Old 03-30-2007, 07:34 AM   #243
Ok i recieved my Silabs Radio. Works better then the ADS one, without this replug bug.
But i have a question:
Im using Radiator, its working good. But after hibernate the Radiator freezes and i have to restart it. Any Ideas? Hom i can start a radiator muted via console command? So i can fix my problem with HibernateTrigger.
Old 03-30-2007, 08:59 AM   #244
AyrtonSennaD's Avatar
AyrtonSennaD is on a distinguished road
so what is the product number on mouser.com ???
AyrtonSennaD is offline   Reply With Quote
Old 03-30-2007, 09:05 AM   #245
henkbliek's Avatar
henkbliek
Mouser: USBFMRADIO-RD
Farnell: 1186925
Newark: 98K2140
white bream
working on a trilogy: CARGO - UNIGO - MERGO
CARGO = the Car Computer
Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
henkbliek is offline   Reply With Quote
Old 04-01-2007, 01:24 PM   #246
davidingermany is an unknown quantity at this point
Ok stupid question time.. How do I get the SILABS to work in RR?
davidingermany is offline   Reply With Quote
Old 04-01-2007, 03:32 PM   #247
jjnit's Avatar
jjnit is an unknown quantity at this point
Install Radiator and use the USBRadio.dll file from this post: (http://www.mp3car.com/vbulletin/927410-post44.html) as the plugin. I think it was just a matter of unrarring the dll and copying it to the plugins folder under Radiator, restarting Radiator and selecting it in the Radiator options screen as the plugin.
I'm not in front of my Carpc right now but I think it was pretty self-explanatory when I did it.
GeorgiaCarry.org Member
jjnit is offline   Reply With Quote
Old 04-01-2007, 03:50 PM   #248
crispyrabbi's Avatar
crispyrabbi is an unknown quantity at this point
How to make it work has been described as above a couple of times and people claim that it work. I have tried it on 2 pc:s with just minor success.
Now I have got it installed in my carpc but its very slow when you go to the radio menu. The tuner may or may not work when you finally get to the radio menu. I also get a lot of mp3 songs in the playlist instead of radiostations.
Think the problem is with radiator and would like an integration of the original software that compared to radiator is fast to start, always works and tunes fast.
Someone has proposed that to guino so maybe it will be so in a not to distant future.
Good luck with radiatorinstall!
AOPEN MINIPC 945 VXR, CORE DUO T2400, 512MB, 120GB, Wlan, CARNETIX CNX-P1900, 1020TSV TFT 10.2" Touchscreen, BU-353 GPS, wlan-antenna, X3 integration to HU, D-link DUB-H7 USB 2.0 Hub, Wireless RF-keyboard, Logitech USB noicecancelling mic, NV RVcam
crispyrabbi is offline   Reply With Quote
Old 04-01-2007, 05:13 PM   #249
jjnit's Avatar
Quote: Originally Posted by grayvader View Post
I ended up buying another one. The board is very delicate -- I probably trashed something under a part because it was just too intermittant.
This time i soldered the antenna extension on carefully and managed to get it to fit perfectly in the hole on the side of the plastic housing. The housing holds it secure and I taped it all up nice and tight. All is GREAT now.
Now, about your dual antenna setup -- I have no idea. Is there a way to plug into one or the other to test?
Cool - I just snapped up another one too... will be much more careful this time around soldering. Did you solder your antenna directly in or use a disconnect in between?
My radio only had one connection to the setup even though it uses dual antennas, so I'm going to assume that mine will work fine wired directly in.
Results when I get my replacement in...
Old 04-01-2007, 09:54 PM   #250
grayvader's Avatar
grayvader is on a distinguished road
I bought an antenna extension cable at Fry's and cut off the pointy end. That left just the socket and about 14" of cable. Then I stripped some insulation and soldered the tiny antenna wire to the antenna hole and the shield to the big ground hole right next to it.
grayvader is offline   Reply With Quote
Old 04-02-2007, 12:05 AM   #251
GuMiSZu's Avatar
GuMiSZu is an unknown quantity at this point
HI!
I can't set up the radiator in RR, I've ADS USBradio (thanks dudeness for the plugin ) under windows the radiator is working without RDS function. Could you help me, where can I setup this function?
thx.. (any link is great also )
GuMiSZu is offline   Reply With Quote
Old 04-02-2007, 09:48 AM   #252
Ok, where can I get Radiator? I looked all over the site and it is mentioned everywhere but could not find a source.
Thanks all!
Old 04-02-2007, 09:49 AM   #253
http://flesko.cz/
Old 04-02-2007, 02:13 PM   #254
Thanks!
Old 04-03-2007, 04:51 AM   #255
odyssey5 is an unknown quantity at this point
Are any developer willing to create a foobar2000 plugin for this little thingy?
Location could be added like this: fm://88.9
A menu selection could scan all available stations and add them to a specific playlist (if a given station are not already added).
odyssey5 is offline   Reply With Quote
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
FS: USB TV / FM Tuner, haupauge usbtv e36mp3 Classified Archive 5 11-18-2004 11:03 AM
USB FM solution good or crap? Jake General Hardware Discussion 2 10-03-2002 02:56 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
