Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 06-02-2007, 07:58 AM   #301
Bj
Bj
it looks to me that you have a short from the active to the ground pcb plane in this photo
BjBlaster! Car MP3 & Carputer!
bjblaster.com
"The solution to one problem is only the begining of another"
Bj is offline   Reply With Quote
Old 06-02-2007, 08:11 AM   #302
bimmerpc is on a distinguished road
"active to the ground pcb plane" means excactly ?
(Pardom my not native english...)
Anyway can I solve that without buying extra components?
Black SolarCell Portable Bluetooth Gps reciever for sale, Contact me!
BMW E46 320 Touring project thread, making the perfect multimedia car ;)
BMW E46 WORKLOG
bimmerpc is offline   Reply With Quote
Old 06-02-2007, 08:32 AM   #303
Bj
Bj
the centre core of your coax (antenna cable) has solder going to the edge of the board (multi layer board) and is most likely touching the ground plane (another track that is ground) and shorting it out. If you have a mulitimeter check that the antenna leads test open circuit between the coax centre cable and the shield. There is already a capacitor on the Silabs board to isolate the RX chip from the antenna, so you should see no DC path between the tip of your motorola and the shield.
bjblaster.com
Old 06-02-2007, 06:14 PM   #304
grayvader's Avatar
grayvader is on a distinguished road
As a note, I also had similar issues with one of these that I messed with. I think I screwed up something internal because it was intermittant after attaching the antenna. Sometimes it would work and sometimes it would do what you described. I suspect that something else (besides the antenna parts) got messed up. I ended up getting a new one and exercised EXTREME care when i attached the new antenna.
grayvader is offline   Reply With Quote
Old 06-02-2007, 07:17 PM   #305
Yeah, I was a bit flimsy with my hand, not much practice before getting onto this chip so I guess the solder iron was touching the pad for a very long time and the board surface looks all messy around the holes
Anyway, does it matter if I have the male lead intact and cut away the female part of the motorola cable or shoule I do it the other way and buy a new cable to cut the male end instead?
BMW E46 WORKLOG
Old 06-07-2007, 03:02 PM   #306
I had some electricians looking at the unit and they could not see any specific short circuit or anything. They measured with a multimeter or what ever they are called. No short. They even resoldered it a couple of times. I Must have destroyed some of the components so I´m ordering one more
BMW E46 WORKLOG
Old 06-07-2007, 03:43 PM   #307
-Stomp- is on a distinguished road
Has someone a direct link where I can buy it, and does they sent it to Denmark? Would like to give it a try...
-Stomp- is offline   Reply With Quote
Old 06-08-2007, 12:13 PM   #308
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
I bought mine from Azzumi but if you go to www.silabs.com/usbradio there should be a link to a seller near you
ShawJohn is offline   Reply With Quote
Old 06-08-2007, 11:21 PM   #309
stryke23x is an unknown quantity at this point
has anyone played with the source code for this at all? I think this would work great for what I need, but I need to make it bigger. I have an 8" 16:9 touch screen molded in my dash. I'm pretty good at graphic design and want to do a new full screen skin for this to match the Digital Dash software I'm using. The only thing I don't know how to do is then modify the source to work with the newly changed size skin. Anyone interested in working on that?
John
stryke23x is offline   Reply With Quote
Old 06-09-2007, 03:45 PM   #310
Raw Wave
ShawJohn's Avatar
it is already integrated into RR and CF! Why re-invent the wheel?
Old 06-10-2007, 12:23 AM   #311
I don't see it in RR and didn't like CF myself. For RR all i see is radiator, dlink, cinergy 600, wintv, hqct, blaupunkt and radioshark. am i missing something?
John
Old 06-10-2007, 09:14 AM   #312
Raw Wave
ShawJohn's Avatar
CDRSKULL has integrated it into Freedom Ultimate, and it is now listed as a Radio device in an updated RRConfig file which was posted up recently.
It is also listed as a radio device in CF from 1.14>
I think Giuno has now built Silabs capability into RR
The Silabs will not work with Vista though as of yet, needs some fiddling as the Silabs software is fine, but release notes mention a modification to make it Vista Compatible, something to do with the New Vista Mixer from what I can gather.
Old 06-10-2007, 09:19 AM   #313
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
John - I've said this before - its does... I've used it under Vista...
Terran
ccsnet is offline   Reply With Quote
Old 06-10-2007, 12:55 PM   #314
Raw Wave
ShawJohn's Avatar
It works fine in Vista with its own software, which has been patched for Vista, but using the RR & CF stuff thats about it refuses to do anything
Maybe you can suggest where Im going wrong, as if I can't sort this out in the next few days I'll be forced to re-install XP Pro, which would be a shame as I managed to get TomTom working pretty sweetly under Vista
Old 07-07-2007, 04:38 PM   #315
Lithoss is an unknown quantity at this point
Otherwise make sure you use a capacitor to couple the antenna if you have a powered (amplified) car antenna and prevent the earth loop problem on the usb radio. Use something like a 47pf ceramic cap between the antenna hole on the PCB and the centre of your coax. Leave the coax shield attached the the ground pad of the board.
has anyone had any success with this for a powered antenna? my subaru has a powered antenna, just wanted to check to see if anyone has done this yet before i rip apart my silabs.
also, the smallest capacitor i can find commonly is 100pf.. here... think thats close enough? why 47pf anyway? thanks guys
Lithoss is offline   Reply With Quote
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
FS: USB TV / FM Tuner, haupauge usbtv e36mp3 Classified Archive 5 11-18-2004 11:03 AM
USB FM solution good or crap? Jake General Hardware Discussion 2 10-03-2002 02:56 PM
