07-13-2007, 10:27 AM
#331
Raw Wave
TP4 is the actual antenna lead. The other node is labeled 'antenna' to show how it connects to the rest of the circuit on page 2. There's a corresponding 'antenna' label there. I agree, it's a poor choice for the label.
Quote: Originally Posted by Lithoss
very true... but why are there two leads labeled antenna??
07-13-2007, 10:39 AM
#332
ah ok, i didnt even look for a second page. yeah they need a reference or a flagnote instead of a redundant label. poor EE practice
07-14-2007, 01:27 AM
#333
Quote: Originally Posted by NiSlo
No I haven't it with a capacitor. I though that was only to prevent a 12v surge hitting the silabs, not to improve reception. For $1 part, it's worth a go I guess
Well, i started installing my carpc tonight. got it far enough to turn it on to see what was working and not. Without powering my antenna i got a little bit of signal from strong stations. hopefully tomorrow when i get it powered it will get better. ill post how it goes.
07-14-2007, 11:56 PM
#334
About 95% done now. I don't know what i'm doing differently but mine works fine while driving. I get little minor pops and fades in and out now and then but its more than good enough until the HD tuner comes out.
07-16-2007, 08:36 PM
#335
 So you've soldered the antenna connection jack onto the silabs, plugged that into your standard antenna in the car and have left the fuse in/removed the fuse? for the antenna and your getting a good signal?
I installed my carpc into my pet Kangaroo, mate.
07-16-2007, 09:02 PM
#336
Yup, i soldered a shielded cable to the silabs exactly like Bj did. I used a good mono audio cable instead of mini coax because i couldnt find any.
Then i ran that short cable (3-4 inches total probably) to this exact connector:
http://www.radioshack.com/product/in...entPage=search
From there it connects right to the subaru stock antenna connector.
You also NEED to make sure that your antenna is getting powered. It needs 12v. Look here: http://www.geocities.com/svxdc/WRX-pinout.htm
Pin 14 is what you're looking for, the blue one.
I did NOT use the extra capacitor, because as rando pointed out, there's already one built into the usb unit.
Yes i left the fuses untouched.
After that, i dunno man. Maybe try checking your usb connections etc. I'm also a very good solderer, its pretty hard to get a perfect solder job on that little board.
07-16-2007, 09:41 PM
#337
The powered antenna may be my problem.
When I tied into the harness to connect my speakers from my carpc, I left the power antenna wire disconnected which would mean that the power antenna isn't getting the juice it needs...
I'll have to take a look this evening after work!
07-17-2007, 12:03 AM
#338
Without the power yeah I'd be surprised if you got any signal at all. I got a little bit, but it was night v day when i powered it.
Even so, silabs isn't the best solution. It's definately not perfect. I can't wait for the HD tuner....
07-18-2007, 04:49 AM
#339
man am i glad that i have the same car as lithoss!
07-18-2007, 08:09 AM
#340
? did ya get it working?
pre '08 impreza's rock
07-18-2007, 02:54 PM
#341
Does anyone know of a uk supplier for this ?
07-18-2007, 02:56 PM
#342
mouser.com will ship to UK, thats where i got mine from
07-19-2007, 03:41 AM
#343
Lithoss,
How have you powered your antenna? Just connected it to the acc wire? I guess if the antenna did draw to much, the acc fuse would blow anyway and prevent any damage somewhere.
07-19-2007, 08:03 AM
#344
Lithoss,
I ran a 12v rail up to my lilliput from the psu in my computer, i tied it into that. acc would work, but yeah you might blow your fuse, i have no idea how much power the antenna pulls. i have my radar detector powered off acc, i've had no problems. eventually i think you'd want to give it something other than acc.
07-27-2007, 12:08 PM
#345
I am a newbie, I installed roadrunner (and I think I have the version with silabs support but it didn't show silabs available in the drop down for config, I just edited the config file to set the value to 7), winamp, digitalfx skin, and have the silabs radio. I can get radio stations ok, but I don't get any RDS. I searched all of this thread and other places but I can't figure out if I am supposed to install something else or configure something to make RDS work.
Regards
David
| Thread Tools |
| Display Modes |
Linear Mode
