Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 12-05-2007, 12:24 AM   #391
NiSlo's Avatar
NiSlo is an unknown quantity at this point
It should also be noted that the Brando USB Radio(cheaper than the Silabs) is actually just the Silabs module in a different case and with an aerial as discussed in this thread.
I'll also help test this new .dll as the main problem I've been having is the sounds not cutting off when changine between radio and media in CF
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 12-05-2007, 03:43 AM   #392
martkrui is an unknown quantity at this point
Currently we are working on a new version so please hold on for a day or two before testing.
If you don't use resume you'll be fine with the original plugin I think. But you should hear noise after you've been using the radio.
martkrui is offline   Reply With Quote
Old 12-09-2007, 02:20 AM   #393
SmoL is on a distinguished road
hey guys,
i've been playing with my skins lately and now i've stuffed up my presets list somehow. I'm using the simplistique skin, can any1 tell me what i need to look for to get the presets to work? everytime i add one via the skin the list is blank the next time i getback to it
SmoL is offline   Reply With Quote
Old 01-15-2008, 12:12 PM   #394
petb's Avatar
petb is an unknown quantity at this point
What i think is wierd is that when you attach a external antenna the recieption only gets good just like a original radio.
could it be that the pc is the bottleneck because it cannot transfer the radio signal fast enough to the usb radio adapter while the cars is moving?..
petb is offline   Reply With Quote
Old 01-15-2008, 01:57 PM   #395
DigitalVampire is an unknown quantity at this point
The behavior of the USB radio when you connect an external antenna should not be any different from your original radio since the RF front-end and hence the sensitivity is more or less the same. The sensitivity may be even worse for a USB radio but it all depends on the hardware implementation of the front-end RF amp/pre-amp.
www.dentalteam.org
DigitalVampire is offline   Reply With Quote
Old 01-30-2008, 01:06 PM   #396
portreathbeach is an unknown quantity at this point
Angry
I would like to know if anyone has had a problem with the USB radio. mine worked fine for about two months, then the computer kept making the 'USB device connected/disconnected' sound and now all I have is an orange LED on the USB radio and the computer will not recognize it.
I emailed Silabs about my problem, and they replied.....
Hello,
Sorry for the delay in answering your email. The problem you are seeing is probably due to flash corruption which means that the contents of the flash has been accidentally modified. In this case you should reflash the device.
To upload again the flash with the correct firmware you will have to do the following:
1. download the latest version of the FM Radio RD firmware from our website:
http://www.silabs.com/tgwWebApp/publ...USBFMRadio.htm
2. connect to the USB FM Radio (you need an USB Debug Adapter for this):
- on the debug adapter's connector, the pin 1 is the one corresponding to the red wire or to the arrow on the connector
- take the FM Radio board out of its casing
- near the MCU are three holes which are the GND (written next to it C12), C2CLK (written R18) and C2DAT (written C17). These holes can be used to connect to the device using the debug adapter as follows
- connect pin 9 of the Debug adapter to GND (hole with C12)
- connect pin 7 of the debug adapter to C2CLK (hole with R18)
- connect pin 4 of the debug adapter to C2DAT (hole with C17)
3. connect the USB FM radio to the USB port and the USB Debug Adapter to another USB port
4. open the silabs ide and press the connect button. The device should get connected
5. extract the zip file you have downloaded
6. open the F320_FM_Radio.wsp project with the silabs ide
7. compile the project and download it to the device.
8. disconnect all wires and everything should be working properly
You will need the full keil compiler to compile this project since it is bigger than the standard 2K. In case you do not have the full keil compiler, I have attached the compiled hex file which can be uploaded to the MCU as is.
Please let us know if you have further questions.
So I have to buy more stuff from them to reflash a product that I bought from them and stopped working! Surely this can't be?
Anyone else had to do this?
portreathbeach is offline   Reply With Quote
Old 01-30-2008, 06:03 PM   #397
NiSlo's Avatar
The Silabs module isn't a 'consumer product' so to speak. It's more of a demonstration of the hardware produced by Silabs that is used by resellers etc.
Old 02-27-2008, 05:59 AM   #398
trinky2000 is an unknown quantity at this point
I can't get my silabs to work good in my car, probably because the car antenna is powered.. If I plug the connector from the silabs to the car antenna it work intermittent, if I unpluggit and try with a simple wire 30cm long work but no very good signal.. so I think the problem is the car antenna..
How can I know id is a powered antenna?
If is powered how can i connect my silabs to it??
My car is New Hyundai santa fe.
trinky2000 is offline   Reply With Quote
Old 02-27-2008, 05:42 PM   #399
After a few more e-mails to Silib Labs and a few tests carried out on my USB radio, they found that it is a fault with the device and are going to send me a new one. Can't wait to try it in the van.
trinky2000, when you say 'powered' do you mean with an amplifier, because every car ariel that I know that is called 'powered' simply means that it is a telescopic ariel which can be powered up and down by the ignition or radio.
ViVE - Volkswagen In Van Entertainment:
VoomPC 2, VIA C7 2GHz
7" Lilliput
120Gb Sata drive
1GB RAM
[||||||||||] 100% - Planning
[||||||||||] 100% - Software coding
[||||||||||] 100% - Built
(Always tweaking!)
Old 02-28-2008, 01:36 PM   #400
I mean amplified...
Any way something strange happened..
I've the cable an the shield soldered to the silabs and I've a connector female connected to the car antenna male connector...
I connected a simple 1 meter wire to the shield by the hole on the plastic of the silabs (a little spot was not covered), this cable is non connected to anything.. then I folded that cable and everithing and place it in the back of the monitor... Everything work great!!!
How that could be???
I'm still not sure if my car antenna is amplified, is a New Hyundai Santa Fe...
Old 03-06-2008, 04:10 PM   #401
Reception while driving
I have read this thread and lots of people are asking what the reception is like while driving. I have installed my USB radio in my van and use the factory fitted ariel. I used an ariel connector (which happened to be connected on the end of a wire) from an old head unit and soldered it directly to the USB radio:
I have written my own front-end, and with the use of Wickerswammie's USBRadio.dll and a VB6 sample code 'SilabTest' I managed to implement the radio in my VB.net project. I find the reception excellent, not quite as good a quality as listening to the CD player or MP3 player, but radios never are.
The RDS is a little bit slow at displaying the station you are tuned too, but the radio text is jumbled. Apart from that the radio works very well, and the signal strength data that can be obtained from the radio is always about 75%. For for the price, it is a must for all car computers. Even with 50Gb of MP3's, it's always nice to listen to the radio now and again.
I'm only speaking from experience in England, it might not be as good in America and other countries, but over here it works fine
7" Lilliput
120Gb Sata drive
1GB RAM
(Always tweaking!)
Old 03-10-2008, 01:24 PM   #402
Right, I have an update. In bad wind and rain the RDS is very poor on the USB radio, but the sound quality stays the same.
7" Lilliput
120Gb Sata drive
1GB RAM
(Always tweaking!)
Old 03-16-2008, 05:20 AM   #403
Beezer's Avatar
Beezer is an unknown quantity at this point
Try my new radio.dll here http://code.google.com/p/silabsradiodll/
You must check the SilabsTest app & implement the new commands.
Beezer is offline   Reply With Quote
Old 03-17-2008, 06:51 PM   #404
Hi Beezer,
I have just downloaded the new usbradio.dll and the source code. After re-programming the FM Radio form of my front-end, I have now implemented RDS text and get the Station name coming up much more quickly than before. I never used Radio Text before, as it was all jumbled. This new USBRadio.dll is far better than the previous one and when programming in VB.NET, the RDS is a lot easier to get hold of (simpler commands and functions)
The Radio mute works much better now. Before I had to turn the USB radio off when going to my MP3 player because of the hiss in the background. Then sometimes when I went back to use the radio, it wouldn't start properly. The radio mute works fine now
Thanks for the great DLL
7" Lilliput
120Gb Sata drive
1GB RAM
(Always tweaking!)
Old 03-17-2008, 07:57 PM   #405
Beezer's Avatar
Another satisfied customer
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
FS: USB TV / FM Tuner, haupauge usbtv e36mp3 Classified Archive 5 11-18-2004 11:03 AM
USB FM solution good or crap? Jake General Hardware Discussion 2 10-03-2002 02:56 PM
