Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 03-22-2008, 03:57 PM   #406
Beezer's Avatar
Beezer is an unknown quantity at this point
I've released a new version of the DLL. Major change is to convert the audio streaming to use DirectShow & DirectSound. Give it a try. If you use Vista, see the note in the "filters" directory.
http://code.google.com/p/silabsradiodll/downloads/list
Beezer is offline   Reply With Quote
Old 03-27-2008, 04:16 PM   #407
Kenshin5 is an unknown quantity at this point
I'm thinking of building one of these with the Si4734 and Si4707 chips, but I have no hardware design experience. I've written a support message to these guys, and I am wanting to build a portable player that incorporates both of these chips using 4 wire or I2C and a complete tuner/capture program.
I think these chips can do it, but again, without hardware experience, it's hard to say. Anyone interested?
Kenshin5 is offline   Reply With Quote
Old 09-23-2008, 09:31 AM   #408
blbrchnk is an unknown quantity at this point
Quote: Originally Posted by portreathbeach View Post
I have read this thread and lots of people are asking what the reception is like while driving. I have installed my USB radio in my van and use the factory fitted ariel. I used an ariel connector (which happened to be connected on the end of a wire) from an old head unit and soldered it directly to the USB radio:
I have written my own front-end, and with the use of Wickerswammie's USBRadio.dll and a VB6 sample code 'SilabTest' I managed to implement the radio in my VB.net project. I find the reception excellent, not quite as good a quality as listening to the CD player or MP3 player, but radios never are.
The RDS is a little bit slow at displaying the station you are tuned too, but the radio text is jumbled. Apart from that the radio works very well, and the signal strength data that can be obtained from the radio is always about 75%. For for the price, it is a must for all car computers. Even with 50Gb of MP3's, it's always nice to listen to the radio now and again.
I'm only speaking from experience in England, it might not be as good in America and other countries, but over here it works fine
Hello I have been working with my silabs usb radio for a little bit and while it does get some reception, it doesn't get as good of reception as what my old radio used to. Before I got power to it, it was hardly getting any radio at all. The thing is, mine doesn't look like those in all of the pictures I have seen in the forums here. When I took mine out of the casing, the antenna was fastened to the PCB on a metal square piece and that was it. I assume maybe it was connected to the ground plane somehow in the middle, but I don't know. When I soldered the coax to it, I put the core of the wire in the big hole left by the antenna and took the foil/shield wires to the outer casing of the usb. Did I do this correctly? I would assume it should sound better than it does currently. Any help would be appreciated. Thanks
blbrchnk is offline   Reply With Quote
Old 09-30-2008, 12:48 PM   #409
Bump. Anyone? it is the Brando USB radio with the Silabs chip like the one in this thread:
http://www.mp3car.com/vbulletin/cent...adio-work.html
Nobody is replying over there either.
Old 10-07-2008, 08:34 AM   #410
bump
Old 10-23-2008, 06:37 PM   #411
SteadVex is an unknown quantity at this point
i'm confused, are there any front ends that just work with the usb radio? looking to build a car pc soon, and i feel the radio isvery very important!
SteadVex is offline   Reply With Quote
Old 10-24-2008, 08:26 AM   #412
Road Runner does.
Old 10-25-2008, 01:46 PM   #413
Quote: Originally Posted by blbrchnk View Post
Road Runner does.
cheers!
Old 10-25-2008, 04:50 PM   #414
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
I'm probably gonna get pounced for this, but FreeICE works with the Silabs and is one of the simple-est front-Ends to install.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 10-27-2008, 11:36 AM   #415
I am still not getting very good reception with my silabs chip.
Old 12-10-2008, 05:53 AM   #416
blade828 is an unknown quantity at this point
Has anyone got sound in any other channel apart from the front channel working at all?
blade828 is offline   Reply With Quote
Old 12-10-2008, 07:35 AM   #417
lez
lez's Avatar
lez is on a distinguished road
funny that, but with my other soundcard, a cheape $9 thing, i used to get sound on the real from the fm.
when i updated my system and got a mb with built in soundcard, i lost it.
seems the drivers for my original card automatically duplicated stereo sound sources onto the rear channels, and the new one does not.
Whats most annoying is that media player when playing mp3 _does_ duplicate the front channels on the rear!
I have not been able to get this working in over a year of trying different drivers.
soudcard that did work for me was the cmi chipset, the 6 channel one, but it was the chipset which could stlll do line in while doing 6 channel out, think it was the lx, or not the later, cant remember
lez is offline   Reply With Quote
Old 02-02-2009, 12:23 PM   #418
MTUACE is an unknown quantity at this point
Does anyone still have the source code for this floating around?
MTUACE is offline   Reply With Quote
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
FS: USB TV / FM Tuner, haupauge usbtv e36mp3 Classified Archive 5 11-18-2004 11:03 AM
USB FM solution good or crap? Jake General Hardware Discussion 2 10-03-2002 02:56 PM
