Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 11-29-2006, 08:36 AM   #91
Bj
Bj
Mouser still sells them - I got mine the other day.
These little tuners are fantastic! It performs 1 billion times better than any of the previous usb radios I have used. I attached an external antenna (75 ohm) to a standard house type splitter between my tv tuner and the silabs. I used to use the magic box pro for FM, but the performance (even though it was the best I had found at that point) is absolutely no match to the quality and signal strength of this tiny little radio! And to make things even better it supports RDS.
Here is the antenna mod I did...
Fitted in car
Here it is running a full 75 ohm system and splitter to both the silabs and the DVBT tuner part of the magic box pro
The only issue I have found is that the RDS info is all jumbled up, or it doesn't refresh at the rate it comes in at. I downloaded the demo from this thread, and all I get it chopped up sentences, it seems that the data coming in is scrolling, but the app can't refresh at the same rate as the scrolling....
Any ideas on this?
Other than that I have got this functioning in my car, all but the rds..
I'm using the vb6 example from a thread I can't find now, but thanks to whoever it was
BjBlaster! Car MP3 & Carputer!
bjblaster.com
"The solution to one problem is only the begining of another"
Bj is offline   Reply With Quote
Old 12-01-2006, 02:33 AM   #92
SmoL is on a distinguished road
awesome work! how's the receoption in car compare to the stock radio head unit? also where did you order it from? I notice your from Aus, yet i cant find anywhere that ships here!
SmoL is offline   Reply With Quote
Old 12-01-2006, 10:48 AM   #93
Bj
Bj
I just followed the link and ordered it from the mouser mob and used fedex to ship it to my door. It ships to oz no dramas. It is better reception that my Sony explod pile-o-crap that's for sure. I'm very impressed with it. It also scores highly for having minimal resources on my M10000 EPIA. The previous Magicbox pro sucked all the juice from the little C3 processor and left me with a laggy bucket of crap. This tuner is truly a piece of art. I love it
bjblaster.com
Old 12-01-2006, 01:59 PM   #94
lez
lez's Avatar
lez is on a distinguished road
emm I really want ond of these but its $60 from mouser, + I might get hammered another $40 import screw fees.
Or azzuri, £27 / $50
I'm thinking seriously.........
I want one.........
Can I justify $50, or should I wait for them to become a mainstream item on ebay for $30, or maybe that wont happen, decisions decisions.......
lez is offline   Reply With Quote
Old 12-07-2006, 11:25 PM   #95
Iceman_jkh is on a distinguished road
Just received mine today.
As soon as you plug it in, its detected straight away - no drivers
Downloaded and ran the software from the site. FM radio coming in nice and clean. Love it.
Gonna mod the antenna like BJ did, and see how it goes in my car.
So far I'm very impressed. Most stations come in atleast 80% strength and thats inside my room (which is a notorious radio/phone reception blackspot)and using the tiny little wire they provide as the standard antenna (1m hookup wire).
Results to follow shortly.
Iceman_jkh is offline   Reply With Quote
Old 12-08-2006, 01:55 AM   #96
excellent, how are you all finding it with radiator? Did ther dll that was posted work ok? any bugs there?
Old 12-08-2006, 01:58 AM   #97
I havent tested with radiator or RR yet, I only used the SiLabs application.
Took it out in the car just now....WOW!
I had to make up a connector/cable just like BJ did.
I used these exact parts:
4 metres of Tv 75Ohm Cable (Air Space) (http://www.dse.com.au/cgi-bin/dse.st...uct/View/W2082)
1 Radio Antenna Socket (http://www.dse.com.au/cgi-bin/dse.st...uct/View/P2002)
I got the "Air Space" which has a copper braid instead of the slightly more expensive aluminium quad shield version (product code: W2087) because I was told that its not possible to solder to the aluminium braid with much success.
I made up the Motorola socket at one end of the cable and soldered the other end directly to the SiLabs FM USB board (same as BJ did in his pic - Signal = Right, Shield = Left).
Took the gear out to my car, extended the radio antenna, plugged the 4metre coax cable into the car's male motorola plug and fired up the PC...
The radio reception was excellent. Sound was excellent. All stations came through very clearly, with only minor static now and then. In the future I will probably bypass the motorola connection and wire some quad RG6 directly from the FM USB Radio to the antenna terminals.
I also tested the device while driving... same excellent reception whether parked or doing 100kph!
Thus far (with my very limited testing) I am extremely happy with this unit!
Ice
Old 12-08-2006, 03:37 AM   #98
Where can I find the latest RoadRunner plugin for this device?
I'd love to test it with RoadRunner now that I know it sounds great using the default software .
Old 12-08-2006, 08:33 PM   #99
fI'm not 100% sure but from what I understand you just need radiator (which rr uses) you can try the DLL thats posted earlier in this thread. or try what they do here: http://www.mp3car.com/vbulletin/software-faqs-solutions-tutorials/38073-how-make-your-bt878-other-radio-tv-tuner-work-radiator.html to get any tuner to work with radiator.
Let me know how it goes
Old 12-08-2006, 08:39 PM   #100
I looked, but couldnt find the DLL
Old 12-09-2006, 06:53 AM   #101
Bj
Bj
Ice
It's an amazing little unit! As long as you keep the impedance loaded correctly it works like a little ripper! I'm glad you had the same excitement as I did when it worked so well
ps I modified my site with the changes... http://orcboys.homedns.org/general/o...e_pc/index.htm under the radio section...
bjblaster.com
Old 12-09-2006, 09:21 AM   #102
BJ,
I do get a little static in some areas. Would Quad shielded RG6 soldered straight onto the USB unit from the antenna, improve the reception at all over the current 4metres of RG59U airspaced cable which I have connected via the stock motorola plug?
Is it true that the aluminium braid shield is difficult to solder onto the board?
Should I solder/connect directly onto the antenna or leave the motorola plug in place? (I assume this plug+cable has a different impedance than 75Ohm)
Old 12-09-2006, 06:39 PM   #103
Bj
Bj
Well I don't have any of the stock antenna cabling at all. I replaced the Motorola socket and stock cabling with all 75ohm gear. It made the difference on my setup anyway. I used 75 ohm micro coax (which I soldered) to go between the unit and the Quad shielded stuff, this way I didn't have to solder any of the RG6 coax connections (see original picture for small section to Belling Lee Connector) to the tiny FM Tuner board.
bjblaster.com
Old 12-10-2006, 01:51 AM   #104
inniss777's Avatar
inniss777 is on a distinguished road
Does anyone have an update on the ability to use this tuner with radiator?
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
inniss777 is offline   Reply With Quote
Old 12-10-2006, 01:59 AM   #105
inniss777 you can't be serious, have you even read the thread. Its right in here. People already have it running with RR and i posted another solution to get it working on this same page!
Dude thats just lazy, I mean theres a post of a guy with it running on this same page. Don't know how much more obvious it can be...
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Not enough power to USB devices >> Possible Solution? Tuckie General Hardware Discussion 20 11-16-2005 12:24 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
FS: USB TV / FM Tuner, haupauge usbtv e36mp3 Classified Archive 5 11-18-2004 11:03 AM
USB FM solution good or crap? Jake General Hardware Discussion 2 10-03-2002 02:56 PM
