Quote: Originally Posted by Silentbob343
I'm interested, but if I had your device set to for 1 minute and my M1 set to 10 minututes would it start to shut down after 10 minutes, i.e. just like running the M1 by-itself, or would it start the shut down after 1 minute. Or would your device essentially take over the soft-off feature from the PSU? I like the idea of the device shutting the computer off after one minute if the key is not turned, but worry about two devices with timers interferring after the key is turned-on and then turned-off.
The device is very easy to wire.
Four wires Input
1. +12v Battery
2. +12v Ignition
3. +12v or ground keyless/alarm signal wire
4. Ground
One wire output
1. +12v signal to your power supply or other startup shutdown controller
Optional 5v 2A to 6A output to power other devices like USB2.0 hub
Devise replaces your ignition wire output to your power supply or startup/shutdown controller.
Let me know the other ideas of functionality you may want for this device.
Estimated price for a one unit is $60 USD and with optional 5v power supply $68 USD. Price will depend on how many people would want to order.
