Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 02-21-2006, 07:51 AM   #151
CristianC is on a distinguished road
Quote: Originally Posted by Vicne
Very interesting.
So for the ones who speak zero-french, the information above is the compatibility table for the VDO/Dayton CHM 604 MP3 CD changer. Please note that this changer is configurable as digital or analog output. As you can see, it works on "all references" for Renault cars of 2004 and 2005, while it is limited to the given models for previous years.
Is possible that some models to use analog input (not SP/DIF) for CDC audio line? ( I hope)
CristianC is offline   Reply With Quote
Old 02-21-2006, 07:59 AM   #152
peppuz79 is on a distinguished road
look here:
http://www.planeterenault.com/forum/...&view=previous
peppe
peppuz79 is offline   Reply With Quote
Old 02-21-2006, 08:46 AM   #153
pippolippi is on a distinguished road
Very interesting.
Pippolippi, is your model referenced as compatible ?
Mine is exactly like yours: RENRDW131-10 (Scenic II, November 2003)
pippolippi is offline   Reply With Quote
Old 02-21-2006, 10:13 AM   #154
Putput's Avatar
Putput is on a distinguished road
I've found this page here where they sell CDC units, according to this info all HU Tuner List and Update List from 2000 on are compatible.
Putput is offline   Reply With Quote
Old 02-21-2006, 10:56 AM   #155
Vicne is on a distinguished road
Then it's absolutely logical that you don't see anything coming out of the HU.
I'd say start the HU, then try to send only "PLAYING" commands every second, with track=1 and both times at 00:00:01 and see if you get acknowledges in return.
Vicne is offline   Reply With Quote
Old 02-21-2006, 10:58 AM   #156
The "from 2000 on" means "digital sound link".
As far as I know, models before 2000 had analog sound between CDC and HU.
Which car model and year do you own ?
Old 02-21-2006, 11:35 AM   #157
I already tried that with no success. As I said, I think that the level of my usb serial adapter isn't enough for the HU, so I'll have to wait until someone design a good interface circuit, that is rs232 compliant on one side and gives 0-12V on the other.
Old 02-21-2006, 12:35 PM   #158
I think that Ale's proposal in post # 131 should be OK. You don't need the stuff at the bottom to drive a relay (except the IC-powering part, of course), so it's rather straightforward. The IC should support 20V supply (absolute max) so maybe the Zener diode also isn't absolutely needed.
Of course, you need to invest in a 4050 but well...
If you don't want to go that way, you can increase the output voltage with a transistor, but if you invert the voltage, don't forget to do it twice...
To avoid damaging the HU with a short-circuit (as these proposals use the HU's 12V as power supply), maybe it would be wiser to use first a secondary power supply : a 9V battery should do the trick and you can test your circuit beforehand by setting your input on either 0V or 9V and measuring the output with a simple multimeter. Just don't forget to link your battery's negative contact to the HU connector's ground.
Old 02-21-2006, 03:37 PM   #159
I'm not too sure: looking at the characteristics for the hef family, the minimum input voltage is -0.5V, the max low input (at 15v) is 4V (probably 3.5 at 12v) and the minimum high input is 11V (probably 9V at 12v).
With this characteristics I think it makes no difference connecting the HU to the serial port directly or through the buffer: if the level coming from the HU is critical to interface directly to a serial port I think it'll also be critical wrt the hef4050b input. OTOH the levels coming from a "real" serial port (+12,-12) are outside the lower limit (-0.5v) and a laptop/usb probably won't have enough voltage to drive it high. If you put a divider network things are even worse.
Maybe the best solution is to use a max232 and the buffer.
Old 02-21-2006, 04:47 PM   #160
I think a simple diode could take care of that...
Well, to keep simple, the solution of the comparator (LM234) proposed my Mox would probably be better suited. Power it with 12V, enter your serial port Tx with a diode on a positive input and the set the threshold of the negative one with a divider bridge. (e.g. 47K/10K to get a threshold around 2V - but the diode causes an offset). You could even put a 100K potentiometer to be able to adjust the threshold.
Any comment is welcome.
Old 02-22-2006, 12:16 AM   #161
My car is DACIA LOGAN made in 2005
HU is 22DC229/62 (I see that this model is present on Twingo II form 2002)
Old 02-22-2006, 03:28 AM   #162
Yes indeed, so I'm afraid it's digital...
Old 02-22-2006, 05:40 PM   #163
(I have the strange feeling that everybody's coding hard...:-) )
Old 02-22-2006, 06:08 PM   #164
Update
Slightly modified version of the rosetta stone document. Mainly fixed formating and typo
**OUT OF DATE. AN UPDATE IS AVAILABLE IN A POST FURTHER BELOW **
Old 02-22-2006, 06:17 PM   #165
mox
mox's Avatar
mox is on a distinguished road
Except for those who own a Connects2
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
mox is offline   Reply With Quote
