02-24-2006, 02:27 AM
#181
Quote: Originally Posted by pippolippi
But then both current loop and rs422 would need 4 wires, so I was probably wrong
Not nessecarily true, if using half duplex current loop is using 2 wires instead of 4, rs422 is based on balanced voltage and uses 4 wires.
02-24-2006, 05:56 AM
#182
Quote: Originally Posted by Vicne
Conclusion :
You have to link pin 3 (Transmit Data) of the serial port to pin 14 (RxD) of the blue connector to send PLAYING frames.
You have to link pin 2 (Receive Data) of the serial port to pin 13 (TxD) of the blue connector to read HU commands.
mmmh, I cannot swear it (I don't have my notes here) but the led on my adapter lights up when I connect pin 2 to 14, so either there's a pull-up resistor there [see the edit] or it's the Tx line, not the Rx.
I'll try tonight or tomorrow to connect everything as you say and try (again) to send frames to the HU.
Edit: if is there a pull up resistor it's not going to work with a diode in series on the rs232 tx line, so I'm not going to try.
02-24-2006, 08:50 AM
#183
Vicne, is it possible for you to make a relatively simple test?
Disconnect the spying circuit (or leave it connected, it shouldn't make a difference), leave the connection between the CDC TX and the HU RX but disconnect the opposite one (HU TX->CDC RX).
Leave the scope in place and check, when you connect the remote cable (edit: or if it is permanently connected when you turn on the HU), if you can see the signal from the CDC and the reply from the HU and the levels.
If you can see the reply at the same level we can definitely be sure that it's voltage and not current based. You can also check if the start sequence from the CDC is enough for the HU to recognize the CDC is connected, but that's not the main goal of this test.
02-24-2006, 08:52 AM
#184
My god, I followed the wires twice, taking notes, and am 99% sure that's correct, but as it's in contradiction with what you say and also CristianC's original post - and I'm missing a bit of sleep - , I'll check a third time, disconnecting one of the wires to be sure.
I should add a disclaimer here (and maybe on the first post of the thread) : Please note that I don't take any responsibility bla bla...
02-24-2006, 09:01 AM
#185
Don't worry, if I fry my HU rx it'll be no worse than it is now (since I'm not going to install a changer). If it works, good, if it doesn't, bad luck but not a big deal.
Besides, it's not my car
02-24-2006, 09:13 AM
#186
OK, I wanted to be sure : I just disconnected pin 14 of the blue connector and started a capture session, and only saw acknowledges from the head unit.
So these acknowledges from the head unit come out of pin13 of the connector, that is the one farthest from the front of the head unit.
Maybe my schema is ambiguous regarding pin numbering as it depends whether you look "at" or "through" the connector. Numbering refers to the one of pinout below.
So I confirm that if you want to emulate a CD changer :
02-24-2006, 09:29 AM
#187
So these acknowledges from the head unit come out of pin13 of the connector, that is the one farthest from the front of the head unit. [....]
So what is the HU acknowledging?, since, according to what you just said, it shouldn't see anything from the CDC.
02-24-2006, 10:12 AM
#188
No, no, that's not what I meant. Everything was still connected between HU and CDC. I only disconnected the derivation from pin 14 to the MAX. I opened the circuit before the 10K resistor if you like.
02-24-2006, 10:41 AM
#189
Rosetta stone update
Here's version 3, with full PLAYING frame decoded.
02-24-2006, 11:30 AM
#190
So, since by connecting pin 14 to my rs232 port the led lights up, either my HU is wacky or there's a pull up resistor on the HU input.
Could you try the test I suggested on post #183?
02-24-2006, 11:40 AM
#191
I just came across that topic with a picture of the back of an "Update List" HU and the connectors are not arranged the same way as on the "Tuner List". Are you sure of the pin numbering there ? On the "Tuner List", the plastic tab to unlock the connector next to pin 18 is on the right (when looking at the HU from the front), and I wonder if the connector is not rotated 180° on the "Update List"...
Maybe you should check with a voltmeter which pin is at 12V while the HU is OFF : that is pin 16.
02-24-2006, 11:55 AM
#192
Well, I don't have the scope anymore.
If it's not a reversed plug, I can try to borrow it again indeed, although the test by CristianC and Mox's description of the Connects2 make me think more and more that it's voltage based.
02-24-2006, 01:29 PM
#193
If the question is for me, the answer is: yes I'm sure, since I have the same model as you
02-24-2006, 05:57 PM
#194
Here my HU, Megane 2 - 2003 -
How I can help you? Excluding logging?
02-25-2006, 08:04 AM
#195
Can I be of help trying something? Me however I don't have the cd chargher. But I am very practical with the printed circuits and the pc.
| Thread Tools |
| Display Modes |
Linear Mode
