Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 02-27-2006, 07:41 PM   #241
Vicne is on a distinguished road
More about logs
I reformated the "dumps13", captured when opening A and B in the spying circuit, and confirm that the HU should reply with an acknowledge when questioned with a frame such as :
- 3Dh 00h 03h 11h 60h 06h 49h
It's also interesting to see that when the CDC receives no ACK, it retries 2 times the same frame without incrementing the id (so 3 identical frames in a row), then waits for 1 second and tries 3 times with the next id, and so on until id = 09, then it falls back to 00h. No idea why...
Vicne is offline   Reply With Quote
Old 02-27-2006, 07:50 PM   #242
Ale
Ale is on a distinguished road
Quote: Originally Posted by Vicne
- Tried with a pull up to the Head Unit's 12V (12.25V actually) : nothing
Are you sure that this pullup can supply almost 12V at pin 14? what value have you tried?
Ale is offline   Reply With Quote
Old 02-27-2006, 08:11 PM   #243
STOP
I had typos in my code ! Start of frame is 3Dh, not D3h !!!
Old 02-27-2006, 08:25 PM   #244
Belgian Champagne
Ladies and gentlemen, we're getting very close !
Once I send correct frames, I AM GETTING ACKNOWLEDGES BACK ! :-)
See capture below (Acknowledges come as soon as I turn the HU on), along with fixed code :-).
I sent both BOOTING and PLAYING and both are getting acknowledged. Well, that's not sufficient yet for the HU to allow me to switch source, but it's now just a question of emulating startup sequence I think.
For the circuit, I left the transistor in open collector configuration, with no divider on the base (once again, less components works better :-) )
So to finish this historic day here's a picture of my setup (PC, interface, hacked M/F blue mini-iso connector and Belgian Champagne :-) )
Cheers !
Old 02-27-2006, 08:37 PM   #245
The pull-up still was 4K7 but it seems it's not needed.
I think voltage measurement of 5.7V when putting this resistor to ground shows that there most probably is some internal pull-up and we can safely leave an open collector, right ?
For the sake of completeness, here's the circuit I'm using. Now finally I think more people (without a CDC) can enter the game :-)
Note : having re-read the MAX3232 Data Sheet this afternoon, it seems I should replace the three 0.1uF capacitors at pins 2, 6 and between 4 and 5 by 0.47uF ones as my power supply is 5V and not 3V (see table 2, page 9)
Thanks again for your insightful input, as well as pippolippi's.
Old 02-28-2006, 06:47 AM   #246
pippolippi is on a distinguished road
Is the max232 really necessary when going from the HU to the PC?
I know that you probably are using it because you already have it, but IIRC you made previous tests with only the 10k resistor.
I'm asking because if the max232 is not needed from the HU to the PC I'm thinking to replace the transistor and the max232 with an optocoupler and a diode (since the optocoupler wouldn't stand more than 5v of reverse voltage).
Code:
----------------------------- GND------ 1--|---- |------------|--6 | | | | | \---/ \ | ------ | | \ / \ | | / C | | | --- \ \| | |/ | | | | \ -- --| ---|--5 HU RX 1N4148 | | \| B |\ | TX ---|<- 2--|---- -- | V E | | --------|--4 HU GND 3--|--NC | ----------------------------- CNY17
Note the apparently reversed connection of the optocoupler: the transistor will be open with a positive TX (hence a 12V via the internal pull-up of the HU) and closed with a negative TX (hence 0V to the HU).
Edit: of course a resistor is needed in series with the optocoupler's led in order not to fry it. Around 2K should do.
pippolippi is offline   Reply With Quote
Old 02-28-2006, 07:48 AM   #247
Yes, it worked with a simple 10K resistor only.
Honestly, I'm using it not only because I have it but also because I'm feeling more comfortable being in the spec than in the "undefined area that should work". I know that most PCs nowadays are probably similar to mine and present the same characteristics, but what if not ? It's not the 5K input impedance that I doubt of (it is defined in the spec), but more the threshold supposedly around 1.5V. What if people use exotic serial ports (USB>serial / PDA / ...) with other characteristics ? The [-3V ; 3V] zone is "undefined" according to the RS232 spec, so I prefer to remain out of it.
I wouldn't say that if it implied an expensive specific component, but a MAX3232 (or MAX232) costs around 2 EUR and can be obtained as free sample from Maxim within a few days, so I "won't afford the economy" (if you see what I mean). Simpler yet, the MAX233 has internal capacitors. It's a bit more expensive but cabling is reduced to almost nothing.
I prefer not to have people asking us why their circuit doesn't work and have to imagine all possibilities, including exotic serial ports. It must work :-)
But of course, if you want to use simple resistors in your specific case, no problem...
Mmh, I'm not used to optocouplers but why not. Now let me guess... you do have a CNY17 in stock, don't you ? :-). Well, I'm probably not the best to comment on that solution, but from a newbie point of view, this doesn't seem incredibly simpler than using the MAX I think...
(Nice ascii art by the way :-) ).
Tell us if you get results, it's always good to have alternative solutions.
Old 02-28-2006, 08:50 AM   #248
No, actually I have an unused max232 hanging around with capacitors and everything already connected, and maybe even a couple of npn transistors.
OTOH revising various optocoupler circuits online maybe they're not suitable for these speeds without a lot of extra components.
Old 02-28-2006, 09:02 AM   #249
BTW, the datasheet for the max232 says that input voltages for T_IN have to be between -0.3V and 6V
Old 02-28-2006, 09:14 AM   #250
Yes...
And they are, as T1IN (pin11) is linked to R2OUT (pin 9) which is TTL level (0-5V) and T2IN is tied to GND to avoid leaving it floating.
I don't see the problem (if any).
Old 02-28-2006, 09:40 AM   #251
I was confused
Old 02-28-2006, 10:44 AM   #252
I was confused
No problem. We probably all need some sleep :-)
Well, if you have components to build a circuit similar to mine, I'd advise that you do that first as it's now known to work. That would confirm :
- that you didn't fry your HU
- that your software is working
- that the pinout and wiring are correct
Then why not go the "10K" way for Rx, and if it's still ok, fiddle with the Tx to see if you can make something simpler/cheaper/smaller...
For my part, I'll work on the software to improve the finite state machine and mimic the CDC's bootup sequence.
Old 02-28-2006, 11:41 AM   #253
slimmegane's Avatar
slimmegane is on a distinguished road
I'm ready very best work! Now I have only 1 question: Where I can find a female connector to connect to HU ???
Thanks very much to all for contribute to Renault and MP3 car forum!
Thanks!
ITALIANI: DISPONIBILI MODULI OEM GPS:
http://www.mp3car.com/vbulletin/show...214#post639214
slimmegane is offline   Reply With Quote
Old 02-28-2006, 12:40 PM   #254
As I said, I have found (and tested) two ways of getting one :
- full Blaupunkt extender (useful for me to get both M and F plugs) for 16 EUR in a car audio store (Blaupunkt ref 7 607 621 154).
- eBay : The female connector (+ contacts) costs 5 EUR (+4 EUR S/H for Belgium) at http://stores.ebay.de/ADAPTERSHOP (search on "blau"). Others sell it under the name "mini-iso" but some don't include the contacts.
Old 02-28-2006, 02:27 PM   #255
nisianp is on a distinguished road
connections-please help
Hello,
My car is a Renault Clio 1.4 8V (October 1999) and I have a Renault radio cassette player (Philips) with these connections
I bought a radio cd player (model DC 278/62B) with these connections
I tried to connect the cd player but I couldn’t connect the screen connector from my car to new radio cd
Does anyone know if I can connect the cd player to my car, and how ?
Please help.
nisianp is offline   Reply With Quote
