03-10-2006, 08:03 AM
#361
Thanks a lot Vicne  You're GREAT! Your solution is more faster that the Girder!
Now i will test it and report the feedback! See later
03-10-2006, 08:09 AM
#362
Excuse me vicne, how istall this release?
03-10-2006, 09:46 AM
#363
Err, like the other ones :-) :
In very brief, unzip, check config and double click the bat file
If it fails,
- make sure you have RxTxSerial.dll in the path (JDK bin dir or windows\system32), just like you did with the dll of the first release,
- double check settings in TLCDEmu.properties
- ask here :-)
Long howto :
http://tlcdcemu.sourceforge.net/howto.html
03-10-2006, 09:49 AM
#364
I've copied the RxTxSerial.dll in Java path (C:\Programmi\Java\jre1.5.0_06\bin) but when I lunch the .bat it start after more time on my desktop PC. Now I will try in Car.
03-10-2006, 09:53 AM
#365
Note that most of the starting time is caused by the GUI Plugin. It's useful for debugging, but for normal operation, I would advise to remove it from the plugin list in TLCDCEmu.properties as it's a memory and CPU hog.
Hopefully in a few days the only plugin we'll need is the ExecutorPlugin or its dll equivalent (plus maybe the "router" I already talked about).
03-11-2006, 05:13 AM
#366
Working circuit with optocouplers
Here's a revised circuit using optocouplers that actually works:
The disadvantage of this circuit is that, if the rs232 connector is disconnected, the program will think that the HU is on, but that's not really a problem (in fact I could probably do away with the HU detection and simply retry until I have an answer).
This even works with the inverter but I found that my inverter is putting out some tough ****: even with all cables disconnected (so no possible ground loop possible) from time to time the serial adapter "disappears".
One interesting thing to note is that the HU doesn't really care that the sequence number is incrementing: I tried just toggling it between 0 and 1 and it worked just fine, so the HU only checks that a sequence number is different than the previous one.
Attached is the modified python program (the changes are to detect the HU is on with DSR low instead of high and some little cleaning of the input buffer).
You invoke it with the name or number of the serial port, e.g.:
Code:
python cdc.py 1
python cdc.py /dev/ttyUSB0
if you want more verbose output add "verbose"
Code:
python cdc.py /dev/ttyUSB0 verbose
It shuld be easy to extend and adapt.
03-11-2006, 08:51 AM
#367
Hi pippolippi,
good work! very simple and clear, a question: what is the working differences between your circuit and the Vicne's circuit whit MAX232?
The python script is more clear! I've undestand and I don't know any programming language
Good works!
03-11-2006, 10:17 AM
#368
Hi pippolippi,
The pc is completely isolated from the hu. I needed it because, as soon as I connected the inverter to power my laptop, the laptop shut off, probably due to some ground loop.
If the pc gnd is already connected to the car/hu gnd then the optocouplers are not necessary. In that case you can use the circuit with the max232 or the simpler one I posted earlier:
keep in mind that the fact it works here it doesn't mean it is well designed, so maybe it doesn't work with your serial port (though I think it should).
Good works!
Great, even though I prefer pascal, python is pretty good for many things. Head to python.org, there are some good tutorials there if you want to learn.
03-11-2006, 10:28 AM
#369
I've tested the new version whit exec.exe command but i wasn't able to work, I've update RR to last version (03mar) and I've copy bin directory to C:\ I've set the ExecutorPlugin.properties like this:
[code]
# Warning : always use double backslash as separator.
# e.g. C:\\Windows\\Notepad.exe readme.txt
EVENT_NEXT=C:\\bin\\exec.exe NEXT
[\CODE]
But when I press next button from HU they don't change anything, only track on display, the Java program receive the command and write NEXT pressed (or similar) the sound go off for 1 second but RR still play the some track.
If I from CMD run "exec.exe NEXT" RR change the track.
If I set: EVENT_NEXT=C:\\bin\\exec.exe C:\\windows\\notepad.exe nothing appear.
Where I wrong?
P.S. If I press a button from 1 to 6 from HU (Disc select) the sound go off and I must change source and return to fake CDC to sound go on
P.S.2. In car the TLCEmu startup fast, I think there is the Antivirus on Desktop PC that run slow. How remove the GUI Plugin? Is sufficent to remove the
"Plugins=org.tlcdcemu.plugin.gui.GUIPlugin,org.tlc dcemu.plugin.logical.LogicalPlugin"
string in "TLCDCEmu.properties" file?
03-11-2006, 01:35 PM
#370
Attached is a version that does just that, so the upper optocoupler (and the corresponding resistors) can be omitted.
It also contains what I think is the correct meaning of packet 93: HU on (it is sent only when the HU has just been switched on, not when the communication is established with the HU already on).
03-11-2006, 02:40 PM
#371
Oops, I think I didn't update the TLCDCEmu.properties in the zip file. It should look like
Code:
DebugLevel=3
SerialDriverClass=gnu.io.RXTXCommDriver
SerialPortName=COM1
Plugins=org.tlcdcemu.plugin.gui.GUIPlugin,org.tlcdcemu.plugin.executor.ExecutorPlugin
# org.tlcdcemu.plugin.logical.LogicalPlugin
Yes, this is a known issue. I'll fix that.
The line Plugins contains multiple values, separated by a ",". All are optional.
03-11-2006, 04:27 PM
#372
Hi pippolippi,
Pippolippi's circuit also has the great advantage of being self-powered, I mean you don't need any extra wires to get the 5V power from the PC.
Finally, it also has one more feature in that it sends to the PC the information whether the head unit is on or off (Remote wire).
The only (small) drawback I can see is that two output wires (RTS & DRT) are used to provide voltage levels to the optocouplers, so you need 2 more wires between the serial port and the adapter (but you already need 4 including remote, so it's not a big deal) and you cannot use those signals for another purpose.
Currently, the Java emulator version you have doesn't set these signals to the correct levels so it won't work as is but I'll change that right now.
Honestly, as soon as I have a bit of time, I think I'm gonna build Pippolippi's interface as well and use that one.
03-11-2006, 04:59 PM
#373
But that's not really necessary (see above post #370)
Since you don't need the isolation you could also use the simpler one (only 2 transistors).
03-11-2006, 05:03 PM
#374
True. I hadn't read your post carefully.
Yes, but I like the idea of optical isolation, and I might change the PC one day and forget about that, so...
03-12-2006, 04:41 AM
#375
Ok, I will try now
Yesterday I've test the system and I've see when HU go OFF while the PC sound it continue to sound, this is a good work for me, because the HU is OFF but the sound is still ON  and this is good for my battery.
But when I power on HU the CDC don't appear in Source List. I must close TLCEmu and re-run.
This is only a report of my test, this isn't a criticism!
Bye and Thanks!
| Thread Tools |
| Display Modes |
Linear Mode
