Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 03-13-2006, 06:40 AM   #391
Quote: Originally Posted by Vicne
Also, don't you think of using a DC/DC converter (car adapter for your laptop) instead of the inverter which probably introduces lots noise due to hashing ? OTOH, they're often rather expensive...
Yes, that's the problem: the price. Not that I wouldn't spend the money if it was my laptop, but it is not my laptop (as it is not my car, everything is the property of my company).
Besides the car adapter would be specific to it, while the inverter, albeit much less elegant and efficient, it's useful (in theory) with other laptops (if/when they give me another one) and other devices.
pippolippi is offline   Reply With Quote
Old 03-13-2006, 07:29 AM   #392
I see.
Well, it doesn't have to be your adapter, couldn't it be theirs too ?
Sure...
Vicne is offline   Reply With Quote
Old 03-13-2006, 08:24 AM   #393
Piggy HUTester
Hi,
the 'piggy HU tester' :
HU
13 <---- /\/\/\ 10 kohm -----> 2
14 <-----/\/\/\10 kohm ------> 3
15 <--------------------------->5
I've tested with the both version of the software and working fine, but ONLY the booting frame can be received from the HU .
It's good for testing HU or for the people that don't want anything else.
Bye
Peppe
peppuz79 is offline   Reply With Quote
Old 03-13-2006, 08:51 AM   #394
HU
Well, I'm not sure of your goal...
What we called the "BOOTING" frame is generated by the emulator and goes to the HU...
The simple 10K resistor is known to work for reading signals coming from the HU, but as far as I know it doesn't work the other way, to send signals to the HU, because of the HU's internal pull-up.
Once again, maybe don't understand what you want to achieve...
Old 03-13-2006, 09:20 AM   #395
of course
sorry error in cut&paste :
3 <---> 14
you can use this interface only to see in dashboard "Tr 1 CD 1" and listen the music from some SPDIF source.
right?
pep
Old 03-13-2006, 09:47 AM   #396
3 <---> 14
Oh, you mean you tested without a resistor there and it works ?
So for the moment you win the "simplest interface" contest with a "1-resistor" circuit. You can only be beaten if we can get rid of the 10k resistor altogether - which could be the case btw... Wanna give it a try ?
What I don't undestand is that it seems to activate the SPDIF in, but you say only the booting frame can be received and I don't understand why. If the circuit is OK for this frame, it should be ok for others too, shouldn't it ?
Old 03-13-2006, 10:04 AM   #397
I'll have to find a very convincing excuse, I just cannot justify it saying that I can work in the car while commuting, can I?
(I usually have mains supply available when I need the laptop for work use).
Old 03-13-2006, 10:12 AM   #398
Well it depends on your boss. You could try :
- I need access to navigation programs to get to work earlier when there are traffic jams. It's either an adapter or a Tomtom
- When I'm on the way back, it's a good time to charge the PC so I can continue to work at home (cause I don't have mains supply at home, the house is only lit with candles)
- I think there's a new market the company should be involved in. It's called "carpeecee". Never heard of it ?
Old 03-13-2006, 10:30 AM   #399
This isn't going to work, since it's a 2km commute
Mmmh, my boss lives nearby, so he know this isn't true. He also know that I'll never work from home
This is the most suitable excuse, after all he asked me to setup internet access at the office when everybody else either didn't know what it was or though it was a passing fad. But it's too far away from our line of business.
Old 03-13-2006, 11:27 AM   #400
This isn't going to work [...]
Then sorry for you .
Maybe find an adapter on eBay or "hope" it's the serial adapter which is defective - which wouldn't surprise me...
Old 03-13-2006, 01:11 PM   #401
Yes, it's the serial adapter. With another one there's no such problem. The one that's working has a screened cable while the one with the problem has a plain cable, no screen.
Old 03-13-2006, 01:15 PM   #402
I think that "simpler is better" (on the same principle I'll see if I can simplify further the optocoupler interface, I think that I can do away with at least the transistor from the HU).
Well, that wasn't a good idea, since not only it doesn't work, but while rewiring the circuit to revert it the previous, working, one, I made a mistake and blew the transistor. I hope it's just the transistor and not the hu
Edit: the mistake was that I connected the collector directly to 12V, bypassing the 680ohm resistor.
Old 03-13-2006, 04:34 PM   #403
Hot hot hot
Well, I hope the transistor played a fuse role and the HU is not damaged...
Old 03-14-2006, 03:00 AM   #404
- CD change buttons are now handled correctly.
I noticed yesterday that I have a rather strange behaviour upon CD change and I think I know why, partially at least :
- First, after CD has changed, the HU sends a "PLAY" command to start playing the new CD. Unfortunately, Roadrunner (and Winamp BTW) give a toggle behaviour to "PLAY" : first time it begins playback, second time it pauses, third time it starts again, etc. So in our case, the "PLAY" sent after CD change is considered a "PAUSE". Then you have to press PAUSE twice to restore the correct behaviour (fortunately, Roadrunner and Winamp don't consider "PAUSE" as a toggle). So unless I find a non-ambiguous way to "PLAY" (that would have no effect if already playing), I'll have to filter out this "PLAY after CD CHANGE" (as well as the "NEXT after RANDOM ON" mentioned by Pippolippi)
- Second, sometimes, a CD change seems to lock things up. HU doesn't send commands anymore and I have to switch the HU OFF and back ON to restore the correct behaviour. I'm suspecting it's because I currently send the 18 frames that normally follow a CD change request in a single burst. Maybe I should send the first 15, then wait for the "PLAY" command before sending the last 3 ones... (see rosetta stone)
Apart from that, I'm rather happy with my tests. I'll concentrate on finishing the hardware this week...
Old 03-14-2006, 03:43 AM   #405
Though I didn't perform extensive testing, I didn't notice any problem upon cd change. But then I'm just sending the "I'm playing" frame, I don't try to simulate the cd changer real sequence.
