07-17-2006, 05:46 PM
#571
Quote: Originally Posted by lond
I can get a PIC16F628 at my local electronic store.
Can you plz compile the code fore me?
//Marcus Löfstrand
Hmm, this require some check of config register, internal clock, baudrate etc.
If you really need the hex code I can build it within some days but i cannot test it, i haven't in plan to buy the pic16f628.
07-17-2006, 07:45 PM
#572
Hi
I found the right PIC at digikey.com, butt they don't deliver to Sweden
Do you know where I can by the PIC with in EU?
//Marcus Löfstrand
07-17-2006, 11:25 PM
#573
Quote: Originally Posted by Ale
Check the configuration word in the winpic should be 0x30e4.
if you use the internal oscillator check if the bit time is 104uS.
adjust value of register osctune (in the main routine) to obtain the correct time.
I checked winpic and config word at address 2007: 30E4
i tested with my scope and i can see a 102-106 uS signal (i need a new scope, i can't see the exact timing with my old phillips scope  )it hasto be 104us exactly?
i used your code with internal oscillator, do i have to adjust value of register?
if you select to use internal osc,you dont have external osc parts, then why do you have to adjust the osctune? do i have to adjust the osctune with each pic processor that i want to use?
and why i cant see communications with hyperterminal? i tested to connect the pic emu to the pc and i cant see any data, i tested at 9600 8-E-1 but with the scope i can see the data
07-18-2006, 09:49 AM
#574
Have placed a order of some samples from microchip, I hope they arrive son
//Marcus Löfstrand
07-18-2006, 02:05 PM
#575
The tolerance admitted usually is +-1% (103-105uS). the tolerance of internal osc given in datasheet is also +-1% but at 25°C and 5.0V.
If the pic is at its limit tolerance should be adjusted.
If you get the signal from the collector of the transistor that go to HU-RX(14) check if the out level is 0-12V. If is ok perhaps your PC need a compliant rs232 so i suggest you for testing purpose to use a free max232 tx inverter that get the signal from pin 6 of pic and send its out to rs232 pin 3.
If you are pratice with excel VBA i can give you my program to test the PIC. It need the mscomm32.ocx that you can get by installing a simple program see the site XL_RS232
07-18-2006, 02:49 PM
#576
I think a litlle about this problem and It should be that my PIC is out of tolerance, so it is better to start with osctune = 0;
then there is way to test the frequency without the oscilloscope:
the routine the send the "play" frame every second should work exactly every ONE second so if you count 60 frame should take 1 min.
There is a small correction to do to adjust this time that in release 1.7 is wrong, i use the value 117 for next timer0 period but it should be 125.
As in the following code:
Code:
char getChar2(unsigned millisec)
char ch;
char next = 0;
tmr0 = 2; // deduct 2*8 fixed instruction cycles delay
do {
next += 117; change to 125;
while (iwr==ird && tmr0 != next) // 125 * 8 = 1000 (= 1 ms)
} while (iwr==ird && --millisec != 0);
07-23-2006, 09:36 AM
#577
Renault iPod solution
After a long search, I have found a solution, thanks to Dee Keenan of Armour Automotive Ltd.
It is now possible to connect your Renault Update List radio to your iPod without losing the CD changer. Autoleads are about to bring out a lead which plugs into the AUX input and connects to the bottom of your iPod so that it recharges it as well (although you actually need two parts, as the AUX lead only has a phono on the end, which you then need to connect to the iPod lead). The leads should be available through any Autoleads (part of Armour Automotive Ltd) dealer from the end of July (although you should be able to preorder them now). Their dealers are listed on their site at http://www.autoleads.co.uk
The parts will be PC7-REN-J for 3.5mm jack, and PC7-REN-P for phono connection. You also need the PC7-POD-200 and PC7-POD-L along with the Renault aux, and this would charge the IPOD and take audio all from the base of the unit, rather than from the jack port, which would refine the audio quite a bit. (I’m not sure which of these is the right part but the Autoleads dealer should be able to tell you).
I have just pre-ordered my leads.
Peter
08-01-2006, 04:08 AM
#578
I have made a VDO CDC simulator with a atmage8L, using c program.It can reserve the original cdc
08-01-2006, 07:40 AM
#579
Wonderful!
Could you post some other details, pics and schematics, please?
08-01-2006, 08:42 PM
#580
 Just use two transistor as inverter connect with the TX\RX from HU, then you could receive the correct data from the HU.
08-11-2006, 03:02 AM
#581
Hi all,
I'v seen this forum 4 month ago, and I was very happy because I also want to connect Ipod to my head unit.
I tried the code, and it worked  But since Ipod doesen't have SPDIF out I have decidec to make my own converter  . After a few weeks of design and tips form CS the converter is ready ( At least the schematics ). It should work without a problem according to the chip's manufachter.
I didn't have the time and the possibility to try it, but I will do it in the next weeks.
It is designed to have a PIC and a max232 in the same circuit to make it complete. The Pic is 16F88 and it has been tested to work. ( Still displays CD 0 TR1  .
If anybody is interested then I will post the schematics and the hex also.
Regards
András
08-11-2006, 04:53 AM
#582
Of course we are all interested
08-11-2006, 05:52 AM
#583
So,
Here is the schematics.
Hope I've helped you.
Regards
András
08-11-2006, 06:12 AM
#584
Sorry I forgot some additional info.
The converter uses a CS5330/CS5330 delta-sigma ad converter, and CS8406 SPDIF transmitter. The circuit generates 18 Bit, 48 khz Stereo signal.
Of course you can easily modificate it to 24 bit 196 khz, but then you have to replace th cs5330 to cs5340 ( I think ). And also you have to add another preamplifier, and modificate the connection of cs8406 ( take care about the data flow, etc. ). Also you have to replace the transformer because it is only valid up to ~60 khz ( for example PE-65612 ).
Both cs ics are from Cirrus Logic. The TLC272 is a pre-amplifier. And a reset ic is required. The current one is from Dallas/Maxim.
Before anybody trie it please read the datasheets carefully because the circuit is very sensitive to grounding shields, and the type of capacitors.
If you can try it before me please let me know.
Regards
András
08-11-2006, 06:24 AM
#585
This looks great, thanks for the info!
I'll have to look at this with a friend that understands electronics better than me, and I'll tell you for sure how this works out. Did you program the PIC yourself or you used the PIC code that was on this forum ?
Why did you go for 18bit/48kHz and not 16bit/44.1kHz ? (just curious)
Do you have to program the SPDIF chips or you just plug them ?
| Thread Tools |
| Display Modes |
Linear Mode
