Go Back   MP3Car.com > Mp3Car Technical > Hardware Development
Old 09-24-2008, 04:37 AM   #1261
almond1303 is an unknown quantity at this point
How do I connect the HQCT-eA?
Now that I have a HQCT-eA. How do I connect the HQCT-eA?
I'm assuming I connect from the computer ear jack to the HQCT-eA either by the aux1 audio input or the aux2 audio input. Is this correct?
almond1303 is offline   Reply With Quote
Old 09-26-2008, 03:10 AM   #1262
Kosti is on a distinguished road
Quote: Originally Posted by Diogenes View Post
Hi,
it does make sense.We have expanded the functionality of our RRHQCT software to do just what you want, right now we test it with the HQCT-eA but it will work with any HQCT.
RR is starting the RRHQCT program when radio is selected and stopping it when another sound source is selected. We have modified our software to switch to AUX2 instead of stopping the program. When selecting Radio the program will adjust the volume setting to follow the selected volume slider in windows (i.e. follow the volume slider of RR). When switched to AUX2 the volume settings of the HQCT for this setting are fixed, ie can only be changed in the RRHQCT window, because RR is controlling the volume of the other sound sources (via soundcard or Winamp,...) the HQCT must NOT influence it. Basically, one must select Radio, tune to a station and adjust the RR slider to a certain level, then switch to another source, set the RR slider to the same position as for radio and then adjust the RRHQCT volume slider to get the same sound volume, after this, the RRHQCT program stores this setting and the volume from all sources wil be the same and controlled from the RR slider.
This is still the beta version, we did plan to switch to AUX1 after the program is running fine.
We will modify it right now and send you a copy of the program, do send us your mail address (mailto info@datalex.be), the program is too large to attach to this thread so i want to send it directly to you.
Since RR is using Windows messages we had to overcome the stop program command sent when selecting another sound source or when exiting RR. In order to stop our program you must click 1 first and then 2, otherwise RRHQCT stays ON and you cannot stop the PC...
Hope this made sense...
Diogenes.
Hi Team,
Were should I post comments on this beat app? For now I will use this thread.
This is how I would like my HQCT to operate.
[1] AUX output always active without RRHQCT running (if possible) defaults to this on exit
[2] When switching from Radio or when radio app closed, then AUX to be the default and for the HQCT to auto switch back to AUX.
What I've found with this beat software.
[1] Cannot close app, have to use task mgr to force close, i assume this is part of your comments to choose 1 first then 2 to close
[2] This app has heaps of options and setting so I do not know how to accurately use it to it's full capacity - any dummy's guide
[3] Have to sometimes toggle radio off / on to get sound.
[4] Audio levels always vary or seems to default
[5] As I run this on my carpc with 7in screen, I cannot see other option in the RRHQCT app.
Is there anything specific I need to further try to aid with this beat testing?
Thanks heaps!
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Kosti is offline   Reply With Quote
Old 10-13-2008, 11:32 AM   #1263
kinnu is an unknown quantity at this point
Hello.
This is where I stand with my project atm. By removing the internal smb connactions and soldering the antenna wire directly to the board helped reception a bit, by moving the radio module as far as possible from psu helped also a bit, but overall it is still very bad.
I found another weird error today the reception of the antenna is affected by LCD, if its turned on i can hear a huge loss of signal. From my tests its not bound by the vga cable or the power going into the lcd, tried with external battery and removed vga cable completely from pc. The bad thing is that it affects the overall performance of any radio reciever in the car e.g. tried that with an aftermarket car radio. Any ideas? Im using CarTFT CTF1020 lcd.
Another thing i wanted to let you guys know that i solved the hqct hanging problem after suspend:
1) first of all i removed the ultrathin power cables from the M2-ATX - psu i was using and replaced them with 4mm2 ones. Then i connected hqct directly to the 12v and 5v rail of the psu, but i cut the 5v rail with a relay and let the 12v rail to drive it. So basically as long as 12v is active the radio module is powered, but if it goes to suspend the relay will cut off the 5v and reseting the module completely. On resume the power will be restored long before centrafuse activates radio itself. I figured that i can even add a switch to the relay, so i can basically reset the module without restarting the whole pc. That kind of reset requres the restart of CF also, but that's still alot faster than complete restart. So far it has been working well.
kinnu is offline   Reply With Quote
Old 10-14-2008, 03:11 AM   #1264
with the HQCT-e
Can u tell me the purpose of joining 2&3 and can the antenna supply a constand trigger for my amps? or will the 12v drop after the tuner is closed and CD or AUX is selected?
Finally what is the purpose of input activations for the NAV & PHONE?
Old 03-19-2009, 10:06 AM   #1265
plunderisley is an unknown quantity at this point
I seem to have a volume issue. I can tune the radio and I hear it, but it's very low volume. Is there a way to fix that?
I had to do a line in option on the back panel as my Intel GLY2A mobo doesn't have a aux in or cd in option inside. The line in volume is 100%, RRHQCT is 100% volume also.
plunderisley is offline   Reply With Quote
Old 03-20-2009, 06:46 AM   #1266
bugiman's Avatar
bugiman is on a distinguished road
HQCT-eA for sale
Hi
I have a HQCT-eA for sale, god condition have hardly been used.
Antenna connection/adaptor included.
/Martin
bugiman is offline   Reply With Quote
Old 04-25-2009, 06:21 AM   #1267
inakif is an unknown quantity at this point
I could be interested if it works fine.
I can listen for the price but I cannot pay much as I am looking for the HQCT-i that I want to attach to an external 5x40W amplifier.
regards
inakif
inakif is offline   Reply With Quote
Old 04-28-2009, 01:35 AM   #1268
bugiman's Avatar
If you do not want to use the built-in amplifier you can connect the external 5x40W amplifier to the output.
On the back of the HQCT-eA there are phono connections for external devices.
The unit is in perfect condition and have only been used a couple of times.
Old 04-28-2009, 04:25 AM   #1269
In fact, it will depend on the price you sell, because a new HQCT-i it is 99€ and a 4x40W amplifier it is 20€.
How much will be your price?
regards,
inakif
Old 05-05-2009, 04:44 AM   #1270
bugiman's Avatar
120€ + shipping is fine by me
Old 05-05-2009, 11:21 AM   #1271
hi,
sorry, but after checking my audio configuration, I need only the amplifier for the front speakers as the rear ones are already amplified by default.
So, I am looking for the HQCT-i and external 4x40W amplifier.
thanks anyway for the offer
regards,
inakif
[RELEASE - Public]GPSSecure - GPS Tracking xBrady GPSSecure 23 03-05-2006 09:33 PM
Hot Chicks Thread - NOT WORK SAFE ODYSSEY Off Topic 1 05-17-2005 10:38 PM
Amp or HU dilemma paul167 Car Audio 4 11-03-2004 06:45 AM
Request regarding the Offical Skin Presentation thread Confused MediaCar 3 01-07-2004 12:52 PM
