Quote: Originally Posted by DarquePervert
The drive int eh headunit isn't setup to read data whatsoever, so this really is pointless to attempt.
The Xenarc 700IDT has enough space to squeeze a slimline slot-load drive into the casing, if you're interested in changing direction on your screen choice (assuming you haven't purchased yet).
DP, I think you missed the point, he want to remove the cd mechanism in the headunit, and replace it with one that will interface with the computer, powered by the computer. He just wants to use the HU as a "housing".
While it seems possible, I doubt it will work. The only way to find out is to take the HU apart, and see how much physical room there is.
Also, it is POSSIBLE, that the unit must "see" the CD mechanism in order to work properly, though that is just an assumption.
Let us know how it turns out.
Michael
